Forum Software Web interface Web Control Problem
Web Control Problem  [SOLVED]
Place here your questions about the web interface.
Post Number:#1 Post Mon Nov 06, 2017 5:24 am
Images: 13
Greece
I reactivated today the Web Control but i have a problem. It is showing Error #28 almost all the time. The Web Control doesn't sent me message that my arduino does not sent data. The Water Temperature graph seems working cause i have graph but i can't control anything else. Is there something i have to check?
Best Regards.
Post Number:#2 Post Mon Nov 06, 2017 10:22 pm
Your controller is sending data but is not responding correctly to web requests.
Check on serial monitor if your controller is receiving a request like 0,0,K and if there an answer for this command.
I can't see any answer from your controller on server.
Post Number:#3 Post Wed Nov 08, 2017 12:02 am
Images: 13
Greece
My controller seems to send and receive data.The server keeps sending me notifications for controller status, but with a huge delay. I have occasional success after a lot of tries. It seems to me that the controller is delaying to respond. Is there a way to increase respond time?
Best Regards.
Post Number:#4 Post Thu Nov 09, 2017 8:53 pm
Did you some change on code or hardware since the last usage with web interface?
Post Number:#5 Post Thu Nov 09, 2017 9:25 pm
Images: 13
Greece
Hi.
I added four dosing pumps using pins 16,17,20,21. Pins 63, 64 assigned to multiplexadorS0Pin and multiplexadorS1Pin.
Best Regards.
Post Number:#6 Post Sat Nov 11, 2017 9:01 am
It can be electric noise on w5100. Try replace your power supply or ethernet shield.
Too check your ethernet cable.
Post Number:#7 Post Sat Nov 18, 2017 1:21 pm
This problem was solved?
What's the solution found?
Return to Web interface
