Forum Software Ferduino code Dosing pumps in custom mode stops running.
Post Number:#1 Post Fri Jun 19, 2015 3:56 am
I am working with ferduino with web control, also runs fine, i am working with sd card in ethernet shield w5100, the joy reef web runs well, the temperature graphs runs well in joy reef web and the tft screen. I was working with the dosing pumps in custom mode, but two days ago stops running, i try to change the start hours but the pumps doesn't runs in custom mode, only runs in manual mode and calibration mode. Where is the problem? i have checked the config in the ferduino's tft lcd screen and also seems well. I post two photos with the graphs and the custom mode dosing pumps config .
I need help please.
Thank a lot.
Post Number:#2 Post Fri Jun 19, 2015 10:38 am
Your SD card isn't working probably.
I can't see any graph on this image.
Check the files on Sd card.
HDP1.TXT, ...., HDP6.TXT and LOGTDIA.TXT.
