Forum Members section DIY Ferduino controller PCF 8575
PCF 8575  [SOLVED]
Post Number:#1 Post Sat Jun 14, 2014 3:35 am
Germany
Hello i hab Problem .
The Demo Code for pcf blink Works
My Problem is in the ferduino Code the Funktion Timer Not Works , i haf Controll LED plugget on ground pcf an pinn
P00 .
If plugget arduino on 5v -Controll LED ls ca 3 sec on an is the tft on is LED of .
LED Not on or Timer 1 on or Off .
Pinn's pcf A0 A1 A2 plugget on ground
Please help me
Post Number:#2 Post Sat Jun 14, 2014 12:03 pm
To use the PCF8575 with Ferduino you need change some lines on code.
Uncomment this line:
https://github.com/FernandoGarcia/Fedui ... ta.ino#L71
Change:
const byte temporizador1 = 80; // P0 // Pino que liga o timer 1.
const byte temporizador2 = 81; // P1 // Pino que liga o timer 2.
const byte temporizador3 = 82; // P2 // Pino que liga o timer 3.
const byte temporizador4 = 83; // P3 // Pino que liga o timer 4.
const byte temporizador5 = 84; // P4 // Pino que liga o timer 5.
const byte solenoide1Pin = 85; // P5 // Liga a reposicao de água doce.
const byte temporizador1 = 0; // P0 // Pino que liga o timer 1.
const byte temporizador2 = 1; // P1 // Pino que liga o timer 2.
const byte temporizador3 = 2; // P2 // Pino que liga o timer 3.
const byte temporizador4 = 3; // P3 // Pino que liga o timer 4.
const byte temporizador5 = 4; // P4 // Pino que liga o timer 5.
const byte solenoide1Pin = 5; // P5 // Liga a reposicao de água doce.
Uncomment this lines:
https://github.com/FernandoGarcia/Fedui ... a.ino#L843
Add:
PCF8575 PCF8575;
After:
byte endereco_PCF8575TS = 0x20; // Endereço em hexadecimal = 0x20
Change:
boolean PCF8575TS_S = false;
to:
boolean PCF8575TS_S = true;
Comment this lines:
https://github.com/FernandoGarcia/Fedui ... up.ino#L49
https://github.com/FernandoGarcia/Fedui ... up.ino#L73
Change all "digitalWrite" to"PCF8575.digitalWrite" on this tab.
https://github.com/FernandoGarcia/Fedui ... adores.ino
Change all "digitalWrite" to"PCF8575.digitalWrite" on this function:
https://github.com/FernandoGarcia/Fedui ... s.ino#L220
Last edited by Fernando Garcia on Sun Aug 31, 2014 2:28 pm, edited 1 time in total.
Reason: Added more changes.
Post Number:#3 Post Mon Jun 16, 2014 7:50 am
Germany
Hello, Fernando, many thanks, is.
absolutely super.
thank you thank you thank you :ymhug:
