Forum Software Ferduino code Config_valores_s_temp was not declared in this scope
Config_valores_s_temp was not declared in this scope  [SOLVED]
Post Number:#1 Post Tue Mar 03, 2015 7:14 pm
Topics: 11
Topics: 11
I have been finalising my code and all was looking good, until 10 minutes later i changed something now it wont compile. I have no idea what it could have been, maybe a wrong press on the keyboard? I have tried google but cannot find anything.
Maybe you could help shed some light on it.
This is all the error message
Feduino_with_webcontrol_beta.ino:442:21: error: too many decimal points in number
L_Menus.ino: In function 'void config_(boolean)':
L_Menus:2427: error: 'config_valores_s_temp' was not declared in this scope
ProcessMyTouch.ino: In function 'void processMyTouch()':
ProcessMyTouch:3133: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3141: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3149: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3157: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3165: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3201: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3211: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3222: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3232: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3242: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3252: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3263: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3273: error: 'config_timer' was not declared in this scope
ProcessMyTouch:3286: error: 'config_timer' was not declared in this scope
If you can think of anything it would be appreciated :D
Last edited by Fernando Garcia on Tue Mar 03, 2015 7:25 pm, edited 1 time in total.
Reason: Please use tags [code][/code] to post codes here.
You need pay more attention.
First error: viewtopic.php?f=8&t=207&p=1388&hilit=too+many+decimal+points+in+number#p1388
This two lines seem related:
Maybe you are using " config_" instead "config_valores_s_temp".
https://github.com/FernandoGarcia/Fedui ... es.ino#L43
Have you deleted or renamed this menu?
https://github.com/FernandoGarcia/Fedui ... .ino#L2423
Post Number:#3 Post Tue Mar 03, 2015 8:02 pm
Topics: 11
Topics: 11
Thank you. I am too tired to be editing code i-) so I have not paid enough attention to what I was doing
I was looking for where to change the names of the timers using the search function and I think i replaced "timer" with ""
I have changed it to config_timer and config_valores_timers_temp, also changed the ip to commas doh! and now it all compiles.
Thank you again
