Forum Members section DIY Ferduino controller Problem with fan
Problem with fan  [SOLVED]
Post Number:#1 Post Fri Jan 16, 2015 2:14 pm
Hi Fernando, I have a problem with my fans .
As you explain in your website, I have connect two fans F12 Arctic Cooling at one transistor ULN2003A using the blu wire, but I have a problem: If the tempetarure of led is low under 35C the fans run at maximum and if the temperature is hight over 45 C the fans stopped. What is wrong?
Post Number:#2 Post Fri Jan 16, 2015 2:38 pm
Which arduino pin is connected on ULN?
In the tab Ferduino change:
byte fanSpeed = 0;         // PWM dos coolers
int fanSpeed = 0;         // PWM dos coolers
Post Number:#3 Post Fri Jan 16, 2015 2:41 pm
I use pin 1 And pin 13
Post Number:#4 Post Fri Jan 16, 2015 2:45 pm
Pin 1 to ULN and pin 13 to blue wire?
What's settings for fans (min. and max)?
Have you removed Serial.begin(38400) on setup()?
Post Number:#5 Post Fri Jan 16, 2015 4:14 pm
Yes pin 1 ULN and pin 13 blu wire of fan.
Setting 30.5 and 40.5
I have not the Serial.begin(38400) on Setup
In my tab there are not :
Or
But only these:
//************************ Variáveis de controle de velocidade dos coolers ****************
float HtempMin = 30.5;    // Declara a temperatura para iniciar o funcionamento das ventoinhas do dissipador
float HtempMax = 40.5;    // Declara que as ventoinhas devem estar em sua velocidade máxima quando o dissipador estiver com 40°c
//************** Variáveis temperárias de controle de velocidade dos coolers **************
float HtempMin_temp = 0;    // Declara a temperatura para iniciar o funcionamento das ventoinhas do dissipador
float HtempMax_temp = 0;    // Declara que as ventoinhas devem estar em sua velocidade máxima quando o dissipador estiver com 40°c
I must write it?
Last edited by Fernando Garcia on Fri Jan 16, 2015 4:45 pm, edited 1 time in total.
Reason: Please use tags [code] [/code] to post any code here.
Post Number:#6 Post Fri Jan 16, 2015 4:58 pm
So you haven't the latest version.
No need add this variable.
You did some change in the tab "parametros"?
Check if is of this way:
  int tempval = int(tempH * 10);
  int fanSpeed = map(tempval, (HtempMin * 10), (HtempMax * 10), 0, 255);       // Controle de velocidade das ventoinhas do dissipador
  if (fanSpeed < 0)
    fanSpeed = 0;
  if (fanSpeed > 255)
    fanSpeed = 255;
  analogWrite(fanPin, fanSpeed);
  if(tempH < HtempMin) // Desativa os coolers se a temperatura estive abaixo da mínima definida.
    digitalWrite(desativarFanPin, LOW);
    digitalWrite(desativarFanPin, HIGH);
You need check the behaviour of your fan manually, connecting directly on 12V and see what's the speed when blue wire is connected on 5V and GND.
Post Number:#7 Post Sat Jan 17, 2015 4:37 pm
Solved, i have changed as the following:
  if (fanSpeed < 0)
    fanSpeed = 255; //it Was 0
  if (fanSpeed > 255)
    fanSpeed = 0; //it Was 255
Post Number:#8 Post Sat Jan 17, 2015 5:37 pm
Thank you very much for your help.
[Ironic mode]
