Forum Software Ferduino code Error WebControl connection
Error WebControl connection  [SOLVED]
Post Number:#1 Post Sat Feb 13, 2016 8:14 am
Topics: 8
Images: 10
Topics: 8
Good morning, I am not able to set up access to WebControl, when I select "validate settings" in the settings displays the error:
Error #204
- Syntax error, malformed JSON
Your controller sent an answer with wrong format but the changes can have been saved.
Please refresh this page and check the changes.
The problem is in the configuration or on my web server?
In the browser using the local IP information appears.
Thank you.
Post Number:#2 Post Sat Feb 13, 2016 11:59 am
This error can be related with noise in your power supply.
In the tab "Webserver" find this part and uncomment:
      /*#ifdef DEBUG
            Serial.print(F("Socket:"));
            Serial.println(i);
        #endif*/
After upload look for serial monitor to check if you can see something like this:
Socket: 0
Socket: 1
Socket: 2
Socket: 3
I had this problem and was solved adding a capacitor between GND and VIN.
Show me a print screen of your browser using local IP to see if something is wrong.
Are you using latest version available on Github?
Post Number:#3 Post Sat Feb 13, 2016 1:16 pm
Topics: 8
Images: 10
Topics: 8
Presents no socket:
I'm already using the latest version available on Github.
Last edited by Fernando Garcia on Sat Feb 13, 2016 1:51 pm, edited 1 time in total.
Reason: Please use tags [img=left][/img] for all images.
Post Number:#4 Post Sat Feb 13, 2016 1:56 pm
The Json format is right.
There other server replying the requests, I can see this answer:
string(45) "
It works!
Try the port 5000 because the 80 is blocked by many providers.
Post Number:#5 Post Sat Feb 13, 2016 2:09 pm
Topics: 8
Images: 10
Topics: 8
The problem is that when I check other ports in http://ping.eu/port-chk/, only port 80 is open, the others are all closed.
Post Number:#6 Post Sat Feb 13, 2016 2:11 pm
You did port forwarding in your router?
Post Number:#7 Post Sat Feb 13, 2016 7:37 pm
Topics: 8
Images: 10
Topics: 8
Friend, I changed the port to 5000, works with the local IP but the door is not open, now in WebControl displays the error:
Failed to connect to 177.84...... port 5000: Connection refused.
Your controller is not responding.
Please check if your ethernet cable is connected.
Post Number:#8 Post Sat Feb 13, 2016 9:02 pm
The problem is on port forwarding in your router.
Can you show a print screen of the settings in your router?
Post Number:#9 Post Sun Feb 14, 2016 2:38 pm
Topics: 8
Images: 10
Topics: 8
Hi Fernando, my router is an apple airport extreme, that is the port setting configuration. If this router does not work, which the router to recommend?
Last edited by Fernando Garcia on Sun Feb 14, 2016 2:46 pm, edited 1 time in total.
Post Number:#10 Post Sun Feb 14, 2016 3:07 pm
Firstly you should check with your provider to know if the ports are not blocked.
Post Number:#11 Post Wed Feb 17, 2016 11:11 am
Topics: 8
Images: 10
Topics: 8
Ready friend, problem solved, lacked release the door in internet server. Now it is working 100%.
Thank you.
Post Number:#12 Post Wed Feb 17, 2016 11:46 am
