Forum Members section DIY Ferduino controller PCF8574 to expand output
Post Number:#1 Post Sat Sep 20, 2014 12:05 pm
I'm working on a compact aquarium controller with Ferduino software. I've made a board with 8 solid state relay (Triac BTA12 and MOC3043M) all controlled by a PCF8574.
Can I use this expander with Ferduino to replace PCF8575 (with all the changes that are needed)?
Can you suggest me the best way to change it? With PCF8574 outputs I'll control the heater, the chiller and some other things with the timers integrated in the software.
Also can I use the same I2C bus (SDA pin 20 - SCL pin 21)for both DS1307 RTC and PCF8574?
Thank you very much
Simone
Post Number:#2 Post Sat Sep 20, 2014 12:42 pm
Yes, use this library.
Look to this examples:
https://github.com/skywodd/pcf8574_ardu ... nBlink.ino
viewtopic.php?p=346#p346
Maybe you can find some answers using the search.
http://ferduino.com/forum/viewtopic.php ... c+i2c#p143
http://ferduino.com/forum/viewtopic.php ... c+i2c#p516
Post Number:#3 Post Mon Mar 02, 2015 9:01 am
thank you very much for your answer!
I'm trying the library that you've suggested me; How can I change the pin where I'll connect the expander? maybe I'll connect the PCF8574 to the pin 18 - 19
Thank you very much again
Simone
Post Number:#4 Post Mon Mar 02, 2015 9:22 am
This is impossible. Use pins 20 and 21.
Post Number:#5 Post Mon Mar 02, 2015 4:28 pm
So, how can I move (directly inside of the library if it is possible) the pin of the RTC?
P.S. I'm also having some problems with the example code of the PCF8574 library; I can't compile it with the arduino IDE...
