Forum Software Ferduino code Previous version of ferduino
Previous version of ferduino  [SOLVED]
Post Number:#1 Post Tue Dec 09, 2014 3:18 pm
hi Fernando .
it is possible to download an earlier version of ferduino french master ?
I explain
in November I tested a version that worked perfectly with my material , and following a bad manipulation :(( I have redeemed all material ( arduino mega , screw shield teak rak , tft shield itead itbd02 2.1 tft lcd screen itead 240x400)
I downloaded the latest version of the installation ferduino this property passes everything works except rct .
the manufacturer of screw shiel said: @ The shield of Pins which are connected the RTC are 21 and 22 (SDA and SDL ) . Removing the battery does not stop the operation of the RTC , it is used only for backup in case of power failure .
I ' tried to connect over the screw sield the V1.1 itbd02 and rct work.
Post Number:#2 Post Tue Dec 09, 2014 3:26 pm
The last update to Ferduino_French was 8 months ago.
Check here: https://github.com/FernandoGarcia/Ferduino_French
The pins for RTC are 20 and 21 not 21 and 22.
Post Number:#3 Post Wed Dec 10, 2014 3:48 am
fernando thank you .
here is the screw shield.
Last edited by Fernando Garcia on Wed Dec 10, 2014 7:40 am, edited 2 times in total.
Reason: Link fixed.
