Forum Software Ferduino code How to calibrate ph et orp probe
How to calibrate ph et orp probe  [SOLVED]
Post Number:#21 Post Mon Oct 20, 2014 5:31 pm
Try this:
Open_channel(ph1);
  delay(50);
  Serial3.print("R");
  Serial3.print('\r');
  delay(1000);
  Serial3.flush();
  Serial.println("Debug pH 1:");
    while(Serial3.available())
      Serial.print(char(Serial3.read()));
     Serial.println();
  Serial3.print("RESPONSE,0"); //  Disable "RESPONSE" code
  delay(1000);
  Serial.println("Debug pH 2:");
     Serial.println();
  Serial3.print("C,0"); // Envia um comando para que o "stamp" pare de enviar as leituras.
  delay(1000);
  Serial.println("Debug pH 3:");
     Serial.println();
  Serial3.print("L,1"); // Envia um comando para que o "stamp" apague o led de depuração.
  delay(1000);
  Serial.println("Debug pH 4:");
     Serial.println();
Post Number:#22 Post Mon Oct 20, 2014 5:45 pm
i receives that :
Debug pH 1:
*ER7.010
Debug pH 2:
Debug pH 3:
Debug pH 4:
Post Number:#23 Post Mon Oct 20, 2014 5:54 pm
It seems right now.
The first *ER is normal and you can see the result for "R" command after.
Post Number:#24 Post Mon Oct 20, 2014 6:22 pm
i have add debug :
 int i;
  do{
    Open_channel(ph1);
    Serial.println("Debug pH 5:");
    Serial.println();
    Serial3.print("R");
    delay(1000);
    Serial.println("Debug pH 6:");
     Serial.println();
    Serial3.print("R");
    delay(1000);
    Serial.println("Debug pH 7:");
    if(Serial3.available() > 3)
      holding = Serial3.available();
      for(i=1; i <= holding; i++)
        sensorstring[i]= Serial3.read();
        Serial.print(sensorstring[i]);
      Serial.println();
      if(holding ==5)
        PHT = ((sensorstring[1]-48)*100 + (sensorstring[3]-48)*10 + (sensorstring[4]-48));
        PHA = PHT/100;
        PHT = ((sensorstring[1]-48)*1000 + (sensorstring[2]-48)*100 + (sensorstring[4]-48)*10 + (sensorstring[5]-48));
        PHA = PHT/100;
      PHT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
with i recieves that:
Debug pH 1:
*ER
7.018
Debug pH 2:
Debug pH 3:
Debug pH 4:
Debug pH 5:
*ER
*ER
Debug pH 6:
*ER
7.019
Debug pH 7:
7.020
Post Number:#25 Post Mon Oct 20, 2014 6:28 pm
What you can learn with this results?
You have commented the fucntions for pH2, ORP and EC in "void iniciar_stamps()"?
Post Number:#26 Post Mon Oct 20, 2014 6:41 pm
i don't know, it make an error when it's connected, maybe
no i don't , why ? there is error of other circuits on my debug ?
i comment now the other circuits.
With other circuits commented:
Debug pH 1:
*ER
7.013
Debug pH 2:
Debug pH 3:
Debug pH 4:
Debug pH 5:
Debug pH 6:
*ER
7.013
Debug pH 7:
7.009
thank you for your patience.
Post Number:#27 Post Wed Oct 22, 2014 1:46 pm
Remove this part:
    Serial.println();
Post Number:#28 Post Wed Oct 22, 2014 2:49 pm
i receives that:
Debug pH 1:
7.194
Debug pH 2:
Debug pH 3:
Debug pH 4:
Debug pH 6:
7.193
Debug pH 7:
7.189
With this code :
//------------------------------------- Leitura dos stamps
void parametros()
   int i;
  do{
    Open_channel(ph1);
    Serial3.print("R");
    delay(1000);
     Serial.println();
    Serial3.print("R");
    delay(1000);
      Serial.println();
      if(holding ==5)
        PHA = PHT/100;
        PHA = PHT/100;
      PHT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
 /* do{
    Open_channel(ph2);
    Serial3.print(tempC); //Para se obter um valor compensado pode-se enviar um valor de temperatura da água.
    delay(500);
      if(holding ==5)
        PHR = PHT/100;
        PHR = PHT/100;
      PHT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  do{
    Open_channel(orp);
    Serial3.print("r"),
    delay(500);
      ORPT = ((sensorstring[1]-48)*100 + (sensorstring[2]-48)*10 + (sensorstring[3]-48));
      ORP = ORPT;
      ORPT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  do{
    Open_channel(ec);
    delay(500);
      Serial.print("Densidade:");
      for(i=1; i <= 15; i++)
      Serial.println();
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  Open_channel(ph1);
  delay(50);
  Serial3.print("R");
  delay(1000);
  Serial3.flush();
     Serial.println();
  delay(1000);
     Serial.println();
  delay(1000);
     Serial.println();
  delay(1000);
     Serial.println();
/* Open_channel(ph2);
  delay(500);
  Serial3.print("R");
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  Serial.println("Debug pH2 setup:");
     Serial.println();
  Open_channel(orp);
  delay(500);
  Serial3.print("R");
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  Serial.println("Debug orp setup:");
   */  Serial.println();
  parametros(); // Verifica os "stamps".
void Open_channel(short channel)
  switch (channel)
  case 0:
    //open channel Y0
    //S0=0
    //S1=0
    digitalWrite(multiplexadorS0Pin, LOW);
    digitalWrite(multiplexadorS1Pin, LOW);
    break;
  case 1:
    //open channel Y1
    //S0=1
    //S1=0
    digitalWrite(multiplexadorS0Pin, HIGH);
    break;
  case 2:
    //open channel Y2
    //S0=0
    //S1=1
    digitalWrite(multiplexadorS1Pin, HIGH);
    break;
/*  case 3:
    //open channel Y3
    //S0=1
    //S1=1
    break; */
  //Serial3.print('\r');
  return;
But on my screen ph tank : 66.96 pb convert to float ?
Post Number:#29 Post Wed Oct 22, 2014 2:59 pm
Replace:
    Serial3.print("R");
    delay(1000);
With:
    Serial3.print("T,");
    delay(1000);
You can't send it 2 times:
    Serial3.print("R");
Post Number:#30 Post Wed Oct 22, 2014 3:06 pm
ok no error, but always ph tank on screen 66.92
Debug pH 1:
7.188
Debug pH 2:
Debug pH 3:
Debug pH 4:
Debug pH 6:
Debug pH 7:
7.192
Post Number:#31 Post Wed Oct 22, 2014 3:12 pm
Before:
      if(holding ==5)
Add:
      Serial.print("Holding: ");
      Serial.println(holding);
      Serial.print("sensorstring[0] :");
      Serial.println(sensorstring[0]);
      Serial.print("sensorstring[1] :");
      Serial.println(sensorstring[1]);
      Serial.print("sensorstring[2] :");
      Serial.println(sensorstring[2]);
      Serial.print("sensorstring[3] :");
      Serial.println(sensorstring[3]);
      Serial.print("sensorstring[4] :");
      Serial.println(sensorstring[4]);
      Serial.print("sensorstring[5] :");
      Serial.println(sensorstring[5]);
Post Number:#32 Post Wed Oct 22, 2014 3:22 pm
ok now i understand "sensorstring".
Holding: 6
sensorstring[0] :
sensorstring[1] :7
sensorstring[2] :.
sensorstring[3] :1
sensorstring[4] :6
sensorstring[5] :9
Post Number:#33 Post Wed Oct 22, 2014 3:30 pm
Replace:
      if(holding ==5)
With:
      if(holding ==6)
The conclusion for all this is simple.
The stamps V4.x send 2 decimal places and EZO send 3.
So the quantity of characters is 6 instead 5.
1º = 7
2º = .
3º = 1
4º = 6
5º = 9
6º = '\r'
I hope that you can learn something with all this.
Post Number:#34 Post Wed Oct 22, 2014 3:39 pm
yes I learn so much and before you ask I always tried several times but I lack connaissnce in coding.
:ymapplause:
great it works well now, I'm going to like ph2 and orp.
Thank you ^:)^
Post Number:#35 Post Fri Oct 24, 2014 5:44 pm
Hi Fernando
I cleaned up the code and found the right adjustment for delays, delays after the "open channel" must be 50 to not make any mistakes.
Now the probes of PH and ORP is working perfectly with new stamps "EZO".
Thank you Fernando. :-bd
void parametros()
   int i;
  do{
    Open_channel(ph1);
    delay(50);
    delay(500);
     Serial.println();
    Serial3.print("R");
    delay(1000);
      Serial.println();
      if(holding ==6)
        PHA = PHT/100;
        PHA = PHT/100;
      PHT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  do{
    Open_channel(ph2);
    delay(50);
    delay(500);
     Serial.println();
    Serial3.print("R");
    delay(1000);
      Serial.println();
      if(holding ==6)
        PHR = PHT/100;
        PHR = PHT/100;
      PHT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  do{
    Open_channel(orp);
     delay(50);
     Serial.println("Debug orp 6:");
    Serial.println();
    Serial3.print("R");
    delay(1000);
    Serial.println("Debug orp 7:");
      ORP = ORPT;
      ORPT=0;
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  do{
    Open_channel(ec);
    delay(500);
      Serial.println();
      Serial3.flush();
      break;
  while (done==1);
  done=0;
  Open_channel(ph1);
  delay(50);
  Serial3.flush();
  delay(500);
  Serial3.flush();
  delay(500);
  delay(500);
  Open_channel(ph2);
  delay(50);
  Serial3.flush();
  delay(500);
  delay(500);
  delay(500);
  Open_channel(orp);
  delay(50);
  delay(500);
  delay(500);
  delay(500);
  switch (channel)
  case 0:
    //open channel Y0
    //S0=0
    //S1=0
    break;
  case 1:
    //open channel Y1
    //S0=1
    //S1=0
    break;
  case 2:
    //open channel Y2
    //S0=0
    //S1=1
    break;
/*  case 3:
    //open channel Y3
    //S0=1
    //S1=1
    break; */
  return;
