Forum Members section DIY Ferduino controller Temperature always show 85 degrees
Temperature always show 85 degrees  [SOLVED]
Post Number:#1 Post Wed Apr 27, 2016 2:55 am
hello all, anybody ever had a problem of temperature sensor always show the number 85 degree Celsius.
I had the problem the temperature sensors show the number 85 degrees celsius.
first connect it to the power of temperature indicate normal, after a few minutes behind the numbers to 85 degrees, 3 sensor the problem same.
where I had to check. in code or in hardware
when the check using "code for test" test results same
I use ferduino English version.
thanks
Post Number:#2 Post Wed Apr 27, 2016 12:53 pm
85°C is an error code, check the circuit.
What's the cable length of your sensor?
Post Number:#3 Post Thu Apr 28, 2016 4:19 am
thanks fernando for the answer.
cable length of 1 meter,
What there is a possibility of conflict with the other?
ok i try to check the circuit.
Post Number:#4 Post Sat May 07, 2016 4:00 pm
No, can be voltage so much smaller than 5V or electric noise.
Post Number:#5 Post Tue May 17, 2016 2:40 am
problem solved,
after I check, it turns out there is a path short, Ground and data.
thanks fernando :-bd
