using teh code Ferduino_with_webcontrol_beta-máster
i notice that sometimes the screen blocks for almost 20 seconds´
my connections
plug the ethernet making bridge pin 10 to pin 53
disconected pin 10, 11, 12 ,13
conected only the necessary
make a bridge pin 4 to resistor R 16 and disconect one side of it
disconect pin 50, 51, 52, 53 of tft shield
so i decided to test all codes
having problem when testing code onde by on on sketchbook
tft and touch = the touch scrren didn´t work
utouch calibration = the touch scrren didn´t work
simple webserver running on sd card = message on serial monitor= sdcard initialization failed
i have already tried to remove sd card or use it, search in the fóruns but does´t find the solution...
