Forum Members section DIY Ferduino controller Add WiFi with less than $5
Post Number:#1 Post Fri Dec 16, 2016 7:59 am
I'm happy to say now is possible add WIFI to your DIY controller with less than $5.
For it is needed a NodeMCU and a logic level shifter because it works with 3.3V.
I'm using a NodeMCU V3 because it has an ESP-12 and USB interface built-in and it's very cheap.
Parts:
1 x NodeMCU V3 ;
1 x Logic level shifter 5 to 3.3 V
Wiring:
See the video to learn how to set up the MQTT client.
Warning: Don't forget to turn off the UART debug log in ESP-link interface.
Enjoy! :)
PS. Any model of ESP8266 supported by ESP-link can be used but please do not ask me how to make the wiring to change the firmware.
Post Number:#2 Post Wed Jun 09, 2021 4:32 pm
I found a better way to add WiFi to Ferduino. This is not a $5 solution but at least no soldering is required and the build will be more clean.
This board by RobotDyn has built-in an ESP8266.
You can follow the video above, you have just to set the dip switches in right position to each situation.
To upload the firmware (ESP-link) to ESP8266:
Switches 1, 2, 3 and 4 = OFF
Switches 5, 6 and 7 = ON
Switch 8 is not used!
To see the debug messages from ESP8266 serial port:
Switches 1, 2, 3, 4 and 7= OFF
Switches 5 and 6 = ON
To upload upload sketch (Ferduino or test codes) to ATmega2560:
Switches 1, 2, 5, 6 and 7= OFF
Switches 3 and 4 = ON
To see debug messages from ATmega2560 serial port:
To enable communication between ATmega2560 and ESP8266 after install Ferduino (or test code) and ESP-link.
Switches 3, 4, 5, 6 and 7= OFF
Switches 1 and 2 = ON
The Ferduino (and test code) is using the Serial 3 to communication between ESP8266 and ATmega2560 so you should place the smaller switch to position TXD3/RXD3.
Since Serial3 now is used for ESP8266 so Serial1 should be used for stamps.
To use this RobotDyn board you should download the branch RobotDyn_Mega_WiFi available here.
Enjoy!
P.S. I haven't RobotDyn board so if there's some error in my instructions let me know.
