Level sensor *:
Dosing pump *:
PH, ORP and EC *:
Buzzer *:
Jebao pump:
Cut only the wire yellow/green of your Jebao controller and put a switch of 3 poles as shown in the image below.
Stripping the wire - 24V and join with GND from arduino.
The result should be something as:
If do you want buy pumps without controller make a board like this:
Here you can find the cable with waterproof connector for Jebao pumps.
LED using a MOSFET:
PCF8575 *:
Fan:
WIFI module *:
* Turn your life easy, buy Ferduino Mega 2560 and forget all this.
