Forum Software Ferduino code Wavemaker mode change when selected
Wavemaker mode change when selected  [SOLVED]
Post Number:#1 Post Sat May 21, 2016 10:37 am
Len Nederlof Random avatar
Hello Fernando,
In my old controller I used THIS program to automatically change the wavemaker modes, this works great.
In my new controller I also want to change the wavemaker modes, but I only want to do that when choosing wavemaker mode 5. If I choose one of the other 4 modes, I want that mode only to work.
I made the following changes:
in ferduino tab on the beginning
// for alternating mode wavemakers
#define alternating_wave
At the end of ferduino tab
unsigned long interval_wave_millis = 0;
int interval_wave = 120; // in minutes
boolean alternated_mode = false ;
in wavemaker tab
 else if (modo_selecionado == 5)
#ifdef alternating_wave
alternated_mode = true ;
#endif
and on Loop tab
  Wavemaker();
#endif
    if (alternated_mode == true )
  if((millis() - interval_wave_millis) > (interval_wave*60000))
    modo_selecionado += 1;
    if(modo_selecionado > 4)
      modo_selecionado = 1;
    interval_wave_millis = millis();
If I choose 1,2,3 or 4, the mode stays the same so that is ok.
If I choose mode 5, the mode of the wave makers starts to change every 2 hours so that is also ok.
But when I choose one of the other modes after mode 5 it keeps changing every 2 hours instead of only the selected mode.
Can you give me advice or help me with this
Kind regards Len
Post Number:#2 Post Sat May 21, 2016 12:10 pm
Try this:
#endif
#endif
Post Number:#3 Post Sat May 21, 2016 3:53 pm
Thank you for the help.
I tried your code, when selecting mode 5 it starts to change the wavemaker modes when selecting an other mode after that it still keeps changing the the different modes.
I think that the problem is in "alternated_mode = true" that stays "true"or wont turn to "false" after selecting a other mode.
Kind regards
Post Number:#4 Post Sat May 21, 2016 4:11 pm
Have you removed this part on code?
    Pump1PWM = Pump1PWM_temp;
    Pump2PWM = Pump2PWM_temp;
  if (wavemaker_on_off == true)
    Pump1PWM = Pump2PWM = 0;
Add some debug messages on loop to see how it is working:
Serial.print("modo_selecionado: ");
Serial.println(modo_selecionado);
Serial.print("alternated_mode: ");
Serial.println(alternated_mode); // 1 = true and 0 = false
Post Number:#5 Post Tue May 24, 2016 11:05 am
Hello Fernando,
I tried the code en debug code.
When i select mode 5 the serial monitor shows
modo_selecionado =5
alternated_mode =1
Then the mode switch to 1, the serial monitor shows
modo_selecionado=1
alternated_mode=0
I tried to get the code to work so that the alternated_mode stays 1 until I select it but i can't get i wright. :(
I tried the folowing
if ((modo_selecionado == 5)&&(alternated_mode == true))
#endif
but than atlternated_mode won't switch of anymore.
Only if i change it to
if ((modo_selecionado == 4)&&(alternated_mode == true))
it switch of after selecting mode 4. :-\
Post Number:#6 Post Tue May 24, 2016 12:10 pm
modo_selecionado =5
alternated_mode =1
modo_selecionado=1
alternated_mode=0
This behaviour is right. The code should work.
Give me all your code in a zip file.
Post Number:#7 Post Sun May 29, 2016 6:17 am
I know that this behaviour is right, and the program works. :)
I wanted to start and stop the automatic mode myself, so I made the following changes.
if  (modo_selecionado == 4)
#endif
I can now select mode 4 to start automatic wavemaker change and if I want it to stop the automatic mode I can select mode 5.
Thanks for the Help.
Post Number:#8 Post Sun May 29, 2016 12:08 pm
This is not good idea because you will lose two modes to manage one.
The option below is better because to stop the interchange is needed only select a mode between 1 and 4.
#endif
Post Number:#9 Post Sat Jun 04, 2016 6:20 am
I understand thats not the best solution becaus I lose 2 modes.
I tried and tried. I even started with a new sketch and tried again.
If I use your example the wavemaker starts and altenated mode is "true"
than automatic mode switch automaticly to mode 1 alternated mode switch off.
I think this is correct because to stop the interchange you need to select a mode between 1 and 4 and this is done by the program
Here is a screenshot of the serial monitor.I only selected mode 5 and run the serial monitor
Kind regards
Len
Post Number:#10 Post Sat Jun 04, 2016 10:32 am
Show me the full code please.
Post Number:#11 Post Sat Jun 04, 2016 3:45 pm
HI,
How can i attach the zip file to the post?
Post Number:#12 Post Sat Jun 04, 2016 3:56 pm
Use the Google drive, One drive or Dropbox and paste the link here.
Post Number:#13 Post Tue Jun 07, 2016 3:54 pm
here is the file
Its is the basic code with the modification for the wavemakers which i tried
Post Number:#14 Post Tue Jun 07, 2016 6:09 pm
Let's start from scratch.
In the Ferduino tab find:
#define USE_TFT
Add after:
#define ALTERNATING_WAVE
Find:
byte Pump2PWM = 0;
Add after:
int interval_wave = 1; // in minutes
On loop find:
Wavemaker();
Add after:
#ifdef ALTERNATING_WAVE
    if ((millis() - interval_wave_millis) > (interval_wave * 60000))
      if (modo_selecionado > 4)
#endif
In the ProcessMyTouch tab on case 10 find:
modo_selecionado = 2;
modo_selecionado = 3;
modo_selecionado = 4;
Add after each line:
alternated_mode = false;
Find:
modo_selecionado = 5;
Add after:
          alternated_mode = true;
#else
#endif
In the Wavemaker tab find:
Replace with:
#ifndef ALTERNATING_WAVE
#endif
Post Number:#15 Post Wed Jun 08, 2016 4:06 pm
Thank you very much for the help,your the best. ^:)^
Kind regards
Len
