Forum Software Ferduino code Too many errors, when try to login on joyreef
Too many errors, when try to login on joyreef  [SOLVED]
Post Number:#1 Post Mon Dec 08, 2014 8:00 am
Len Nederlof Random avatar
Hi
The new Joy-reef is looking great.
I try to upgrade to the newer version on it.
I had the old version of Ferduino with web control
so i replaced the old ethernet library by this downloaded together with "Ferduino with web control".
I compiled the sketch again and uploaded it again
I registerd again on joy-reef but when i try to login first i get Ferduino password error, check your settings
after refreshing i get
Too many errors, please wait 843 seconds and retry
Do i need to change the part of the ehternet settings on the sketch to put the API key in it
I mean do i have to follow the other instructions in the How to install Ferduino with web control
mentioned under " For all users: "
or is
Warning: Old users only need do update of ethernet library.
Replace the old ethernet library by this downloaded together with "Ferduino with web control".
enough
Kind regards Len
Post Number:#2 Post Mon Dec 08, 2014 8:08 am
It means that no need change others libraries.
You need make all others configurations according to new tutorial.
Post Number:#3 Post Wed Dec 10, 2014 1:25 pm
I still have password problems
i cant connect to joy-reef with the arduino and when i try to connect to the arduino using the code from base64
The format show be: http://local_IP:port/?cmd=password_in_base64,0,K
i get response":"000
If i use the serial monitor theres no response
i made all others configurations according to new tutorial, i changed the part of "Funções do ethernet shield" in the sketch so its like in the new ferduino code with the username and API key.
boolean Ethernet_Shield = true; // Altere para "false" caso não tenha um Ethernet Shield conectado ao Arduino.
char *Username  = "nederlof";   // Coloque aqui o nome de usuário cadastrado no joy-reef.com
char *APIKEY = "xxxxxx";           // Cole aqui a ApiKey gerada pelo joy-reef.com
byte maxima_tentativa = 3;                // Número máximo de tentativas de autenticação.
unsigned long intervalo_tentativa = 15;   // Tempo  de espera (em minutos) para novas tentativas.
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Este MAC deve ser único na sua rede local.
byte ip[] = {x, x, x, x};                     // Configure o IP conforme a sua rede local.
IPAddress dnsServer(8, 8, 8, 8);                    // Configure o IP conforme a sua rede local. Este é o DNS do Google, geralmente não é necessário mudar.
IPAddress gateway(x,x,x,x);                  // Configure o "Gateway" conforme a sua rede local.
IPAddress subnet(255, 255, 255, 0);                 // Configure a máscara de rede conforme a sua rede local.
EthernetServer server(80);                        // Coloque aqui o número da porta configurada no seu roteador para redirecionamento.
                                                    // O número da porta deverá ser obrigatóriamente um destes: 80, 5000, 6000, 7000, 8000, 8080 ou 9000.
unsigned long intervalo = 0;
char *inParse[25];
boolean web_teste = false;
byte tentativa = 0;
boolean web_dosage = false;
unsigned long millis_dosagem = 0;
unsigned long millis_enviar = 0;
boolean web_calibracao = false;
char *token = ":";
char Auth1[50];
unsigned long teste_led_millis = 0;
and i changed the part on the webserver tab so its like in the new ferduino code,this becausse ther wher compilling error and the now fixed.
Kind regards Len
Post Number:#4 Post Wed Dec 10, 2014 1:38 pm
Can you show the APIKEY that you are unsing on code exactly?
Later you can generate a new clicking at "Generate new ApiKey".
If the code send 000 it's means that all configurations for local network are fine.
Post Number:#5 Post Thu Dec 11, 2014 4:55 am
My code is
char *APIKEY = "90e73bf";
This the second one i tried because with the first key i had the same problem so i generated aa new one but still not ok.
Len
Post Number:#6 Post Thu Dec 11, 2014 9:07 am
Using your local IP try this:
http://192.168.0.177/?cmd=bmVkZXJsb2Y6OTBlNzNiZg==,0,K
You can have problem with your provider using the port 80. Try the 5000.
Post Number:#7 Post Thu Dec 11, 2014 1:09 pm
Tried the code white my local ip its the same
changed the poort to 5000 did the port check,the port is open.
when i try to connect i get
{"response":"001","interval":"718"}
on the joy reef site i get Too many errors, please wait 700 seconds and retry
when the interval is counted down to zero i get
{"response":"000"}
and then on the joy reef site i get
Post Number:#8 Post Thu Dec 11, 2014 1:28 pm
On setup add:
  Serial.print("Base 64: ");
  Serial.println(Auth1);
  char credencial[50];
  base64_decode(credencial, Auth1, strlen(Auth1));
  Serial.print("Username:APIKEY: ");
  Serial.println(credencial);
After:
base64_encode(Auth1, buffer, strlen(buffer));
Open the serial monitor set baud to 38400.
Tell me the result.
Post Number:#9 Post Thu Dec 11, 2014 3:45 pm
Because i'm running the old version of Ferduino with web control there is no
in the setup tab ( and more lines are different) so i will fix them first hopefully is that the problem.
I already found earlier some changes in the code on the ferduino tab at the end
prog_char string0[] PROGMEM = "POST /api/temp HTTP/1.1";
i already changed them earlier
Len
Post Number:#10 Post Fri Dec 12, 2014 7:04 am
Images: 1
Joy-reef is not compatible with old version of Ferduino.
You have to update it.
Post Number:#11 Post Sun Dec 14, 2014 11:24 am
Can you mark this topic as solved?
The problem to connect to the Joy-reef is solved.
Latest version of ferduino loaded and a made the changes necessary to work with my setup.
Still small problem regarding dosing pumps , but have to look into that
Len
