Forum Members section DIY Ferduino controller Ethernet module
Ethernet module  [SOLVED]
Post Number:#1 Post Sun Sep 25, 2016 5:59 pm
Topics: 22
Topics: 22
Hello
I want to connect this network adapter like this
I can not understand where to connect the pin SS in the arduino mega
Post Number:#2 Post Sun Sep 25, 2016 6:06 pm
SS is Select Slave goes to pin 53.
Post Number:#3 Post Mon Sep 26, 2016 8:44 am
Topics: 22
Topics: 22
but the 53-pin I am using it for the sd card
I could use a more different pin?
Post Number:#4 Post Mon Sep 26, 2016 10:26 am
The SD card SHOULD be connected on pin 4 as explained in many topics here.
viewtopic.php?f=24&t=41
Post Number:#5 Post Tue Sep 27, 2016 8:50 am
Topics: 22
Topics: 22
OK, fine
but it would be possible to use another pin for the network card?
and leave the pin 53 for the sd card?
Post Number:#6 Post Tue Sep 27, 2016 1:10 pm
In fact is possible changing the code.
Use the pin 4 for SS because it can work in parallel with touch screen so, you will save a pin to another function.
In Ferduino tab, if do you have this variable uncommented:
USE_PIN_53_FOR_SD_CARD
Only check if your code is like this:
#ifdef USE_PIN_53_FOR_SD_CARD
const byte SelectSlave_ETH = 4;
If your version haven't the lines above change your code to:
const byte ChipSelect_SD = 53;
Keeping the pins according to default code helps to upgrade when a new version is available. For it I told to connect the SD card to pin 4 and ethernet to pin 53.
Post Number:#7 Post Tue Sep 27, 2016 4:28 pm
Topics: 22
Topics: 22
so if instead of pin 4 in the Select Slave ETH you can for example use a free pin right?
const byte SelectSlave_ETH = (pin free);
thank you
Post Number:#8 Post Tue Sep 27, 2016 4:34 pm
Yes, it's right but you will lose a pin that can be used to another function as I told.
Post Number:#9 Post Wed Sep 28, 2016 8:50 am
Topics: 22
Topics: 22
This works because the ethernet library has been modified by you right?
because I have upgraded your library via IDE 1.6.9 and does not work anymore
if you get back your library back to work
Post Number:#10 Post Wed Sep 28, 2016 9:24 am
Yes, it's a custom library.
Post Number:#11 Post Sun Oct 16, 2016 11:42 am
Topics: 22
Topics: 22
connected all right but with the small network adapter gives me:
please insert a SD Card
if you put the shield network card works well doing same links them
Post Number:#12 Post Sun Oct 16, 2016 2:42 pm
Use the codes for test to make the ethernet module and SD card to work separatelly. Then the example "Simple Web server running on SD card".
Maybe is needed change the speed on setup.
while (!SD.begin(ChipSelect_SD, SPI_HALF_SPEED))
Post Number:#13 Post Sun Oct 16, 2016 4:30 pm
Topics: 22
Topics: 22
I found this article on the internet could be the problem that this network module does not work with the sd card
https://www.itead.cc/blog/how-to-make-w5100-module-work-with-sd-card-module
Post Number:#14 Post Fri Oct 21, 2016 5:59 pm
Topics: 22
Topics: 22
It could be the problem ????
Post Number:#15 Post Sat Oct 22, 2016 9:52 am
Can you make the tests suggested above and show me results first please?
