Forum Software Ferduino code Enabling PCF8575 disables TFT, have you heard of this?
Enabling PCF8575 disables TFT, have you heard of this?  [SOLVED]
Post Number:#1 Post Fri Nov 11, 2016 10:35 pm
Hello Fernando, I am simply testing with jumper wires some new devices, stamps etc, I just try to test pcf8575 first and when uncommenting to enable use_pcf8575, the TFT does not seem to initialise?
Is this something you have heard before?
It is curious as I see no reason why this should happen..
This is on fresh blank version on the sainsmart 7.0" LCD and the elekfreaks 2.2 tft shield with white colour.
Kind Regards
Jay
PS. I did try some searching to find a reference but there was nothing relating to this..
Post Number:#2 Post Sat Nov 12, 2016 10:02 am
You should have a "#endif" in wrong place.
Post your code on Github or Arduino create so I can help you.
Post Number:#3 Post Sat Nov 12, 2016 2:50 pm
In this circumstance, it is only a clean version strait from zip from your github. Using PCF8575 v2.0
Only changes are enable tft shield, use pin_53 for sd, and skip password screen.
also one change.. from ITDB32WD to CTE50
UTFT myGLCD(CTE50,38,39,40,41)
When I comment-out #define USE_PCF8575, LCD works fine..
Strange huh? :-$
Jay
I think the issue is different, the PCF functions doesn't disables the TFT.
When the Arduino can't connect to a PCF so the code hangs on setup and you get a white screen forever.
Post Number:#5 Post Sat Nov 12, 2016 3:16 pm
Here is a fork from your repo, I have made all the changes I would use as a bare minimum for testing.
https://github.com/jamiebrowncow/Ferdui ... ntrol_beta
So simply, if PCF8575 is not communicating then the code will hang?
I have yet to make the modifications to the board, so this may have been why..
I will just revise what needs to be done and get the soldering iron out and ensure it is connecting correctly. I believe this i will solve the issue.
I felt that, just like if RTC is not connected, this would not be an issue to code running.
You understand every eventuality with your code. =)) Very elite.
Peace, I will report back shortly to let you know that it worked.
Jay
-------------------------------- Last edited Sat Nov 12, 2016 3:41 pm --------------------------------
Okay so I prepared the PCF correctly by addressing it, and sure enough, it works.
Once again thank you very much Fernando.
Post Number:#6 Post Sat Nov 12, 2016 4:16 pm
