Forum Members section Show your controller Franks Controller
Franks Controller
Post Number:#1 Post Wed May 21, 2014 10:24 am
Getting ready to do my own build - I loved the jarduino controller, but thought it had some shortcoming (no Ethernet and delayed development) and the I found Willies poet of reefcentral.
I've just ordered the basics to get started - hopefully they'll be there this weekend.
Has anyone seen or tried this shield yet? http://shop.aqualed-light.com/product_i ... ucts_id=34
It looks like it'll cut down on a couple of shield, and then it has the screw terminals to make things easier.
One big thing I haven't decided on yet is my LEDs - I have a bio cube 29, and am thinking of having a custom aluminum PCB cut for the lighting.
Post Number:#2 Post Wed May 21, 2014 10:57 am
Welcome Frank!
You can use this shield.
Here have an example of the ferduino working with it.
Looking to the manual you'll notice that the touch use the pins A8 until A12.
http://shop.aqualed-light.com/images/Du ... _UG_V2.pdf
Ie you win PWM pins but lose analog pins.
Will still remain the A0 until A7 and A13 until A15 pins.
You'll win the PWM pins 2 until 6.
You'll have to change some pins in the code.
Post Number:#3 Post Thu May 22, 2014 9:59 pm
hello Frank, welcome aboard,
you heard it from the master, that shield will work, just needs a few tweaks, if you noticed with my build, I had to remove some pins on the LCD/TFT shield so to remove the conflicts with the on-board SD card reader on the LCD/TFT board,
the Ferduino code uses the SD card reader on the Ethernet shield, if the SD card reader on the LCD/TFT shield is left connected, it will cause issues :)
Post Number:#4 Post Tue May 27, 2014 5:27 pm
Thanks all!!
Most parts are in, but, some eBay seller sent me the wrong TFT shield, so, I don't think I can try things out yet. I am pretty sure this one doesn't have the right pins for me to work with - or is going to require so much hacking up of the code its going to be a pain.
https://i565.photobucket.com/albums/ss9 ... 00AC49.jpg
Post Number:#5 Post Tue May 27, 2014 6:09 pm
Frank, your link is wrong.
Post Number:#6 Post Tue May 27, 2014 6:56 pm
I will have to fix at home - Photobucket + work don't seem to get along very well, its a smaller 1/2 size shield from ElecFreaks rather than the full size one.
Basically, I ordered http://imall.iteadstudio.com/developmen ... 17024.html but received http://imall.iteadstudio.com/im120417008.html
Post Number:#7 Post Tue May 27, 2014 7:16 pm
This model is to Arduino Uno.
You bought the shield of the first post?
Post Number:#8 Post Tue May 27, 2014 7:51 pm
Image: http://imall.iteadstudio.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/im120417008_8.jpg
Correct - I ordered this - having trouble posting image links due to 600x800 size restriction.
Post Number:#9 Post Tue May 27, 2014 8:17 pm
Use this tool to put image up to 1280 x 1024.
You bought this shield?
Arduino Due / Mega Screw Shield with TFT connector & RTC
Post Number:#10 Post Wed May 28, 2014 1:36 am
Not yet - I wanted to get the basic one first to play around, then when I was ready to order the screw shield (its not cheap!) I am still in the process of setting up a new tank (livestock goal for late October)
I'm kind of annoyed at it - but - not much I can do now. I did get the Ethernet shield, so, I may get that hooked up and running and see if I can go in a back way without the LCD attached.
Post Number:#11 Post Wed May 28, 2014 11:06 am
I'm asking because if you have this shield no need of TFT shield.
Why not buy the kit v1.1 with RTC?
Post Number:#12 Post Fri May 30, 2014 2:44 am
Still working along.
No LCD screen yet - it may be in tommorow, but, by soldering onto the bottom of the mega, I've been able to get the system "up" and running and communicating with Joy-Web which is great!
No temperatures yet - was unable to figure out the code on where to make changes to force in the addresses for the probes, but, they are properly detected with the dallas temperature tester.
Post Number:#13 Post Sat May 31, 2014 6:52 am
Things are starting to look good!
All menus in F instead of C now, renamed a few things to my own liking as far as menu options. Currently I do not have a RTC, and trying to figure out what I want to do as far as that.
If I can find some scrap unetched PCB around, I'll probably make a SSR board - I've got 200-300 triacs + optoisolators in a bin that I can use, or use some existing SSRs packs I already have.
I'm not really a programmer, but, I have a sense of how it works - and now that I've been playing around a bit - the layout of the code is starting to make sense.
This is the setup with two probes - I haven't yet hooked up the third.
Post Number:#14 Post Sat May 31, 2014 9:46 am
Cool!
The code was made to be easy of customize.
Post Number:#15 Post Mon Jun 02, 2014 1:53 am
Last two major pieces are on order.
Ended up just ordering a basic screw shield from a US based seller, no built in RTC or TFT shield, but, I won't have to wait a month to get it from out of state.
Once that's received, I can dig out my old puck SSR relays that I have for the timers (how nice that I actually have 5 of them!!)
Also ordered a RTC shield, and two 38v to 5-36v buck adapters for 5v and 12v use. No immediate need, so they are coming this way from China.
Post Number:#16 Post Mon Jun 02, 2014 9:32 am
Your link to the image is wrong.
Post Number:#17 Post Mon Jun 02, 2014 5:56 pm
Post Number:#18 Post Mon Jun 02, 2014 8:07 pm
You can insert the image using the tool that I showed on post #9 or using the tag [img=left].
On this case the crossroadsfencing is blocking the use of the image.
This shield also serves.
Post Number:#19 Post Wed Jun 04, 2014 1:26 am
You can insert the image using the tool that I showed on post #9 or using the tag Image: .
After doing the insert using the tool - throws the error of image size for me - its limiting me to a max resolution of 800x600 - if you want to allow larger its something due to a setup issue on the forum (I've run and setup several in the past, including with as many as 10,000 users.)
Post Number:#20 Post Wed Jun 04, 2014 8:42 am
You chose the option "left"?
I have the size limited to the tag [img] because is annoying see an image higher than my monitor.
Here have an example: http://www.brasilreef.com/viewtopic.php ... &view=next
This image have 2592 x 1944.
http://img11.imageshack.us/img11/9558/foto0099i.jpg
Users viewing this topic: No registered users and 5 guests
