Post Number:#261 Post Wed Oct 07, 2015 3:48 am
Time and date do not save on power failure, I replaced the battery twice now. I was thinking about setting the code to check the server time and date every 10 seconds so if there is a power outage it will set on it's own. Any thoughts?
Post Number:#262 Post Wed Oct 07, 2015 10:45 am
I won't add it to Ferduino code.
If you want add in your code here have an example.
 * Last Updated - March 21, 2012
 * Open Ocean Reef Controller by Brandon Bearden
 * This work is licensed under the Creative Commons
 * Attribution-NonCommercial-ShareAlike 3.0 Unported License.
 * To view a copy of this license, visit
 * http://creativecommons.org/licenses/by-nc-sa/3.0/
 * or send a letter to Creative Commons, 444 Castro Street,
 * Suite 900, Mountain View, California, 94041, USA.
 * IN NO EVENT SHALL THE LICENSE HOLDER BE LIABLE TO ANY
 * PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL,
 * OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OF THIS
 * SOFTWARE AND ITS DOCUMENTATION, EVEN IF THE COPYRIGHT
 * HOLDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * THE LICENSE HOLDER SPECIFICALLY DISCLAIMS ANY WARRANTIES,
 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
 * THE SOFTWARE PROVIDED HEREUNDER IS ON AN "AS IS" BASIS,
 * AND THE LICENCE HOLDER HAS NO OBLIGATION TO PROVIDE
 * MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
 * OR MODIFICATIONS.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Time.h>
/* ******** Ethernet Card Settings ******** */
// Set this to your Ethernet Card Mac Address
byte mac[] = { 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF };
/* ******** NTP Server Settings ******** */
/* us.pool.ntp.org NTP server
   (Set to your time server of choice) */
IPAddress timeServer(96, 44, 157, 90);
/* Set this to the offset (in seconds) to your local time
   This example is GMT - 6 */
const long timeZoneOffset = -21600L;
/* Syncs to NTP server every 15 seconds for testing,
   set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 15;
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
time_t prevDisplay = 0;
void setup() {
   Serial.begin(9600);
   // Ethernet shield and NTP setup
   int i = 0;
   int DHCP = 0;
   DHCP = Ethernet.begin(mac);
   //Try to get dhcp settings 30 times before giving up
   while( DHCP == 0 && i < 30){
     delay(1000);
     i++;
   if(!DHCP){
    Serial.println("DHCP FAILED");
     for(;;); //Infinite loop because DHCP Failed
   Serial.println("DHCP Success");
   //Try to get the date and time
   int trys=0;
   while(!getTimeAndDate() && trys<10) {
     trys++;
// Do not alter this function, it is used by the system
int getTimeAndDate() {
   int flag=0;
   Udp.begin(localPort);
   sendNTPpacket(timeServer);
   delay(1000);
   if (Udp.parsePacket()){
     Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
     unsigned long highWord, lowWord, epoch;
     highWord = word(packetBuffer[40], packetBuffer[41]);
     lowWord = word(packetBuffer[42], packetBuffer[43]);
     epoch = highWord << 16 | lowWord;
     epoch = epoch - 2208988800 + timeZoneOffset;
     flag=1;
     setTime(epoch);
     ntpLastUpdate = now();
   return flag;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
// Clock display of the time and date (Basic)
void clockDisplay(){
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
// Utility function for clock display: prints preceding colon and leading 0
void printDigits(int digits){
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
// This is where all the magic happens...
void loop() {
    // Update the time via NTP server as often as the time you set at the top
    if(now()-ntpLastUpdate > ntpSyncTime) {
      int trys=0;
      while(!getTimeAndDate() && trys<10){
        trys++;
      if(trys<10){
        Serial.println("ntp server update success");
      else{
        Serial.println("ntp server update failed");
    // Display the time if it has changed by more than a second.
    if( now() != prevDisplay){
      prevDisplay = now();
      clockDisplay();
Source: https://github.com/OpenReefs/Open-Reefs ... tpSync.ino
Only replace all code for "Time.h" to work with "DS1307.h"
-------------------------------- Last edited Wed Oct 07, 2015 11:02 am --------------------------------
I got it to work on separate Arduino I will post step by step and add comment tomorrow I have get to bed for work tonight :-B
No multiplexer just prototype shield and Arduino Mega 2560.
1) 5 volt from 2560 to VCC on stamp.
2) ground to ground
3) TX3 from 2560 to RX on stamp.
4) RX3 from 2560 to TX on stamp.
5) Connect USB to 2560.
open IDE>open file EZO Mega> keep BAUD rate the same (9600) for the first load of code> load code> open serial monitor> send this: serial,38400<cr> next in IDE change the SERIAL(9600) to SERIAL(38400) load new code to 2560 open the serial monitor change baud rate to 38400 and send this c,0 to stop constant read then send this (serial,?<cr>) response should be (?*OK,38400)
THIS WAS NOT DONE ON FERDUINO BOARD WAS ON A STAND ALONE 2560 AND PROTOTYPE SHIELD.
I was talking about a step by step to a full controller, because you are starting from ground.
And the stamp worked?
Post Number:#263 Post Sun Oct 25, 2015 1:01 am
+12V is connected only on pin 9 (ULN2003) and in red wire of your fan.
DO NOT connect +12V to RJ11.
Connect only - 12V (GND) to GND in RJ11.
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=11&image_id=378
P.S. There a convention: RED is for positive wire and BLACK to negative (GND) wire.
By this I should be able to control more than one fan?
Post Number:#264 Post Sun Oct 25, 2015 9:02 am
Yes, connect the second fan to F2 and PWM in parallel.
Post Number:#265 Post Sun Oct 25, 2015 3:53 pm
Okay know I understand the schematic a little better thank you, also I can not get my probes to calibrate. I am using the test code for stamps and Atlas calibration guide. so far on EC stamp all I have done brings the same results SG, 1.000, am I missing some thing?
As for the fans I will not use PWM for now just on and off, but I did get 10 uln2003 ICs for my project build, it will be the same system for on and off.
Post Number:#266 Post Sun Oct 25, 2015 9:04 pm
Post Number:#267 Post Tue Oct 27, 2015 8:11 am
Try to calibrate only with EC stamp connected maybe the others stamps are interfering.
Are you using a refractometer to check the salinity?
Post Number:#268 Post Tue Oct 27, 2015 11:36 pm
Post Number:#269 Post Thu Nov 05, 2015 5:01 am
Hi all, so I found my refractometer was out of spec so I re-calibrated and found my salinity was very low, now it is in spec and probe is reading correctly.
Also is there an issue with having date and time read from a net sever for the Ferduino?
Post Number:#270 Post Thu Nov 12, 2015 2:02 pm
Patrick Meister Random avatar
Hi Christopher,
Fernando have you seen this?
I found it atlas scientific
Image: http://www.ferduino.com/forum/gallery/image.php?album_id=17&image_id=381
I'm the founder of Whitebox Labs. We're the maker of the product you posted there.
First of all, great build you did here. I wondered if you have some pics of your tank somewhere? I'd love to see it.
I've noticed you and some others here had troubles making the EC circuit play nice. Simply put, there is an issue of crosstalk between the EC and other circuits when used in the same closed / common ground system. The reason for this is the way the EC probe works. The probe basically applies a voltage between 2 points internally to measure the conductivity of the water. The other probes (e.g. PH) are influenced by that voltage and will give wrong or unstable readings.
So IF you're using the EC circuit, there's no way around individual circuit isolation - if you need stable and exact readings, that is. But there are more reasons for isolation, even if you're not using the EC circuit. An aquarium can be quite noisy, electronically speaking. Pumps in the water, or lamp ballasts close to the water can introduce noise and stray voltage. If you can see your readings jump when switching on/off lights or other aquarium devices, that's why.
Of course we all know that the circuits, probes, calibration solutions et cetera add up to a price! Isolation adds even more. But it's a small price to pay for stable and accurate lab-grade readings. Having an isolated circuit offers more accuracy than the rolls royce of probes connected to an unisolated circuit.
@Fernando, I'm glad you liked our design and got inspired by it. I like how you introduce individual isolation to the Ferduino in an elegant way using an innovative backpack design.
  • For Ferduino users, you should get Fernandos new iso module.
  • On a breadboard, the Atlas Scientific PWR-ISO is an affordable way to isolate up to 2 channels.
  • On a normal 5V Arduino, the Tentacle Shield might be an option for you.
Happy hacking!
Patrick
PS: We've created a handy setup sketch for the Atlas Scientific circuits. It was initially designed for the Arduino & Tentacle Shield, but with some small modifications it should be easy to make it run on the Ferduino too. Let me know if you need help adapting the code.
It does auto-detection of circuit type and baudrate. It let's you setup and calibrate the circuits easily in an interactive way through the Arduino IDE serial monitor. You can download it here.
Post Number:#271 Post Fri Nov 13, 2015 2:55 pm
Welcome Patrick!
This interference between EC and others stamps was found recently by Atlas Scientific.
Previously in Atlas site's the image for carrier board was:
Now is:
Including the message marked in red.
Sometimes the electric noise can be minimized using an average of values and/or ground probe but, the best option is use the isolator.
Regarding my ISO shield, coming soon the Christopher will assemble a prototype.
The Tentacle shield isn't simple to use with Ferduino controller because it's for Arduino Uno so, user will have problem to stack others shields.
Post Number:#272 Post Fri Nov 13, 2015 4:57 pm
Looking forward to it.
My project is based on this shield. :D
Your iso shield is based on the Tentacle Shield design, right? I assume you will respect the spirit of open source and release it under the same license (CC BY-SA 4.0). Thank you.
Yes I think using the Tentacle on Ferduino is not optimal. While certainly possible, it does not make a lot of sense. Except you need 8 or 12 sensor circuits on your Ferduino :D
However, have you had a look at the "Setup Sketch" i linked in above? It might be useful, also to set up the Atlas circuits on Ferduino (without using Tentacle at all).
Patrick
Post Number:#273 Post Fri Nov 13, 2015 5:16 pm
The schematic will be available for all when the board is available in my shop.
I did see your code, it's more complex than the example that I did. Thanks for your suggestion.
[codebender]https://codebender.cc/embed/sketch:76554[/codebender]
Post Number:#274 Post Fri Nov 20, 2015 4:15 pm
Iso is working great but on a more sour note the file with my completed code in it was corrupted by another program so I get to start my code from scratch again @-) :-l
Post Number:#275 Post Fri Nov 20, 2015 9:17 pm
I'm glad to hear my ISO shield is working fine. :)
I don't understand your problem with code.
Post Number:#276 Post Sun Nov 22, 2015 1:32 am
As I had to start over from scratch I am having some issues with web settings, I can get base64 to respond but not joy-reef. I have found that the port only shows open for a second or two after reboot of the ferduino then is closed. and also found base64 will only read once then coes not respond.
Post Number:#277 Post Sun Nov 22, 2015 11:30 am
This problem is conflict between SD card and W5100 as you know.
Try to format the SD card again.
Post Number:#278 Post Sun Nov 22, 2015 3:07 pm
yep I forgot how important it is to start with a fresh SD card, Thanks Fernando. ^:)^
still the same results, it will connect once then not again.
Post Number:#279 Post Sun Nov 22, 2015 5:50 pm
At this point I have done the following,
1) reformat card 3x
2) changed speed in all 3 ranges half, full and, quarter.
3) changed gateway in multiple ways.
4) did the changes to the D1307.h and D1307.ccp files as well.
I did go all the way through the with web control setup, checked for the changes in webserver and ferduino tabs to make sure they were okay, All of these files are from the new down loads from forum or github.
here is the setup code. To change speed.
//------------------------setup------------------------------
  // Comment out the line below to use pins 0 and 1 to control the coolers .
  Serial.begin(38400 ); // Starts communication with the serial port 0 for debug messages .
  Serial3.begin ( 38400 ); // Starts communication with the serial port 2 which are connected to the " stamps" .
  // Set the pin function.
  pinMode(alarmPin, OUTPUT);               // Pino 0;
  pinMode(desativarFanPin, OUTPUT);        // Pino 1;
  pinMode (ChipSelect_SD, OUTPUT);         // Pino 4 ou 5;
  pinMode(ledPinUV, OUTPUT);               // Pino 8;
  pinMode(ledPinBlue, OUTPUT);             // Pino 9;
  pinMode(ledPinWhite, OUTPUT);            // Pino 10;
  pinMode(ledPinRoyBlue, OUTPUT);          // Pino 11;
  pinMode(ledPinRed, OUTPUT);              // Pino 12;
  pinMode(fanPin, OUTPUT);                 // Pino 13;
  pinMode(multiplexadorS0Pin, OUTPUT);     // Pino 16;
  pinMode(multiplexadorS1Pin, OUTPUT);     // Pino 17;
  pinMode(aquecedorPin, OUTPUT);           // Pino 42;
  pinMode(chillerPin, OUTPUT);             // Pino 43;
  pinMode(ledPinMoon, OUTPUT);             // Pino 44;
  pinMode(wavemaker1, OUTPUT);             // Pino 45;
  pinMode(wavemaker2, OUTPUT);             // Pino 46;
  pinMode(ozonizadorPin, OUTPUT);          // Pino 47;
  pinMode(reatorPin, OUTPUT);              // Pino 48;
  pinMode(SelectSlave_ETH, OUTPUT);        // Pino 53;
  pinMode(sensor1, INPUT);                 // Pino A0;
  pinMode(sensor2, INPUT);                 // Pino A1;
  pinMode(sensor3, INPUT);                 // Pino A2;
  pinMode(sensor4, INPUT);                 // Pino A3;
  pinMode(sensor5, INPUT);                 // Pino A4;
  pinMode(sensor6, INPUT);                 // Pino A5;
  pinMode(bomba1Pin, OUTPUT);              // Pino A6;
  pinMode(bomba2Pin, OUTPUT);              // Pino A7;
  pinMode(bomba3Pin, OUTPUT);              // Pino A8;
  pinMode(dosadora1, OUTPUT);              // Pino A9;
  pinMode(dosadora2, OUTPUT);              // Pino A10;
  pinMode(dosadora3, OUTPUT);              // Pino A11;
  pinMode(dosadora4, OUTPUT);              // Pino A12;
  pinMode(dosadora5, OUTPUT);              // Pino A13;
  pinMode(dosadora6, OUTPUT);              // Pino A14;
  pinMode(ChipSelect_RFM, OUTPUT);         // Pino A15;
  //**************** PCF8575 ****************
   pinMode (temporizador1, OUTPUT);         // Pino 80;
   pinMode (temporizador2, OUTPUT);         // Pino 81;
   pinMode (temporizador3, OUTPUT);         // Pino 82;
   pinMode (temporizador4, OUTPUT);         // Pino 83;
   pinMode (temporizador5, OUTPUT);         // Pino 84;
   pinMode (solenoide1Pin, OUTPUT);         // Pino 85;
  myGLCD.InitLCD(LANDSCAPE); // Image orientation in LCD .
  clearScreen();             // Clean the LCD .
  myTouch.InitTouch(LANDSCAPE);       // Orientation of the " touch screen " .
  myTouch.setPrecision ( PREC_MEDIUM ); // Set the accuracy of the " touch screen " .
  ReadDallasAddress ();
  sensors.begin();                                //Inicia as leituras das sondas de temperatura.
  sensors.setResolution(sensor_agua, 10);        // Define a resolução em 10 bits.
  sensors.setResolution(sensor_dissipador, 10);  // Define a resolução em 10 bits.
  sensors.setResolution(sensor_ambiente, 10);    // Define a resolução em 10 bits.
  sensors.requestTemperatures();                 // Chamada para todos os sensores.
  tempC = (sensors.getTempC(sensor_agua));       // Lê a temperatura da água
  tempH = (sensors.getTempC(sensor_dissipador)); // Lê a temperatura do dissipador.
  tempA = (sensors.getTempC(sensor_ambiente));   // Lê a temperatura do ambiente.
    if(PCF8575TS_S == true)
   PCF8575.begin(endereco_PCF8575TS); // Inicia a comunicação com o PCF8575TS
   for(int i = 0; i < 16; i++)
   PCF8575.pinMode(i, OUTPUT);
   delay(100);
   PCF8575.digitalWrite(i, LOW);
  rtc.halt(false); // Inicia o funcionamento do RTC.
  byte k =  EEPROM.read(0);
  if(k != 222) // Verifica se a EEPROM foi formatada por este programa
    setFont(LARGE, 255, 0, 0, 0, 0, 0);
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_textos[225]))); // "FORMATANDO A EEPROM..."
    myGLCD.print(buffer, CENTER, 115);
    EEPROM.write(0, 222); // Indica que a EEPROM foi formatada por este programa
    for (int i = 1; i < 4096; i++)
      EEPROM.write(i, 0); // Formata a eeprom
  k =  EEPROM.read(796); // Copia valores dos LEDs para a eeprom.
  if(k != 222)
    SaveLEDToEEPROM();
  // Lê a variáveis guardadas na EEPROM.
  ReadFromEEPROM();
  lertpaEEPROM();
  lerPHAEEPROM();
  lerPHREEPROM();
  lerORPEEPROM();
  lerDENEEPROM();
  ler_dosadora_EEPROM();
  ler_luz_noturna_EEPROM();
  ler_timers_EEPROM();
  ler_coolersEEPROM();
  ler_tempPotEEPROM();
  ler_wave_EEPROM();
  ler_calib_dosadora_EEPROM();
  ler_predefinido_EEPROM();
  check_erro_tpa_EEPROM();
  selecionar_SPI(SD_CARD);                         // Seleciona disposito SPI que será utilizado.
  while(!card.init(SPI_FULL_SPEED, ChipSelect_SD)) // Inicia a comunicação com o cartão SD.
    myGLCD.print("PLEASE INSERT A SD CARD.", CENTER, 115);
    Serial.println(F("Please insert a SD CARD"));
  volume.init(&card);
  root.openRoot(&volume);
  t = rtc.getTime(); // Atualiza as variáveis que usam o RTC.
  check_arquivo_temp_agua(); // Corrige o log de temperatura
  check_arquivo_ph_agua();   // Corrige o log de pH da água
  check_arquivo_ph_reator(); // Corrige o log de pH do reator
  check_arquivo_orp();       // Corrige o log de ORP
  check_arquivo_densidade(); // Corrige o log de densidade
    if(Stamps == true)
    //iniciar_stamp_ph_reator();    // Lê o pH do reator
    iniciar_stamp_orp();          // Lê a ORP
    iniciar_stamp_densidade();    // Lê a densidade
    iniciar_stamp_ph_aquario();   // Lê o pH do aquário
  if(Ethernet_Shield == true)
    selecionar_SPI(ETHER_CARD); // Seleciona disposito SPI que será utilizado.
    Ethernet.begin(mac, ip, dnsServer, gateway, subnet, SelectSlave_ETH); // Configuração do servidor.
    server.begin(); // Inicia o servidor.
    Serial.print(F("Ip Server: "));
    Serial.println(Ethernet.localIP());
  strcpy(buffer,Username);
  strcat(buffer,token);
  strcat(buffer,APIKEY);
  base64_encode(Auth1, buffer, strlen(buffer)); // Cria a senha do servidor.
  /*  if(RFM12B == true)
   selecionar_SPI(RFM);                      // Seleciona disposito SPI que será utilizado.
   rf12_initialize(myNodeID,freq,network);   // Inicializa o RFM12B
  clearScreen();    // Limpa o LCD.
  mainScreen(true); // Exibe a tela inicial no LCD.
here is the ferduino tab.
//************************* Funções do ethernet shield ************************************
boolean Ethernet_Shield = true;                     // Change to "false" if not connected to an Ethernet Shield Arduino .
const char *Username  = "ckindig123";               // Place here the user name registered in joy-reef.com
const char *APIKEY = "91733d7";                     // Cole here ApiKey generated by joy-reef.com
const byte maxima_tentativa = 3;                    // Maximum number of authentication attempts .
const byte intervalo_tentativa = 15;                // Waiting time (in minutes ) for retries.
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // The MAC must be unique on your local network .
byte ip[] = {192, 168, 0, 139};                     // Configure the IP according to its local network.
IPAddress dnsServer(8, 8, 8, 8);                    // Configure the IP according to its local network. This is Google's DNS is generally not necessary to change .
IPAddress gateway(192, 168, 0, 1);                  // Set the " Gateway " as their local network.
IPAddress subnet(255, 255, 255, 0);                 // Configure the network mask as your local network .
EthernetServer server(5000);                        // Insert here the number of the configured port on your router to redirect.
                                                    // The port number must be compulsorily either: 80 , 5000, 6000, 7000, 8000, 8080 or 9000 .
unsigned long intervalo = 0;
char *inParse[25];
boolean web_teste = false;
byte tentativa = 0;
boolean web_dosage = false;
unsigned long millis_dosagem = 0;
unsigned long millis_enviar = 0;
boolean web_calibracao = false;
const char *token = ":";
char Auth1[50];
unsigned long teste_led_millis = 0;
And webserver tab.
void processRequest()
  char clientline[110];
  char line[110];
  char *requestString;
  char *RequestString;
  byte index = 0;
  EthernetClient client = server.available();
  uint8_t remoteIP[4];
  IPAddress joyreef(5, 249, 155, 195);
  client.getRemoteIP(remoteIP);
  if (client)
    Serial.print(remoteIP[0]);
    Serial.print(".");
    Serial.print(remoteIP[1]);
    Serial.print(".");
    Serial.print(remoteIP[2]);
    Serial.print(".");
    Serial.println(remoteIP[3]);
    if(((remoteIP[0] == joyreef[0]) && (remoteIP[1] == joyreef[1]) && (remoteIP[2] == joyreef[2]) && (remoteIP[3] == joyreef[3])) ||
      ((remoteIP[0] == ip[0]) && (remoteIP[1] == ip[1]) && (remoteIP[2] == ip[2])))
      while (client.connected())
        if (client.available())
          char c = client.read();
          if (c != '\n' && c != '\r')
            if(index < 110)
              clientline[index] = c;
              line[index] = c;
              index++;
            continue;
          clientline[index] = 0;
          line[index] = 0;
          Serial.println(clientline);
          if (strstr(clientline, "GET /"))
            if(strstr(clientline,"?"))
              //ignore any page request just look at the GET
              requestString = strstr(clientline,"=") + 1;
              (strstr(clientline, " HTTP"))[0] = 0;
              RequestString = strstr(line,"=") + 1;
              (strstr(line, " HTTP"))[0] = 0;
              readRequest(requestString, RequestString);
          break;
    delay(2);
    client.stop();
void readRequest(char *request, char *Request)
  char inData[50];
  byte count = 0;
  char *str;
  char *p;
  boolean invalidPass = true;
  char *pass;
  boolean terminador = false;
  char credencial[50];
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[8]))); // "HTTP/1.1 200 OK"
  client.println(buffer);
  strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[9]))); // "Content-Type: application/json"
  client.println();
  pass = strtok(Request, ",");
  base64_decode(pass, pass, strlen(pass));
  base64_decode(credencial, Auth1, strlen(Auth1));
  invalidPass = strcmp (pass, credencial);
  requestString = strstr(request,",") + 1;
  if (invalidPass  == false)
    for(int j = 0; j < strlen(requestString); j++)
      if(request[j]!='K')
        inData[j] = requestString[j];
      if(requestString[j] == 'K')
        inData[j] = '\0';
        p = inData;
        terminador = true;
        while ((str = strtok_r(p, ",", &p)) != NULL)
          inParse[count] = str;
          count++;
  if ((invalidPass  == false) && (tentativa < maxima_tentativa) && (terminador == true))
    tentativa = 0;
    requestAction(atoi(inParse[0]));
    tentativa++;
    if(tentativa <= maxima_tentativa)
      intervalo = millis();
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[10]))); // "{\"response\":\"000\"}"
      client.print(buffer);
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[11]))); // "{\"response\":\"001\",\"interval\":\""
      client.print(buffer + String((intervalo_tentativa * 60) - ((millis() - intervalo) / 1000)) +  "\"}");
    delay(2);
    client.stop();
void requestAction(byte ID)
  byte cont = 0;
  byte dia;
  float lunarCycle = moonPhase(t.year, t.mon, t.date); //get a value for the lunar cycle
    switch (ID)
  case 0: // Home
    client.print(F("{\"theatsink\":"));
    client.print(tempH);
    client.print(F(",\"twater\":"));
    client.print(tempC);
    client.print(F(",\"tamb\":"));
    client.print(tempA);
    client.print(F(",\"waterph\":"));
    client.print(PHA);
    client.print(F(",\"reactorph\":"));
    client.print(PHR);
    client.print(F(",\"orp\":"));
    client.print(ORP);
    client.print(F(",\"dens\":"));
    client.print(DEN);
    client.print(F(",\"wLedW\":"));
    client.print(LedToPercent(wled_out));
    client.print(F(",\"bLedW\":"));
    client.print(LedToPercent(bled_out));
    client.print(F(",\"rbLedW\":"));
    client.print(LedToPercent(rbled_out));
    client.print(F(",\"redLedW\":"));
    client.print(LedToPercent(rled_out));
    client.print(F(",\"uvLedW\":"));
    client.print(LedToPercent(uvled_out));
    client.print(F(",\"unix\":"));
    client.print(rtc.getTimeStamp());
    client.print(F(",\"running\":"));
    client.print(millis()/1000);
    client.print(F(",\"speed\":"));
    client.print(LedToPercent(fanSpeed));
    client.print(F(",\"moonPhase\":"));
    client.print(fase);
    client.print(F(",\"iluminated\":"));
    client.print(lunarCycle *100);
    client.print(F("}"));
    break;
  case 1:
    //  Send{case, mode, association}
    if (atoi(inParse[1]) == 0) // mode = 0 to read values
      byte numberOfDevices = 0;
      float temperatura1 = 0;
      float temperatura2 = 0;
      float temperatura3 = 0;
      sensors.begin();
      numberOfDevices = sensors.getDeviceCount();
      for(byte k = 0; k < numberOfDevices; k++)
        // Pesquisar endereços
        if(sensors.getAddress(tempDeviceAddress, k))
          if (k == 0)
            temperatura1 = sensors.getTempC(tempDeviceAddress);
            for (byte i=0; i<8; i++)
              sonda1[i] = tempDeviceAddress[i];
          if (k == 1)
            temperatura2 = sensors.getTempC(tempDeviceAddress);
              sonda2[i] = tempDeviceAddress[i];
          if (k == 2)
            temperatura3 = sensors.getTempC(tempDeviceAddress);
            for (byte i = 0; i < 8; i++)
              sonda3[i] = tempDeviceAddress[i];
      client.print(F("{\"number\":"));
      client.print(numberOfDevices);
      if(numberOfDevices < 2)
        if(sonda_associada_1 == 1)
          sonda_associada_2 = 0;
          sonda_associada_3 = 0;
        else if(sonda_associada_2 == 1)
          sonda_associada_1 = 0;
        else if(sonda_associada_3 == 1)
      client.print(F(",\"p1\":"));
      client.print(temperatura1);
      client.print(F(",\"p2\":"));
      client.print(temperatura2);
      client.print(F(",\"p3\":"));
      client.print(temperatura3);
      client.print(F(",\"ap1\":"));
      client.print(sonda_associada_1);
      client.print(F(",\"ap2\":"));
      client.print(sonda_associada_2);
      client.print(F(",\"ap3\":"));
      client.print(sonda_associada_3);
      client.println(F("}"));
    else if (atoi(inParse[1]) == 1) // mode = 1 to save values
      sonda_associada_1 = atoi(inParse[2]); // 0,3,2,K
      sonda_associada_2 = atoi(inParse[3]);
      sonda_associada_3 = atoi(inParse[4]);
      for(byte i = 0; i < 8; i++)
          sensor_agua[i] = sonda1[i];
        else if(sonda_associada_1 == 2)
          sensor_agua[i] = sonda2[i];
          sensor_agua[i] = sonda3[i];
          sensor_dissipador[i] = sonda1[i];
        else if(sonda_associada_2 == 2)
          sensor_dissipador[i] = sonda2[i];
          sensor_dissipador[i] = sonda3[i];
          sensor_ambiente[i] = sonda1[i];
        else if(sonda_associada_3 == 2)
          sensor_ambiente[i] = sonda2[i];
          sensor_ambiente[i] = sonda3[i];
      contador_temp = 0;
      temperatura_agua_temp = 0;
      temperatura_dissipador_temp = 0;
      temperatura_ambiente_temp = 0;
      SaveDallasAddress();
      strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[7]))); // "{\"response\":\"ok\"}"
    break;
  case 2: //config date & time //Send (case, mode, date, month, year, hour, minute, second, day of week)
    if(atoi(inParse[1]) == 0) // To save time and date send inParse[1] = 1
      client.print(F("{\"date\":\""));
      client.print(t.year);
      client.print(F("-"));
      client.print(t.mon);
      client.print(t.date);
      client.print(F("\",\"time\":\""));
      client.print(t.hour);
      client.print(F(":"));
      client.print(t.min);
      client.print(t.sec);
      client.print(F("\"}"));
      dia = validateDate(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2]));
      dia = validateDateForMonth(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2]));
      rtc.halt(true);
      rtc.setDate(dia, atoi(inParse[3]), atoi(inParse[2]));
      rtc.setTime(atoi(inParse[5]), atoi(inParse[6]), atoi(inParse[7]));
      rtc.setDOW(calcDOW(atoi(inParse[4]), atoi(inParse[3]), atoi(inParse[2])));
      rtc.halt(false);
    break;
  case 3:
    if(atoi(inParse[1]) == 0) // Send (case, mode, values)
      client.print(F("{\"hour\":"));
      client.print(hora);
      client.print(F(",\"minute\":"));
      client.print(minuto);
      client.print(F(",\"duration\":"));
      client.print(duracaomaximatpa);
      client.print(F(",\"monday\":"));
      client.print(semana_e[0]);
      client.print(F(",\"tuesday\":"));
      client.print(semana_e[1]);
      client.print(F(",\"wednesday\":"));
      client.print(semana_e[2]);
      client.print(F(",\"thursday\":"));
      client.print(semana_e[3]);
      client.print(F(",\"friday\":"));
      client.print(semana_e[4]);
      client.print(F(",\"saturday\":"));
      client.print(semana_e[5]);
      client.print(F(",\"sunday\":"));
      client.print(semana_e[6]);
      client.print(F(",\"status\":"));
      client.print(bitRead(tpa_status,2));
    if(atoi(inParse[1]) == 1)
      hora = atoi(inParse[2]);
      minuto = atoi(inParse[3]);
      duracaomaximatpa = atoi(inParse[4]);
      for(byte i = 0; i < 7; i++)
        semana_e[i] = atoi(inParse[i + 5]);
      SalvartpaEEPROM();
    if(atoi(inParse[1]) == 2)
      bitWrite(tpa_status,2,atoi(inParse[2]));
      Salvar_erro_tpa_EEPROM();
    break;
  case 4:    //individual led test - load first values
    if (atoi(inParse[1]) == 0) //Send (case, mode, wled, rled, rbled, rled, uvled)
      client.print(F("{\"wLedW\":"));
      client.print(wled_out);
      client.print(bled_out);
      client.print(rbled_out);
      client.print(uvled_out);
      client.print(rled_out);
    else if (atoi(inParse[1]) == 1) // mode = 1 to change values
      wled_out_temp = atoi(inParse[2]);
      bled_out_temp = atoi(inParse[3]);
      rbled_out_temp = atoi(inParse[4]);
      rled_out_temp = atoi(inParse[5]);
      uvled_out_temp = atoi(inParse[6]);
      web_teste = true;
      teste_led_millis = millis();
      teste_em_andamento = true;
    else if (atoi(inParse[1]) == 2)
      web_teste = false;
      teste_em_andamento = false;
    break;
  case 5:
    //  Send{case, mode, color, first position}
      client.print(F("{\"value0\":"));
      for(byte i = 1 + atoi(inParse[3]); i < 9 + atoi(inParse[3]); i++)
        client.print(cor[atoi(inParse[2])][i - 1]);
        if(i < 8 + atoi(inParse[3]))
          client.print(",\"value" + String(i - atoi(inParse[3])) + "\":");
    else if (atoi(inParse[1]) == 1) // mode = 1 to save values temporarily
      for (int i = atoi(inParse[3]); i < atoi(inParse[3]) + 8; i++)
        cont++;
        cor[atoi(inParse[2])][i] = atoi(inParse[3 + cont]);
    else if (atoi(inParse[1]) == 2) // mode = 2 to save values to eeprom
      SaveLEDToEEPROM();
    else if (atoi(inParse[1]) == 3) // mode = 3 to discard values
      ReadFromEEPROM();
    break;
  case 6: //moonlight
    //  Send{case, mode, value}
      client.print(F("{\"min\":"));
      client.print(MinI);
      client.print(F(",\"max\":"));
      client.print(MaxI);
      MinI = atoi(inParse[2]);
      MaxI = atoi(inParse[3]);
      Salvar_luz_noturna_EEPROM();
    break;
  case 7: //fan led
      client.print(F("{\"minfan\":"));
      client.print(HtempMin);
      client.print(F(",\"maxfan\":"));
      client.print(HtempMax);
      HtempMin = atof(inParse[2]);
      HtempMax = atof(inParse[3]);
      salvar_coolersEEPROM();
    break;
  case 8: //reduce led power
      client.print(F("{\"templimit\":"));
      client.print(tempHR);
      client.print(F(",\"potred\":"));
      client.print(potR);
      tempHR = atoi(inParse[2]);
      potR = atoi(inParse[3]);
      salvar_tempPotEEPROM();
    break;
  case 9: //water temperature control
      client.print(F("{\"setTemp\":"));
      client.print(setTempC);
      client.print(F(",\"offTemp\":"));
      client.print(offTempC);
      client.print(F(",\"alarmTemp\":"));
      client.print(alarmTempC);
      setTempC = atof(inParse[2]);
      offTempC = atof(inParse[3]);
      alarmTempC = atof(inParse[4]);
      SaveTempToEEPROM();
    break;
  case 10:// dosage manual
    // send (case, dosing pump selected, dose)
    dosadora_selecionada = atoi(inParse[1]);
    tempo_dosagem = map ((atof(inParse[2])*2), 0, fator_calib_dosadora_e[dosadora_selecionada], 0, 60000);
    tempo_dosagem /= 2;
    web_dosage = true;
    client.print("{\"wait\":" + String((tempo_dosagem / 1000) + 10) + "}");
    millis_dosagem = millis();
    break;
  case 11:// Calibration
    if(atoi(inParse[1]) == 0)// send (case, mode, dosing pump selected)
      dosadora_selecionada = atoi(inParse[2]);
      config_valores_calib_temp();
      client.print(F("{\"calib\":"));
      client.print(fator_calib_dosadora[dosadora_selecionada]);
    else if(atoi(inParse[1]) == 1)// send (case, mode, dosing pump selected) mode = 1 to dose
      client.print(F("{\"wait\":70}"));
      web_calibracao = true;
    else if(atoi(inParse[1]) == 2)// send (case, mode, dosing pump selected, factor of calibration) mode = 2 to save
      fator_calib_dosadora[dosadora_selecionada] = atof(inParse[3]);
      for(byte i = 0; i < 6; i++)
        fator_calib_dosadora_e[i] = fator_calib_dosadora[i];
      Salvar_calib_dosadora_EEPROM();
    break;
  case 12:
    if(atoi(inParse[1]) == 0) // Send (case, mode, dosing pump selected)
      config_valores_dosadoras_temp();
      config_valores_dosadoras_temp2();
      client.print(F("{\"hStart\":"));
      client.print(hora_inicial_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"mStart\":"));
      client.print(minuto_inicial_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"hEnd\":"));
      client.print(hora_final_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"mEnd\":"));
      client.print(minuto_final_dosagem_personalizada[dosadora_selecionada]);
      client.print(segunda_dosagem_personalizada[dosadora_selecionada]);
      client.print(terca_dosagem_personalizada[dosadora_selecionada]);
      client.print(quarta_dosagem_personalizada[dosadora_selecionada]);
      client.print(quinta_dosagem_personalizada[dosadora_selecionada]);
      client.print(sexta_dosagem_personalizada[dosadora_selecionada]);
      client.print(sabado_dosagem_personalizada[dosadora_selecionada]);
      client.print(domingo_dosagem_personalizada[dosadora_selecionada]);
      client.print(F(",\"quantity\":"));
      client.print(quantidade_dose_dosadora_personalizada[dosadora_selecionada]);
      client.print(F(",\"dose\":"));
      client.print(dose_dosadora_personalizada[dosadora_selecionada]);
      client.print(F(",\"onoff\":"));
      client.print(modo_personalizado_on[dosadora_selecionada]);
    else if(atoi(inParse[1]) == 1) // Send (case, mode, dosing pump selected, values)
      hora_inicial_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[3]);
      minuto_inicial_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[4]);
      hora_final_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[5]);
      minuto_final_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[6]);
      segunda_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[7]);
      terca_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[8]);
      quarta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[9]);
      quinta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[10]);
      sexta_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[11]);
      sabado_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[12]);
      domingo_dosagem_personalizada[dosadora_selecionada] = atoi(inParse[13]);
      quantidade_dose_dosadora_personalizada[dosadora_selecionada] = atoi(inParse[14]);
      dose_dosadora_personalizada[dosadora_selecionada] = atof(inParse[15]);
      modo_personalizado_on[dosadora_selecionada] = atoi(inParse[16]);
      config_valores_salvar_dosadoras();
      criar_arquivos();
      Salvar_dosadora_EEPROM();
    break;
  case 13: //PH control
      client.print(F("{\"setPHA\":"));
      client.print(setPHA);
      client.print(F(",\"offPHA\":"));
      client.print(offPHA);
      client.print(F(",\"alarmPHA\":"));
      client.print(alarmPHA);
      setPHA = atof(inParse[2]);
      offPHA = atof(inParse[3]);
      alarmPHA = atof(inParse[4]);
      SavePHAToEEPROM();
    break;
  case 14: // Calcium Reactor PH control
      client.print(F("{\"setPHR\":"));
      client.print(setPHR);
      client.print(F(",\"offPHR\":"));
      client.print(offPHR);
      client.print(F(",\"alarmPHR\":"));
      client.print(alarmPHR);
      setPHR = atof(inParse[2]);
      offPHR = atof(inParse[3]);
      alarmPHR = atof(inParse[4]);
      SavePHRToEEPROM();
    break;
  case 15: // ORP control
      client.print(F("{\"setORP\":"));
      client.print(setORP);
      client.print(F(",\"offORP\":"));
      client.print(offORP);
      client.print(F(",\"alarmORP\":"));
      client.print(alarmORP);
      setORP = atoi(inParse[2]);
      offORP = atoi(inParse[3]);
      alarmORP = atoi(inParse[4]);
      SaveORPToEEPROM();
    break;
  case 16: // Density control
      client.print(F("{\"setDEN\":"));
      client.print(setDEN);
      client.print(F(",\"offDEN\":"));
      client.print(offDEN);
      client.print(F(",\"alarmDEN\":"));
      client.print(alarmDEN);
      setDEN = atoi(inParse[2]);
      offDEN = atoi(inParse[3]);
      alarmDEN = atoi(inParse[4]);
      SaveDENToEEPROM();
    break;
  case 17:
    break;
  case 18:// Timers
    if(atoi(inParse[1]) == 0)// send (case, mode, timer selec.)
      temporizador = atoi(inParse[2]);
      config_valores_timers_temp();
      client.print(on_hora[temporizador]);
      client.print(on_minuto[temporizador]);
      client.print(off_hora[temporizador]);
      client.print(off_minuto[temporizador]);
      client.print(F(",\"activated\":"));
      client.print(temporizador_ativado[temporizador]);
    else if(atoi(inParse[1]) == 1)// send (case, mode, timer selected, values) mode = 1 to save
      web_timer = true;
      on_hora[temporizador] = atoi(inParse[3]);
      on_minuto[temporizador] = atoi(inParse[4]);
      off_hora[temporizador] = atoi(inParse[5]);
      off_minuto[temporizador] = atoi(inParse[6]);
      temporizador_ativado[temporizador] = atoi(inParse[7]);
      config_valores_salvar_timers();
      salvar_timers_EEPROM();
      bitWrite(temporizador_modificado,(temporizador + 1),1);
    break;
void dosagem_manual()
  digitalWrite(dosadora[dosadora_selecionada], HIGH);
  delay(tempo_dosagem);
  digitalWrite(dosadora[dosadora_selecionada], LOW);
void calibrar()
  delay(60000);
void enviar_dados()
  char dados[6];
  EthernetClient client;
  String OneString;
  int ContentLength = 0;
  OneString = Username;
  ContentLength += OneString.length();
  dtostrf(tempC,5,2,dados);
  OneString = String(dados);
  dtostrf(tempH,5,2,dados);
  dtostrf(tempA,5,2,dados);
  dtostrf(PHA,5,2,dados);
  dtostrf(PHR,5,2,dados);
  OneString = String(DEN);
  OneString = String(ORP);
  OneString = String(rtc.getTimeStamp());
  ContentLength += 140;
  Serial.println(F("Connecting..."));
  if (client.connect(joyreef, 80))
    Serial.println(F(">> Connected <<"));
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[0]))); // "POST /api/temp HTTP/1.1"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[1]))); // "Host: www.joy-reef.eu"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[2]))); // "Authorization: Basic "
    client.println(Auth1);
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[3]))); // "Cache-Control: no-cache"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[4]))); // "Content-Type: application/x-www-form-urlencoded"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[5]))); // "Connection: close"
    strcpy_P(buffer, (char*)pgm_read_word_near(&(tabela_strings[6]))); // "Content-Length: "
    client.println(ContentLength);
    client.println();
    client.print(F("{\"userName\":\""));
    client.print(Username);
    client.print(F("\",\"minute\":\""));
    client.print(F("\",\"A\":")); // Temp. da água
    client.print(dtostrf(tempC,5,2,dados));
    client.print(F(",\"B\":")); // Temp. dissipador
    client.print(dtostrf(tempH,5,2,dados));
    client.print(F(",\"C\":")); // Temp. ambiente
    client.print(dtostrf(tempA,5,2,dados));
    client.print(F(",\"D\":")); // PH do aquário
    client.print(dtostrf(PHA,4,2,dados));
    client.print(F(",\"E\":")); // PH do reator de cálcio
    client.print(dtostrf(PHR,4,2,dados));
    client.print(F(",\"F\":")); // Densidade
    client.print(DEN);
    client.print(F(",\"G\":")); // ORP
    client.print(ORP);
    client.print(F(",\"H\":")); // Status chiller, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,0));
    client.print(F(",\"I\":")); // Status aquecedor, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,1));
    client.print(F(",\"J\":")); // Status reator de cálcio, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,5));
    client.print(F(",\"K\":")); // Status ozonizador, 0 = desligado e 1 = ligado
    client.print(bitRead(status_parametros,7));
    client.print(F(",\"L\":")); // Status reposição de água doce, 0 = desligado e 1 = ligado
    client.print(bitRead(Status,1));
    client.print(F(",\"M\":")); // Status niveis, 0 = baixo e 1 = normal
    client.print(nivel_status);
    client.print(F(",\"N\":")); // Status TPA, 0 = desligado e 1 = ligado
    client.print(bitRead(tpa_status,0));
    client.print(F(",\"O\":"));
    client.print(bitRead(temporizador_status,1)); // Status timer 1, 0 = desligado e 1 = ligado
    client.print(F(",\"P\":"));
    client.print(bitRead(temporizador_status,2)); // Status timer 2, 0 = desligado e 1 = ligado
    client.print(F(",\"Q\":"));
    client.print(bitRead(temporizador_status,3)); // Status timer 3, 0 = desligado e 1 = ligado
    client.print(F(",\"R\":"));
    client.print(bitRead(temporizador_status,4)); // Status timer 4, 0 = desligado e 1 = ligado
    client.print(F(",\"S\":"));
    client.print(bitRead(temporizador_status,5)); // Status timer 5, 0 = desligado e 1 = ligado
    client.print(F(",\"T\":")); // Sinaliza falha na TPA
    delay(5);
    client.stop();
    Serial.println(F("Can't connect!"));
Post Number:#280 Post Tue Nov 24, 2015 11:42 pm
so all of the sudden ferduino started working again, all I can figure is me wall wart power is too much at 7 volts and 2 amps but on 6 volt setting is running well and working with joy reef. :D
Time to calibrate the probes and get it back on the tank to test ISO in real time. Again thank you for your help Fernando.
Users viewing this topic: No registered users and 6 guests
