Forum Software Ferduino code PH Probe (EZO) Question
PH Probe (EZO) Question  [SOLVED]
Post Number:#1 Post Mon Dec 21, 2015 9:48 am
I would like to use only one pH Probe (EZO Version) from Atlas Scientific for the tank pH values, but I am wondering whether the serial board expander (multiplexer) is required for the pH probe to work. Is there any code that can be used so I do not have to use the Serial Board Expander (The board used for multiple probes)? Thank you.
Good Luck to You!
Post Number:#2 Post Mon Dec 21, 2015 10:35 am
Welcome Michael!
No changes on code is required to use a single stamp without multiplexer.
Only connect the stamp directly in serial port 3.
