Forum Software Ferduino code New Ferduino Build. Help required with compiling error.
New Ferduino Build. Help required with compiling error.  [SOLVED]
Post Number:#1 Post Mon Oct 13, 2014 1:55 am
Hello and Ola, Fernando and All.
My name is Jamie.
Firstly, Fernando, thank you so much for your amazing contribution to the reef keeping hobby. After keeping planted aquariums with my own controllers I have decided to build my first reef tank, I was going to modofy Jarduino, but as you will see from this post, I knew in advance, that I would stuggle heavilly to implement pretty much everything Ferduino offers, including ATO and Automatic Water Change.
Your code is amazing, so I must thank you sincerely right now as I have not found an area to leave my respect and to introduce myself.
I am attempting to build a Ferduino controller.
I have a chinese clone Mega 2560, TFT/SD/Touch shield and 5.0 800x480 Sainsmart TFT LCD.
I have connected them up, tested the UTouch examples and they compiled and uploaded.
I am having trouble with compiling and uploading Ferduino_English.ino from Ferduino_English_master.zip
I am using Arduino IDE 1.5.8
Connectivity between Arduino and IDE is OK.
I have always used arduino IDE on my own laptop which I use ubuntu linux exclusively, but for this, I decided instead of messing my personal library, I would create a fresh install on a my partners laptop with Windows 7 to follow the video exactly.
Following the video. I have removed all libraries from the Program Files(x86)/Arduino/Libraries/ folder and replaced them with all of the library folders contained in /Bibliotecas/
I then opened up Ferduino_English.ino into IDE, all the tabs loaded up correctly, I made changes to the UTFT variable for the Sainsmart 5.0 LCD as follows:
myGLCD(ITDB50, 38,39,40,41)
I proceeded to uploaded, when I was met with the following report.
Arduino: 1.5.8 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
A_Textos.ino:81:1: error: 'prog_char' does not name a type
A_Textos.ino:82:1: error: 'prog_char' does not name a type
A_Textos.ino:83:1: error: 'prog_char' does not name a type
A_Textos.ino:84:1: error: 'prog_char' does not name a type
A_Textos.ino:85:1: error: 'prog_char' does not name a type
A_Textos.ino:86:1: error: 'prog_char' does not name a type
A_Textos.ino:87:1: error: 'prog_char' does not name a type
A_Textos.ino:88:1: error: 'prog_char' does not name a type
A_Textos.ino:89:1: error: 'prog_char' does not name a type
A_Textos.ino:90:1: error: 'prog_char' does not name a type
A_Textos.ino:91:1: error: 'prog_char' does not name a type
A_Textos.ino:92:1: error: 'prog_char' does not name a type
A_Textos.ino:93:1: error: 'prog_char' does not name a type
A_Textos.ino:94:1: error: 'prog_char' does not name a type
A_Textos.ino:95:1: error: 'prog_char' does not name a type
A_Textos.ino:96:1: error: 'prog_char' does not name a type
A_Textos.ino:97:1: error: 'prog_char' does not name a type
A_Textos.ino:98:1: error: 'prog_char' does not name a type
A_Textos.ino:99:1: error: 'prog_char' does not name a type
A_Textos.ino:100:1: error: 'prog_char' does not name a type
A_Textos.ino:101:1: error: 'prog_char' does not name a type
A_Textos.ino:102:1: error: 'prog_char' does not name a type
A_Textos.ino:103:1: error: 'prog_char' does not name a type
A_Textos.ino:104:1: error: 'prog_char' does not name a type
A_Textos.ino:105:1: error: 'prog_char' does not name a type
A_Textos.ino:106:1: error: 'prog_char' does not name a type
A_Textos.ino:107:1: error: 'prog_char' does not name a type
A_Textos.ino:108:1: error: 'prog_char' does not name a type
A_Textos.ino:109:1: error: 'prog_char' does not name a type
A_Textos.ino:110:1: error: 'prog_char' does not name a type
A_Textos.ino:111:1: error: 'prog_char' does not name a type
A_Textos.ino:112:1: error: 'prog_char' does not name a type
A_Textos.ino:113:1: error: 'prog_char' does not name a type
A_Textos.ino:114:1: error: 'prog_char' does not name a type
A_Textos.ino:115:1: error: 'prog_char' does not name a type
A_Textos.ino:116:1: error: 'prog_char' does not name a type
A_Textos.ino:117:1: error: 'prog_char' does not name a type
A_Textos.ino:118:1: error: 'prog_char' does not name a type
A_Textos.ino:119:1: error: 'prog_char' does not name a type
A_Textos.ino:120:1: error: 'prog_char' does not name a type
A_Textos.ino:121:1: error: 'prog_char' does not name a type
A_Textos.ino:122:1: error: 'prog_char' does not name a type
A_Textos.ino:123:1: error: 'prog_char' does not name a type
A_Textos.ino:124:1: error: 'prog_char' does not name a type
A_Textos.ino:125:1: error: 'prog_char' does not name a type
A_Textos.ino:126:1: error: 'prog_char' does not name a type
A_Textos.ino:127:1: error: 'prog_char' does not name a type
A_Textos.ino:128:1: error: 'prog_char' does not name a type
A_Textos.ino:129:1: error: 'prog_char' does not name a type
A_Textos.ino:130:1: error: 'prog_char' does not name a type
A_Textos.ino:131:1: error: 'prog_char' does not name a type
A_Textos.ino:132:1: error: 'prog_char' does not name a type
A_Textos.ino:133:1: error: 'prog_char' does not name a type
A_Textos.ino:134:1: error: 'prog_char' does not name a type
A_Textos.ino:135:1: error: 'prog_char' does not name a type
A_Textos.ino:136:1: error: 'prog_char' does not name a type
A_Textos.ino:137:1: error: 'prog_char' does not name a type
A_Textos.ino:138:1: error: 'prog_char' does not name a type
A_Textos.ino:139:1: error: 'prog_char' does not name a type
A_Textos.ino:140:1: error: 'prog_char' does not name a type
A_Textos.ino:141:1: error: 'prog_char' does not name a type
A_Textos.ino:142:1: error: 'prog_char' does not name a type
A_Textos.ino:143:1: error: 'prog_char' does not name a type
A_Textos.ino:144:1: error: 'prog_char' does not name a type
A_Textos.ino:145:1: error: 'prog_char' does not name a type
A_Textos.ino:146:1: error: 'prog_char' does not name a type
A_Textos.ino:147:1: error: 'prog_char' does not name a type
A_Textos.ino:148:1: error: 'prog_char' does not name a type
A_Textos.ino:149:1: error: 'prog_char' does not name a type
A_Textos.ino:150:1: error: 'prog_char' does not name a type
A_Textos.ino:151:1: error: 'prog_char' does not name a type
A_Textos.ino:152:1: error: 'prog_char' does not name a type
A_Textos.ino:153:1: error: 'prog_char' does not name a type
A_Textos.ino:154:1: error: 'prog_char' does not name a type
A_Textos.ino:155:1: error: 'prog_char' does not name a type
A_Textos.ino:156:1: error: 'prog_char' does not name a type
A_Textos.ino:157:1: error: 'prog_char' does not name a type
A_Textos.ino:158:1: error: 'prog_char' does not name a type
A_Textos.ino:159:1: error: 'prog_char' does not name a type
A_Textos.ino:160:1: error: 'prog_char' does not name a type
A_Textos.ino:161:1: error: 'prog_char' does not name a type
A_Textos.ino:162:1: error: 'prog_char' does not name a type
A_Textos.ino:163:1: error: 'prog_char' does not name a type
A_Textos.ino:164:1: error: 'prog_char' does not name a type
A_Textos.ino:165:1: error: 'prog_char' does not name a type
A_Textos.ino:166:1: error: 'prog_char' does not name a type
A_Textos.ino:167:1: error: 'prog_char' does not name a type
A_Textos.ino:168:1: error: 'prog_char' does not name a type
A_Textos.ino:169:1: error: 'prog_char' does not name a type
A_Textos.ino:170:1: error: 'prog_char' does not name a type
A_Textos.ino:171:1: error: 'prog_char' does not name a type
A_Textos.ino:172:1: error: 'prog_char' does not name a type
A_Textos.ino:173:1: error: 'prog_char' does not name a type
A_Textos.ino:174:1: error: 'prog_char' does not name a type
A_Textos.ino:175:1: error: 'prog_char' does not name a type
A_Textos.ino:176:1: error: 'prog_char' does not name a type
A_Textos.ino:177:1: error: 'prog_char' does not name a type
A_Textos.ino:178:1: error: 'prog_char' does not name a type
A_Textos.ino:179:1: error: 'prog_char' does not name a type
A_Textos.ino:180:1: error: 'prog_char' does not name a type
A_Textos.ino:181:1: error: 'prog_char' does not name a type
A_Textos.ino:182:1: error: 'prog_char' does not name a type
A_Textos.ino:183:1: error: 'prog_char' does not name a type
A_Textos.ino:184:1: error: 'prog_char' does not name a type
A_Textos.ino:185:1: error: 'prog_char' does not name a type
A_Textos.ino:186:1: error: 'prog_char' does not name a type
A_Textos.ino:187:1: error: 'prog_char' does not name a type
A_Textos.ino:188:1: error: 'prog_char' does not name a type
A_Textos.ino:189:1: error: 'prog_char' does not name a type
A_Textos.ino:190:1: error: 'prog_char' does not name a type
A_Textos.ino:191:1: error: 'prog_char' does not name a type
A_Textos.ino:192:1: error: 'prog_char' does not name a type
A_Textos.ino:193:1: error: 'prog_char' does not name a type
A_Textos.ino:194:1: error: 'prog_char' does not name a type
A_Textos.ino:195:1: error: 'prog_char' does not name a type
A_Textos.ino:196:1: error: 'prog_char' does not name a type
A_Textos.ino:197:1: error: 'prog_char' does not name a type
A_Textos.ino:198:1: error: 'prog_char' does not name a type
A_Textos.ino:199:1: error: 'prog_char' does not name a type
A_Textos.ino:200:1: error: 'prog_char' does not name a type
A_Textos.ino:201:1: error: 'prog_char' does not name a type
A_Textos.ino:202:1: error: 'prog_char' does not name a type
A_Textos.ino:203:1: error: 'prog_char' does not name a type
A_Textos.ino:204:1: error: 'prog_char' does not name a type
A_Textos.ino:205:1: error: 'prog_char' does not name a type
A_Textos.ino:206:1: error: 'prog_char' does not name a type
A_Textos.ino:207:1: error: 'prog_char' does not name a type
A_Textos.ino:208:1: error: 'prog_char' does not name a type
A_Textos.ino:209:1: error: 'prog_char' does not name a type
A_Textos.ino:210:1: error: 'prog_char' does not name a type
A_Textos.ino:211:1: error: 'prog_char' does not name a type
A_Textos.ino:212:1: error: 'prog_char' does not name a type
A_Textos.ino:213:1: error: 'prog_char' does not name a type
A_Textos.ino:214:1: error: 'prog_char' does not name a type
A_Textos.ino:215:1: error: 'prog_char' does not name a type
A_Textos.ino:216:1: error: 'prog_char' does not name a type
A_Textos.ino:217:1: error: 'prog_char' does not name a type
A_Textos.ino:218:1: error: 'prog_char' does not name a type
A_Textos.ino:219:1: error: 'prog_char' does not name a type
A_Textos.ino:220:1: error: 'prog_char' does not name a type
A_Textos.ino:221:1: error: 'prog_char' does not name a type
A_Textos.ino:222:1: error: 'prog_char' does not name a type
A_Textos.ino:223:1: error: 'prog_char' does not name a type
A_Textos.ino:224:1: error: 'prog_char' does not name a type
A_Textos.ino:225:1: error: 'prog_char' does not name a type
A_Textos.ino:226:1: error: 'prog_char' does not name a type
A_Textos.ino:227:1: error: 'prog_char' does not name a type
A_Textos.ino:228:1: error: 'prog_char' does not name a type
A_Textos.ino:229:1: error: 'prog_char' does not name a type
A_Textos.ino:230:1: error: 'prog_char' does not name a type
A_Textos.ino:231:1: error: 'prog_char' does not name a type
A_Textos.ino:232:1: error: 'prog_char' does not name a type
A_Textos.ino:233:1: error: 'prog_char' does not name a type
A_Textos.ino:234:1: error: 'prog_char' does not name a type
A_Textos.ino:235:1: error: 'prog_char' does not name a type
A_Textos.ino:236:1: error: 'prog_char' does not name a type
A_Textos.ino:237:1: error: 'prog_char' does not name a type
A_Textos.ino:238:1: error: 'prog_char' does not name a type
A_Textos.ino:239:1: error: 'prog_char' does not name a type
A_Textos.ino:240:1: error: 'prog_char' does not name a type
A_Textos.ino:241:1: error: 'prog_char' does not name a type
A_Textos.ino:242:1: error: 'prog_char' does not name a type
A_Textos.ino:243:1: error: 'prog_char' does not name a type
A_Textos.ino:244:1: error: 'prog_char' does not name a type
A_Textos.ino:245:1: error: 'prog_char' does not name a type
A_Textos.ino:246:1: error: 'prog_char' does not name a type
A_Textos.ino:247:1: error: 'prog_char' does not name a type
A_Textos.ino:248:1: error: 'prog_char' does not name a type
A_Textos.ino:249:1: error: 'prog_char' does not name a type
A_Textos.ino:250:1: error: 'prog_char' does not name a type
A_Textos.ino:251:1: error: 'prog_char' does not name a type
A_Textos.ino:252:1: error: 'prog_char' does not name a type
A_Textos.ino:253:1: error: 'prog_char' does not name a type
A_Textos.ino:254:1: error: 'prog_char' does not name a type
A_Textos.ino:255:1: error: 'prog_char' does not name a type
A_Textos.ino:256:1: error: 'prog_char' does not name a type
A_Textos.ino:257:1: error: 'prog_char' does not name a type
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from C:\Program Files (x86)\Arduino\libraries\UTFT/UTFT.h:83,
                 from Ferduino_English.ino:44:
A_Textos.ino:260:23: error: variable 'tabela_textos' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
A_Textos.ino:262:3: error: 'texto0' was not declared in this scope
A_Textos.ino:262:11: error: 'texto1' was not declared in this scope
A_Textos.ino:262:19: error: 'texto2' was not declared in this scope
A_Textos.ino:262:27: error: 'texto3' was not declared in this scope
A_Textos.ino:262:35: error: 'texto4' was not declared in this scope
A_Textos.ino:262:43: error: 'texto5' was not declared in this scope
A_Textos.ino:262:51: error: 'texto6' was not declared in this scope
A_Textos.ino:262:59: error: 'texto7' was not declared in this scope
A_Textos.ino:263:3: error: 'texto8' was not declared in this scope
A_Textos.ino:263:11: error: 'texto9' was not declared in this scope
A_Textos.ino:263:19: error: 'texto10' was not declared in this scope
A_Textos.ino:263:28: error: 'texto11' was not declared in this scope
A_Textos.ino:263:37: error: 'texto12' was not declared in this scope
A_Textos.ino:263:46: error: 'texto13' was not declared in this scope
A_Textos.ino:263:55: error: 'texto14' was not declared in this scope
A_Textos.ino:263:64: error: 'texto15' was not declared in this scope
A_Textos.ino:264:3: error: 'texto16' was not declared in this scope
A_Textos.ino:264:12: error: 'texto17' was not declared in this scope
A_Textos.ino:264:21: error: 'texto18' was not declared in this scope
A_Textos.ino:264:30: error: 'texto19' was not declared in this scope
A_Textos.ino:264:39: error: 'texto20' was not declared in this scope
A_Textos.ino:264:48: error: 'texto21' was not declared in this scope
A_Textos.ino:264:57: error: 'texto22' was not declared in this scope
A_Textos.ino:264:66: error: 'texto23' was not declared in this scope
A_Textos.ino:265:3: error: 'texto24' was not declared in this scope
A_Textos.ino:265:12: error: 'texto25' was not declared in this scope
A_Textos.ino:265:21: error: 'texto26' was not declared in this scope
A_Textos.ino:265:30: error: 'texto27' was not declared in this scope
A_Textos.ino:265:39: error: 'texto28' was not declared in this scope
A_Textos.ino:265:48: error: 'texto29' was not declared in this scope
A_Textos.ino:265:57: error: 'texto30' was not declared in this scope
A_Textos.ino:265:66: error: 'texto31' was not declared in this scope
A_Textos.ino:266:3: error: 'texto32' was not declared in this scope
A_Textos.ino:266:12: error: 'texto33' was not declared in this scope
A_Textos.ino:266:21: error: 'texto34' was not declared in this scope
A_Textos.ino:266:30: error: 'texto35' was not declared in this scope
A_Textos.ino:266:39: error: 'texto36' was not declared in this scope
A_Textos.ino:266:48: error: 'texto37' was not declared in this scope
A_Textos.ino:266:57: error: 'texto38' was not declared in this scope
A_Textos.ino:266:66: error: 'texto39' was not declared in this scope
A_Textos.ino:267:3: error: 'texto40' was not declared in this scope
A_Textos.ino:267:12: error: 'texto41' was not declared in this scope
A_Textos.ino:267:21: error: 'texto42' was not declared in this scope
A_Textos.ino:267:30: error: 'texto43' was not declared in this scope
A_Textos.ino:267:39: error: 'texto44' was not declared in this scope
A_Textos.ino:267:48: error: 'texto45' was not declared in this scope
A_Textos.ino:267:57: error: 'texto46' was not declared in this scope
A_Textos.ino:267:66: error: 'texto47' was not declared in this scope
A_Textos.ino:268:3: error: 'texto48' was not declared in this scope
A_Textos.ino:268:12: error: 'texto49' was not declared in this scope
A_Textos.ino:268:21: error: 'texto50' was not declared in this scope
A_Textos.ino:268:31: error: 'texto51' was not declared in this scope
A_Textos.ino:268:40: error: 'texto52' was not declared in this scope
A_Textos.ino:268:49: error: 'texto53' was not declared in this scope
A_Textos.ino:268:58: error: 'texto54' was not declared in this scope
A_Textos.ino:268:67: error: 'texto55' was not declared in this scope
A_Textos.ino:269:3: error: 'texto56' was not declared in this scope
A_Textos.ino:269:12: error: 'texto57' was not declared in this scope
A_Textos.ino:269:21: error: 'texto58' was not declared in this scope
A_Textos.ino:269:30: error: 'texto59' was not declared in this scope
A_Textos.ino:269:39: error: 'texto60' was not declared in this scope
A_Textos.ino:269:48: error: 'texto61' was not declared in this scope
A_Textos.ino:269:57: error: 'texto62' was not declared in this scope
A_Textos.ino:269:66: error: 'texto63' was not declared in this scope
A_Textos.ino:270:3: error: 'texto64' was not declared in this scope
A_Textos.ino:270:12: error: 'texto65' was not declared in this scope
A_Textos.ino:270:21: error: 'texto66' was not declared in this scope
A_Textos.ino:270:30: error: 'texto67' was not declared in this scope
A_Textos.ino:270:39: error: 'texto68' was not declared in this scope
A_Textos.ino:270:48: error: 'texto69' was not declared in this scope
A_Textos.ino:270:57: error: 'texto70' was not declared in this scope
A_Textos.ino:270:66: error: 'texto71' was not declared in this scope
A_Textos.ino:271:3: error: 'texto72' was not declared in this scope
A_Textos.ino:271:12: error: 'texto73' was not declared in this scope
A_Textos.ino:271:21: error: 'texto74' was not declared in this scope
A_Textos.ino:271:30: error: 'texto75' was not declared in this scope
A_Textos.ino:271:39: error: 'texto76' was not declared in this scope
A_Textos.ino:271:48: error: 'texto77' was not declared in this scope
A_Textos.ino:271:57: error: 'texto78' was not declared in this scope
A_Textos.ino:271:66: error: 'texto79' was not declared in this scope
A_Textos.ino:272:3: error: 'texto80' was not declared in this scope
A_Textos.ino:272:12: error: 'texto81' was not declared in this scope
A_Textos.ino:272:21: error: 'texto82' was not declared in this scope
A_Textos.ino:272:30: error: 'texto83' was not declared in this scope
A_Textos.ino:272:39: error: 'texto84' was not declared in this scope
A_Textos.ino:272:48: error: 'texto85' was not declared in this scope
A_Textos.ino:272:57: error: 'texto86' was not declared in this scope
A_Textos.ino:272:66: error: 'texto87' was not declared in this scope
A_Textos.ino:273:3: error: 'texto88' was not declared in this scope
A_Textos.ino:273:12: error: 'texto89' was not declared in this scope
A_Textos.ino:273:21: error: 'texto90' was not declared in this scope
A_Textos.ino:273:30: error: 'texto91' was not declared in this scope
A_Textos.ino:273:39: error: 'texto92' was not declared in this scope
A_Textos.ino:273:48: error: 'texto93' was not declared in this scope
A_Textos.ino:273:57: error: 'texto94' was not declared in this scope
A_Textos.ino:273:66: error: 'texto95' was not declared in this scope
A_Textos.ino:274:3: error: 'texto96' was not declared in this scope
A_Textos.ino:274:12: error: 'texto97' was not declared in this scope
A_Textos.ino:274:21: error: 'texto98' was not declared in this scope
A_Textos.ino:274:30: error: 'texto99' was not declared in this scope
A_Textos.ino:274:39: error: 'texto100' was not declared in this scope
A_Textos.ino:274:49: error: 'texto101' was not declared in this scope
A_Textos.ino:274:59: error: 'texto102' was not declared in this scope
A_Textos.ino:274:69: error: 'texto103' was not declared in this scope
A_Textos.ino:275:3: error: 'texto104' was not declared in this scope
A_Textos.ino:275:13: error: 'texto105' was not declared in this scope
A_Textos.ino:275:23: error: 'texto106' was not declared in this scope
A_Textos.ino:275:33: error: 'texto107' was not declared in this scope
A_Textos.ino:275:43: error: 'texto108' was not declared in this scope
A_Textos.ino:275:53: error: 'texto109' was not declared in this scope
A_Textos.ino:275:63: error: 'texto110' was not declared in this scope
A_Textos.ino:276:3: error: 'texto111' was not declared in this scope
A_Textos.ino:276:13: error: 'texto112' was not declared in this scope
A_Textos.ino:276:23: error: 'texto113' was not declared in this scope
A_Textos.ino:276:33: error: 'texto114' was not declared in this scope
A_Textos.ino:276:43: error: 'texto115' was not declared in this scope
A_Textos.ino:276:53: error: 'texto116' was not declared in this scope
A_Textos.ino:276:63: error: 'texto117' was not declared in this scope
A_Textos.ino:277:3: error: 'texto118' was not declared in this scope
A_Textos.ino:277:13: error: 'texto119' was not declared in this scope
A_Textos.ino:277:23: error: 'texto120' was not declared in this scope
A_Textos.ino:277:33: error: 'texto121' was not declared in this scope
A_Textos.ino:277:43: error: 'texto122' was not declared in this scope
A_Textos.ino:277:53: error: 'texto123' was not declared in this scope
A_Textos.ino:277:63: error: 'texto124' was not declared in this scope
A_Textos.ino:278:3: error: 'texto125' was not declared in this scope
A_Textos.ino:278:13: error: 'texto126' was not declared in this scope
A_Textos.ino:278:23: error: 'texto127' was not declared in this scope
A_Textos.ino:278:33: error: 'texto128' was not declared in this scope
A_Textos.ino:278:43: error: 'texto129' was not declared in this scope
A_Textos.ino:278:53: error: 'texto130' was not declared in this scope
A_Textos.ino:278:63: error: 'texto131' was not declared in this scope
A_Textos.ino:279:3: error: 'texto132' was not declared in this scope
A_Textos.ino:279:13: error: 'texto133' was not declared in this scope
A_Textos.ino:279:23: error: 'texto134' was not declared in this scope
A_Textos.ino:279:33: error: 'texto135' was not declared in this scope
A_Textos.ino:279:43: error: 'texto136' was not declared in this scope
A_Textos.ino:279:53: error: 'texto137' was not declared in this scope
A_Textos.ino:279:63: error: 'texto138' was not declared in this scope
A_Textos.ino:280:3: error: 'texto139' was not declared in this scope
A_Textos.ino:280:13: error: 'texto140' was not declared in this scope
A_Textos.ino:280:23: error: 'texto141' was not declared in this scope
A_Textos.ino:280:33: error: 'texto142' was not declared in this scope
A_Textos.ino:280:43: error: 'texto143' was not declared in this scope
A_Textos.ino:280:53: error: 'texto144' was not declared in this scope
A_Textos.ino:280:63: error: 'texto145' was not declared in this scope
A_Textos.ino:281:3: error: 'texto146' was not declared in this scope
A_Textos.ino:281:13: error: 'texto147' was not declared in this scope
A_Textos.ino:281:23: error: 'texto148' was not declared in this scope
A_Textos.ino:281:33: error: 'texto149' was not declared in this scope
A_Textos.ino:281:43: error: 'texto150' was not declared in this scope
A_Textos.ino:281:53: error: 'texto151' was not declared in this scope
A_Textos.ino:281:63: error: 'texto152' was not declared in this scope
A_Textos.ino:282:3: error: 'texto153' was not declared in this scope
A_Textos.ino:282:13: error: 'texto154' was not declared in this scope
A_Textos.ino:282:23: error: 'texto155' was not declared in this scope
A_Textos.ino:282:33: error: 'texto156' was not declared in this scope
A_Textos.ino:282:43: error: 'texto157' was not declared in this scope
A_Textos.ino:282:53: error: 'texto158' was not declared in this scope
A_Textos.ino:282:63: error: 'texto159' was not declared in this scope
A_Textos.ino:283:3: error: 'texto160' was not declared in this scope
A_Textos.ino:283:13: error: 'texto161' was not declared in this scope
A_Textos.ino:283:23: error: 'texto162' was not declared in this scope
A_Textos.ino:283:33: error: 'texto163' was not declared in this scope
A_Textos.ino:283:43: error: 'texto164' was not declared in this scope
A_Textos.ino:283:53: error: 'texto165' was not declared in this scope
A_Textos.ino:283:63: error: 'texto166' was not declared in this scope
A_Textos.ino:284:3: error: 'texto167' was not declared in this scope
A_Textos.ino:284:13: error: 'texto168' was not declared in this scope
A_Textos.ino:284:23: error: 'texto169' was not declared in this scope
A_Textos.ino:284:33: error: 'texto170' was not declared in this scope
A_Textos.ino:284:43: error: 'texto171' was not declared in this scope
A_Textos.ino:284:53: error: 'texto172' was not declared in this scope
A_Textos.ino:284:63: error: 'texto173' was not declared in this scope
A_Textos.ino:285:3: error: 'texto174' was not declared in this scope
A_Textos.ino:285:13: error: 'texto175' was not declared in this scope
A_Textos.ino:285:23: error: 'texto176' was not declared in this scope
A_Textos.ino:285:33: error: 'texto177' was not declared in this scope
A_Textos.ino:285:43: error: 'texto178' was not declared in this scope
A_Textos.ino:285:53: error: 'texto179' was not declared in this scope
A_Textos.ino:285:63: error: 'texto180' was not declared in this scope
A_Textos.ino:286:3: error: 'texto181' was not declared in this scope
A_Textos.ino:286:13: error: 'texto182' was not declared in this scope
A_Textos.ino:286:23: error: 'texto183' was not declared in this scope
A_Textos.ino:286:33: error: 'texto184' was not declared in this scope
A_Textos.ino:286:43: error: 'texto185' was not declared in this scope
A_Textos.ino:286:53: error: 'texto186' was not declared in this scope
A_Textos.ino:286:63: error: 'texto187' was not declared in this scope
A_Textos.ino:287:3: error: 'texto188' was not declared in this scope
A_Textos.ino:287:13: error: 'texto189' was not declared in this scope
A_Textos.ino:287:23: error: 'texto190' was not declared in this scope
A_Textos.ino:287:33: error: 'texto191' was not declared in this scope
A_Textos.ino:287:43: error: 'texto192' was not declared in this scope
A_Textos.ino:287:53: error: 'texto193' was not declared in this scope
A_Textos.ino:287:63: error: 'texto194' was not declared in this scope
A_Textos.ino:288:3: error: 'texto195' was not declared in this scope
A_Textos.ino:288:13: error: 'texto196' was not declared in this scope
A_Textos.ino:288:23: error: 'texto197' was not declared in this scope
A_Textos.ino:288:33: error: 'texto198' was not declared in this scope
A_Textos.ino:288:43: error: 'texto199' was not declared in this scope
A_Textos.ino:288:53: error: 'texto200' was not declared in this scope
A_Textos.ino:288:63: error: 'texto201' was not declared in this scope
A_Textos.ino:289:3: error: 'texto202' was not declared in this scope
A_Textos.ino:289:13: error: 'texto203' was not declared in this scope
A_Textos.ino:289:23: error: 'texto204' was not declared in this scope
A_Textos.ino:289:33: error: 'texto205' was not declared in this scope
A_Textos.ino:289:43: error: 'texto206' was not declared in this scope
A_Textos.ino:289:53: error: 'texto207' was not declared in this scope
A_Textos.ino:289:63: error: 'texto208' was not declared in this scope
A_Textos.ino:290:3: error: 'texto209' was not declared in this scope
A_Textos.ino:290:13: error: 'texto210' was not declared in this scope
A_Textos.ino:290:23: error: 'texto211' was not declared in this scope
A_Textos.ino:290:33: error: 'texto212' was not declared in this scope
A_Textos.ino:290:43: error: 'texto213' was not declared in this scope
A_Textos.ino:290:53: error: 'texto214' was not declared in this scope
A_Textos.ino:290:63: error: 'texto215' was not declared in this scope
A_Textos.ino:291:3: error: 'texto216' was not declared in this scope
A_Textos.ino:291:13: error: 'texto217' was not declared in this scope
A_Textos.ino:291:23: error: 'texto218' was not declared in this scope
A_Textos.ino:291:33: error: 'texto219' was not declared in this scope
A_Textos.ino:291:43: error: 'texto220' was not declared in this scope
A_Textos.ino:291:53: error: 'texto221' was not declared in this scope
A_Textos.ino:291:63: error: 'texto222' was not declared in this scope
A_Textos.ino:292:3: error: 'texto223' was not declared in this scope
A_Textos.ino:292:13: error: 'texto224' was not declared in this scope
A_Textos.ino:292:23: error: 'texto225' was not declared in this scope
A_Textos.ino:292:33: error: 'texto226' was not declared in this scope
A_Textos.ino:292:43: error: 'texto227' was not declared in this scope
A_Textos.ino:292:53: error: 'texto228' was not declared in this scope
A_Textos.ino:292:63: error: 'texto229' was not declared in this scope
A_Textos.ino:293:3: error: 'texto230' was not declared in this scope
A_Textos.ino:293:13: error: 'texto231' was not declared in this scope
A_Textos.ino:293:23: error: 'texto232' was not declared in this scope
A_Textos.ino:293:33: error: 'texto233' was not declared in this scope
A_Textos.ino:293:43: error: 'texto234' was not declared in this scope
A_Textos.ino:293:53: error: 'texto235' was not declared in this scope
A_Textos.ino:293:63: error: 'texto236' was not declared in this scope
A_Textos.ino:294:3: error: 'texto237' was not declared in this scope
A_Textos.ino:294:13: error: 'texto238' was not declared in this scope
A_Textos.ino:294:23: error: 'texto239' was not declared in this scope
A_Textos.ino:294:33: error: 'texto240' was not declared in this scope
A_Textos.ino:294:43: error: 'texto241' was not declared in this scope
A_Textos.ino:294:53: error: 'texto242' was not declared in this scope
A_Textos.ino:294:63: error: 'texto243' was not declared in this scope
A_Textos.ino:295:3: error: 'texto244' was not declared in this scope
A_Textos.ino:295:13: error: 'texto245' was not declared in this scope
A_Textos.ino:295:23: error: 'texto246' was not declared in this scope
A_Textos.ino:295:33: error: 'texto247' was not declared in this scope
A_Textos.ino:295:43: error: 'texto248' was not declared in this scope
A_Textos.ino:295:53: error: 'texto249' was not declared in this scope
A_Textos.ino:295:63: error: 'texto250' was not declared in this scope
A_Textos.ino:296:3: error: 'texto251' was not declared in this scope
A_Textos.ino:296:13: error: 'texto252' was not declared in this scope
A_Textos.ino:296:23: error: 'texto253' was not declared in this scope
A_Textos.ino:296:33: error: 'texto254' was not declared in this scope
A_Textos.ino:296:43: error: 'texto255' was not declared in this scope
A_Textos.ino:296:53: error: 'texto256' was not declared in this scope
A_Textos.ino:299:28: error: variable 'tabela_textos_fase' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
A_Textos.ino:308:1: error: 'prog_char' does not name a type
A_Textos.ino:309:1: error: 'prog_char' does not name a type
A_Textos.ino:310:1: error: 'prog_char' does not name a type
A_Textos.ino:311:1: error: 'prog_char' does not name a type
A_Textos.ino:312:1: error: 'prog_char' does not name a type
A_Textos.ino:313:1: error: 'prog_char' does not name a type
A_Textos.ino:314:1: error: 'prog_char' does not name a type
A_Textos.ino:315:1: error: 'prog_char' does not name a type
A_Textos.ino:316:1: error: 'prog_char' does not name a type
A_Textos.ino:317:1: error: 'prog_char' does not name a type
A_Textos.ino:318:1: error: 'prog_char' does not name a type
A_Textos.ino:319:1: error: 'prog_char' does not name a type
A_Textos.ino:320:1: error: 'prog_char' does not name a type
A_Textos.ino:321:1: error: 'prog_char' does not name a type
A_Textos.ino:322:1: error: 'prog_char' does not name a type
A_Textos.ino:323:1: error: 'prog_char' does not name a type
A_Textos.ino:324:1: error: 'prog_char' does not name a type
A_Textos.ino:325:1: error: 'prog_char' does not name a type
A_Textos.ino:326:1: error: 'prog_char' does not name a type
A_Textos.ino:327:1: error: 'prog_char' does not name a type
A_Textos.ino:328:1: error: 'prog_char' does not name a type
A_Textos.ino:329:1: error: 'prog_char' does not name a type
A_Textos.ino:331:20: error: variable 'nome_canal' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
A_Textos.ino:333:3: error: 'nomecanal0' was not declared in this scope
A_Textos.ino:333:15: error: 'nomecanal1' was not declared in this scope
A_Textos.ino:333:27: error: 'nomecanal2' was not declared in this scope
A_Textos.ino:333:39: error: 'nomecanal3' was not declared in this scope
A_Textos.ino:333:51: error: 'nomecanal4' was not declared in this scope
A_Textos.ino:333:63: error: 'nomecanal5' was not declared in this scope
A_Textos.ino:334:3: error: 'nomecanal6' was not declared in this scope
A_Textos.ino:334:15: error: 'nomecanal7' was not declared in this scope
A_Textos.ino:334:27: error: 'nomecanal8' was not declared in this scope
A_Textos.ino:334:39: error: 'nomecanal9' was not declared in this scope
A_Textos.ino:334:51: error: 'nomecanal10' was not declared in this scope
A_Textos.ino:334:64: error: 'nomecanal11' was not declared in this scope
A_Textos.ino:335:3: error: 'nomecanal12' was not declared in this scope
A_Textos.ino:335:16: error: 'nomecanal13' was not declared in this scope
A_Textos.ino:335:29: error: 'nomecanal14' was not declared in this scope
A_Textos.ino:335:42: error: 'nomecanal15' was not declared in this scope
A_Textos.ino:335:55: error: 'nomecanal16' was not declared in this scope
A_Textos.ino:335:67: error: 'nomecanal17' was not declared in this scope
A_Textos.ino:336:3: error: 'nomecanal18' was not declared in this scope
A_Textos.ino:336:16: error: 'nomecanal19' was not declared in this scope
A_Textos.ino:336:29: error: 'nomecanal20' was not declared in this scope
A_Textos.ino:336:42: error: 'nomecanal21' was not declared in this scope
Cosm.ino: In function 'void cosm()':
Cosm.ino:4:31: error: no matching function for call to 'EtherCard::dnsLookup(char [13])'
Cosm.ino:4:31: note: candidate is:
In file included from Ferduino_English.ino:54:0:
C:\Program Files (x86)\Arduino\libraries\ethercard/EtherCard.h:175:15: note: static bool EtherCard::dnsLookup(int*, bool)
   static bool dnsLookup (prog_char* name, bool fromRam =false);
C:\Program Files (x86)\Arduino\libraries\ethercard/EtherCard.h:175:15: note:   no known conversion for argument 1 from 'char [13]' to 'int*'
Error compiling.
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Currently all I have is the Mega, TFT and a DS1307 not wired up.
Could this be due to me not having the rest of the required hardware including the W1500 Ethernet module, connected to the Mega?
I feel I am missing something significant. :D
Can somebody perhaps point me in the right direction please?
Thanks so much in advance.
Jamie.
Edit: I would like to add, I have also tried willie111/ferduino-7.0 which is actually the version I would like. Upon compiling and uploading I get the following message:
RusFont1.c:8:9: error: variable 'RusFont1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t RusFont1[764] PROGMEM={
Error compiling.
I followed the same proceedure as in the video, except I used the code from github.com/willie111/Ferduino-7.0, copied the libraries over to a clean library folder, made the changes for the LCD, and attemped to upload.
I feel so silly, I must be missing something minor, but I am lost amongst these error messages. #-o
Welcome Jamie!
You need use the IDE 1.0.5 and this library.
In .../libraries/UTFT delete the file "DefaultFonts.c"
In .../Ferduino_English/bibliotecas/UTFT copy the files "BigFont.c", "RusFont1.c", "SmallFont.c", " SevenSegNumFont.c", "SevenSegmentFull.c" and "SevenSegNumFontPlus.c" paste in .../libraries/UTFT.
Ola :D
It is uploading right now...
Happy to see RX light flashing away..
Will report back in a moment.
Cut that, formatting eeprom..
It has loaded! not full size but that is due to the version, now I know where I went wrong, I can test the latest beta.
God bless you!
I would like to add, I did try all this on 1.0.5, as I said originally I followed the video but I also said I used the latest build, I did use both, I must have missed the font swap.
All those errors huh =))
Thank you so much Fernando, I will surely repay this to you once I actually get my build threads done. I will eventually get around to writing up some local HTML pages which I see a few people are asking about as I am much better at web design than coding on MCU's :)
Thank you so so much! I just need to go and play because when I started this post I was still wondering it if would work!
Jay
Post Number:#4 Post Mon Oct 13, 2014 10:33 pm
Olá!
