I think I have established, that if I use the W5100, then I need to connect VCC, GND, and ICSP pins. Then I use the SPI.h and Ethernet.h libraries.
I can only get these ethernet shields.
Network Ethernet Lan Shield Module Board W5100
Does anybody know if this is correct for these shields, it is not acceptable to fit this shield to the Mega.
I would like to wire up remotely, do I just wire the ICSP header for ethernet?
If this is correct, then what about SD, is this also on SPI, or does it use other pins?
Any help would be great. Thanks.
Jamie.
