Forum Software Ferduino code Insert SD card - SPI_HALF_SPEED
Insert SD card - SPI_HALF_SPEED  [SOLVED]
Post Number:#1 Post Sat May 26, 2018 11:17 pm
Topics: 9
Topics: 9
Hello Fernando,
The message asking me to insert SD card is appearing for me, and I have already researched several solutions, I have already tried several cards and in different formats, I have already checked all the welds on the board with a multimeter and they are all right, as well as trying the solutions presented in this one. link: https://ferduino.com/forum/viewtopic.php?f=8&t=104.
So I was not able to do the presented solution of changing the SPI_HALF_SPEED to SPI_FULL_SPEED or SPI_QUARTER_SPEED, I already tried to search with ctrl + F in the Ferduino code, but I did not find this command, I think this was taken from the code, am I right?
Rômulo Queiroz
Post Number:#2 Post Sat May 26, 2018 11:30 pm
Search on setup.
Post Number:#3 Post Sun May 27, 2018 9:57 am
Topics: 9
Topics: 9
I change for SPI_QUARTER_SPEED and SPI_FULL_SPEED, but without sucess.
I've been studying the code and am in doubt regarding the code below:
//************************** Dispositivos SPI *********************************************
const byte SD_CARD = 0;
const byte ETHER_CARD = 1;
const byte RFM = 2;
#if defined USE_PIN_4_FOR_SD_CARD // Do not change this line
const byte ChipSelect_SD = 4; // Para cartão SD conectado no "ethernet shield".
#elif defined USE_PIN_53_FOR_SD_CARD // Do not change this line
const byte ChipSelect_SD = 53; // Para cartão SD conectado no TFT.
#else // Do not change this line
const byte ChipSelect_SD = 5; // Para o Ferduino Mega 2560
#endif // Do not change this line
#ifdef USE_PIN_53_FOR_SD_CARD // Do not change this line
const byte SelectSlave_ETH = 4;
const byte SelectSlave_ETH = 53;
Do I have to change anything in this code?
One more question:
Do you have complete circuit for SHIELD TFT ITDB02 MEGA SHIELD V. 1.1?
Rômulo.
Last edited by Fernando Garcia on Sun May 27, 2018 11:16 am, edited 1 time in total.
Reason: Please use tags [code][/code] to post any code here.
Post Number:#4 Post Sun May 27, 2018 11:18 am
Where your SD card is plugged? TFT or ethetnet shield?
Post Number:#5 Post Sun May 27, 2018 11:53 am
Topics: 9
Topics: 9
TFT, i don't have ethernet.
Post Number:#6 Post Sun May 27, 2018 12:09 pm
Uncomment this line:
//#define USE_PIN_53_FOR_SD_CARD // Descomente esta linha se você tem o cartão SD conectado no TFT.
Post Number:#7 Post Tue May 29, 2018 8:04 pm
Topics: 9
Topics: 9
Hello Fernando, Unfortunately, it did not work either.
Do you have circuit of TFT shield?
I'll have to do a fine check of all the pins. :D :D
Rômulo Queiroz
Post Number:#8 Post Tue May 29, 2018 9:30 pm
I haven't schematic for this shield.
Please show me some pictures of your TFT shield.
Also try make the SD card work with test code.
Post Number:#9 Post Thu May 31, 2018 3:29 pm
Topics: 9
Topics: 9
Below are the photos of my TFT shield.
I don't find test code for SD card...could I show me ?
Rômulo Queiroz
Post Number:#10 Post Thu May 31, 2018 5:25 pm
You has bad soldering is top right corner.
viewtopic.php?f=8&t=42
Post Number:#11 Post Thu May 31, 2018 9:51 pm
Topics: 9
Topics: 9
Fernando,
I have refaced the welds of the board but continue the same message of INSERT THE SD CARD.
As for the test code of the SD card appeared a white screen and did not give any result.
Now I'm lost, what can I do? I do not know what else to do.
Rômulo Queiroz
Post Number:#12 Post Thu May 31, 2018 10:07 pm
Open the serial monitor to see the result and set the right baud rate according to code setup.
Post Number:#13 Post Fri Jun 01, 2018 9:35 pm
Topics: 9
Topics: 9
I try all velocity, but nothing them done.
Seems like don't have comunication with SD card.
What can i do?
I think leave this project . ~x(
Post Number:#14 Post Fri Jun 01, 2018 10:21 pm
Some options for you:
1 - Try learn a bit and fix your code and hardware;
2 - Buy another TFT shield kit and ask to a professional assembly it for you and set up the code correctly;
3 - Buy an ethernet shield with SD card slot and set up the code correctly.
Post Number:#15 Post Thu Jun 14, 2018 10:54 am
Topics: 9
Topics: 9
Fernando, i have good news!
I change my TFT Shield from mega Shield v1.1 to mega Shield v2.2 and total sucess! Open start screen in First time.
I think my old TFT Shield have been problem.
Please close this Topic.
