Forum Members section DIY Ferduino controller Fan controller Question
Fan controller Question  [SOLVED]
Post Number:#1 Post Fri Sep 26, 2014 4:23 pm
Hi guys,
I have a question for a controller fan:
I'm riding the circuit for fan / heatsink and the information in Fernando topic that contains the circuitry shows a fan (PWM) 4-pin. I already have 2 12v 3pin fan aerocool shark, I can use or do I have to buy another fan of being 4 pin?
if I may use the aerocool which the modification I have to do in the circuit?
Thx
Post Number:#2 Post Fri Sep 26, 2014 4:29 pm
I may be wrong, but the circuit uses 2 pins, 1 to turn the fan on and off, and 1 to control pwm speed. If you don't connect the pwm pin, it should still turn your fans on full speed and off, it just won't control the speed. No modification is then needed to the code.
Fernando should be able to confirm.
Post Number:#3 Post Fri Sep 26, 2014 4:32 pm
Guy, you're right.
Post Number:#4 Post Fri Sep 26, 2014 4:49 pm
HI!
thanks for the reply!
