Forum Members section DIY Ferduino controller PCF8575 and ULN2803
PCF8575 and ULN2803  [SOLVED]
Post Number:#1 Post Wed Nov 26, 2014 12:22 pm
Belgium
Hello Fernando,
I am using PCF8575(sparkfun breakout board) with ULN2803.
My config is as follow:
PCF8575
SDA > pin 20 (I did not use resistor because I have supposed that they are on the breakout board (R1,R2,R3))
SCL >pin 21 (same remark)
Gnd > Gnd Arduino
VCC >+5 Arduino
A0,A1,A2 > Gnd (weld between central pad and right pad (at the back of the breakout board )
P00-P05 > PIN 1-5 ULN2803
ULN2803
Pin 1-5 > P00-P05 PCF8575
Pin 9 > Gnd Arduino
Voltage check on output pin PCF8575(P00-P05) gives 4.82 (timer ON) or 0V (timer OFF).
Regarding those values,I can suppose that my PCF8575 is working properly.
My problem is that once I connect P00-P05 to pin 1-5 of the ULN2803,voltage drops to 1.7 V on input pin ULN2803 and to 0.44V on output pin (voltage drop between input and output is correct I think) but why does the voltage drops to 1.7V on input pin with the consequence that it's not possible to trigger a relay with 0.44V on output.
Could you please help me
Once again thank you very much for your help and for the superb project that you offer to us
Jean-Yves
Post Number:#2 Post Wed Nov 26, 2014 1:27 pm
If your module is like this:
Exists only the pads to resistors. Need add resistors of 10 K.
When the ULN is connected is normal have 1.5 - 1.7 V.
What's the model of your relay board?
It have inverted logic, I mean turn on with LOW and turn off with HIGH signal?
Post Number:#3 Post Wed Nov 26, 2014 2:37 pm
Belgium
Hello again Fernando,
This is well the board that I use.
Following your answer, I have added 2 10K resistors.
This is the link to my relay board.
http://www.ebay.com/itm/8-Channel-5V-Re ... 1317483666.
May be my problem comes from the way to connect this relay board.
Thanks again
Jean-Yves
Post Number:#4 Post Wed Nov 26, 2014 3:09 pm
You can test it connecting IN1 - IN8 directly to GND.
Check if the jumper is in right position (JD-VCC / VCC) .
Here's the basic circuit for this board.
Moreover for this quantity of relays I think better use an external power supply connected between JD-VCC and GND.
Post Number:#5 Post Wed Nov 26, 2014 3:31 pm
Belgium
Thank you Fernando,
Just finished rewiring my breadboard using opto-isolation for Arduino and an external power source connected to Gnd and JD-VCC.
Everything works fine.
I can now continue the design of my PCB ( I test each part of ferduino separetly on a breadboard and if it's OK I convert it to my PCB project).
Thanks again
Jean-Yves
Post Number:#6 Post Wed Nov 26, 2014 3:39 pm
Users viewing this topic: Bing [Bot] and 1 guest
