Forum Software Ferduino code Error during sketch verification
Error during sketch verification  [SOLVED]
Post Number:#1 Post Tue Dec 23, 2014 9:52 am
Belgium
Hello Fernando,
As I received my ethernet shield W5100,I tried to install the new version of Joyreef but I systematically received the same error during sketch verification
This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Mega 2560 or Mega ADK"
Webserver.ino: In function 'void processRequest()':
Webserver:11: error: 'class EthernetClient' has no member named 'getRemoteIP'
Webserver.ino: In function 'void requestAction(byte)':
Webserver:179: error: 'class DS1307' has no member named 'getTimeStamp'
Webserver.ino: In function 'void enviar_dados()':
Webserver:883: error: 'class DS1307' has no member named 'getTimeStamp'
Webserver:922: error: 'class DS1307' has no member named 'getTimeStamp'
I have search in the forum but I can't find an answer.
I have uninstalled Arduino several times and upload the new Joyreef also several times, modified DS1307 library and changed ethernet library by the new one,tried differents IP Address but nothing to do, always the same problem.
Could you once more help me.
Thanks in advance
Best regards,
Jean-Yves
Last edited by Fernando Garcia on Tue Dec 23, 2014 10:00 am, edited 1 time in total.
Reason: Added tags for error code.
Post Number:#2 Post Tue Dec 23, 2014 9:56 am
Post Number:#3 Post Tue Dec 23, 2014 10:20 am
Belgium
Fernando ,
Thanks for the reply but I followed the topic line by line till the end and I can't find where is my error.
The sketch does not pass the verification so I can not upload it in my arduino.
Sorry to bother you but I don't know what to do
Thanks again
Post Number:#4 Post Tue Dec 23, 2014 10:35 am
The solution is explained on link above.
Make sure to save "DS1307.h" and "DS1307.cpp" after changes on code.
Replace your old ethernet library.
Post Number:#5 Post Tue Dec 23, 2014 10:53 am
Belgium
Fernando,
File DS1307 cpp and h are well saved in Arduino library after I modified them( I checked again to be sure ).I have also changed the ethernet library by the new one but nothing to do.
Post Number:#6 Post Tue Dec 23, 2014 1:17 pm
Belgium
I would like to thanks Fernando for the incredible help he gives to me.
What he can do is crazy.
Thank you again
Merry Christmas
Jean-Yves
Post Number:#7 Post Tue Dec 23, 2014 1:24 pm
You're welcome.
Let me list the problems.
1º You can't use IDE from .exe file should be .zip.
2º Even after uninstall the IDE the files with libraries settings remais in .../documents/arduino.
