Forum Members section LED light and others 5 channel Multichip full spectrum LED help
5 channel Multichip full spectrum LED help  [SOLVED]
Post Number:#21 Post Fri Jan 06, 2017 4:54 pm
Images: 13
Greece
I finally decided to go with this driver. If i decide to add one more led, i can do it right?
Is there so much difference from 500h ldd?
Some quick questions:
I have the following arduino hardware:
1. Arduino Compatible Atmega2560-16AU CH340G ATMEGA 2560 R3 Board Mega2560 R3
2. http://www.ebay.com/itm/121114423145
3. http://www.ebay.com/itm/311519653531
4. http://www.ebay.com/itm/142087550541
5. http://www.ebay.com/itm/331799616470
6. http://www.ebay.com/itm/262423841770
7. http://www.ebay.com/itm/361742868985
Do i need something exta?
Post Number:#22 Post Fri Jan 06, 2017 5:36 pm
Using the maximum current the life time of your LED will be smaller as I told before.
Only this parts can be used, all others except Arduino are incompatible with Ferduino code.
Maybe you can use this TFT shield with an external RTC but I think better buy and assembly a kit with RTC.
Please check my part list.
viewtopic.php?f=24&t=39
Post Number:#23 Post Fri Jan 06, 2017 6:04 pm
Images: 13
Greece
So Only for lighting (for start) what extra need to buy?
Post Number:#24 Post Fri Jan 06, 2017 7:00 pm
TFT + TFT shield with RTC.
Post Number:#25 Post Sat Jan 07, 2017 6:14 am
Images: 13
Greece
For lowering the cost, is it possible to use 4 5-ldd boards?
Post Number:#26 Post Sat Jan 07, 2017 7:38 am
In a board all V+ are linked so you will have to cut the trail of one LDD to connect 26V to channel 4 and solder the wire in the board.
-------------------------------- Last edited Sat Jan 07, 2017 9:01 am --------------------------------
Connecting the step down between the power supply and black connector all LDDs will work with 26V but you will need of 1 LDD working at 36V to complete 16 channels at 36V. For it will be needed cut the trail to connect 1 wire with 36V.
Post Number:#27 Post Tue Jan 10, 2017 7:23 am
Images: 13
Greece
I've ordered the leds and i'm searchimg for coolers. I saw this. The question is what pin size to choose?
Post Number:#28 Post Tue Jan 10, 2017 9:21 am
The Fans should have PWM control, normally have 4 wires.
I recommend buy fans from Arctic because are very quiet.
You can buy this model and replace the fans for this: https://www.arctic.ac/worldwide_en/arctic-f9-pwm.html
Or buy the kit from Arctic: https://www.arctic.ac/worldwide_en/acce ... -6990.html
Post Number:#29 Post Tue Jan 10, 2017 10:23 am
Images: 13
Greece
How about this?
Post Number:#30 Post Tue Jan 10, 2017 11:58 am
This heatsink is rated to 120W it could be enough but this surface to fix the LED seems not big enough. I can't see any dimension for it.
Post Number:#31 Post Wed Jan 11, 2017 8:28 am
Images: 13
Greece
Is necessary the PWM control for the fans? Can i use constant RPM?
Post Number:#32 Post Wed Jan 11, 2017 8:42 am
PWM control is optional.
Post Number:#33 Post Wed Jan 11, 2017 9:14 am
Images: 13
Greece
So i will order these with Standard 3 pin. Is there any aditional hardware i need to connect the fans?
Post Number:#34 Post Wed Jan 11, 2017 9:17 am
All informations needed are on forum, search a bit please.
Post Number:#35 Post Wed Jan 11, 2017 9:35 am
Images: 13
Greece
Sory.... but all those diagrams seems Greek to me!!!!! :ymblushing:
Post Number:#36 Post Wed Jan 11, 2017 9:56 am
So it's good should be VERY EASY for you.
Post Number:#37 Post Thu Jan 19, 2017 3:45 pm
Images: 13
Greece
I've finally ordered all the nessesary parts and i'm trying to figure out how to wire them. From what i can understand:
1. I have to connect each ldd Board whith the power supply. One channel must be wirred to step down regulator.
2. I have to wire all the ground signals from ldd boards in one wire and connect it to arduino's ground
3. I have to to wire the same colors from each led in one wire and connect it to each arduino's color signal.
It's a lttle bit confusing to me. Some suggest to put a 10k resistor in each color signal. I think tha i need a simple diagram, even handwritten. I suppose that i'll need to wire them in pcb Board cause i'll need the ground signal for the other functions.....
Post Number:#38 Post Thu Jan 19, 2017 4:41 pm
Not exactly, you can't connect 34 and 26 V to a board without cut PCB trace. As you can see in the image above there only one black connector to connect the power supply.
What you should make is use 1 LDD board to all channels 4 with step down between the black connector and power supply.
So will left 1 LDD in this board to connect a channel at 34V. As there no black connector for this you should cut the PCB trace that goes to V+ in this LDD and solder the wire with 34V directly on PCB.
Yes.
Yes, if you are talking about connect PWM signal from LDD board in parallel.
This resistor is called PULL DOWN but some LDD board have it in SMD on bottom side like this (R1 to R5):
You have to check in your LDD board.
If it haven't you can put the resistor next of Arduino PWM connector between GND and PWM pin. The schematic is like this:
Only to remember V-, GND and GROUND are same thing.
I'm sorry for my misunderstanding and bad words.
I have deleted the last two posts.
I hope see similar action from you.
We can keep talking about this build when you show me your Ferduino controller parts.
Users viewing this topic: No registered users and 7 guests
