Forum Software Ferduino code Night mode similar to the pumps Vortech
Post Number:#1 Post Sun May 03, 2015 4:13 am
Hi
follow the directions given by fernendo in a previous post I made a code that makes the night mode similar to so emblazoned Vortech.
during the day the controller carries out the program we selected (1 or 2 or 3 pr 4) and then during the night the two pumps working in continuous mode (both pumps at the same speed) with a power of 45%
This is the code that I created:
add "boolean notturno = false" in this position
  int value = 0;
  long times = millis();
  boolean notturno=false;
  if(modo_selecionado == 1)
after replace all this part
else if(modo_selecionado == 5)
 Pump1PWM = Pump1PWM_temp;
 Pump2PWM = Pump2PWM_temp;
  analogWrite(wavemaker1, Pump1PWM);
  analogWrite(wavemaker2, Pump2PWM);
with this
else if((modo_selecionado == 5)||(notturno==true))
  if((bled_out == 0) && (wled_out == 0) && (rbled_out  == 0) && (rled_out == 0) && (uvled_out == 0))
  notturno=true  ;
   Pump1PWM = 255 ;
   Pump2PWM = 255 ;
  analogWrite(wavemaker1, int(Pump1PWM *0.45));
  analogWrite(wavemaker2, int(Pump2PWM *0.45 ));
    notturno=false;
  analogWrite(wavemaker1, (Pump1PWM ));
  analogWrite(wavemaker2, (Pump2PWM ));
if you want to increase or decrease the power just change the value 0.45 (45%) with the one wanted 0.5 to 50% of the power, and so on
greetings to all
