Forum Software Ferduino code Inverted function chiller Heather pumps
Inverted function chiller Heather pumps  [SOLVED]
Post Number:#1 Post Tue Jan 10, 2017 6:52 pm
Hello, I'm having a problem... When the heater is activated, I have signal on chiller pin and the opposite too...
When the chiller is activated I have signal on heater pin.
When the temperature is OK.. Activated both of then meanwhile deactivated.
I'm using a 16 relay board.
This problem occurs with some pumps too.. TPA system pumps
Post Number:#2 Post Tue Jan 10, 2017 7:57 pm
Welcome Marcelo!
1 - How the relay board is connected to Arduino?
2 - Have you tested your circuit using a simple code like this?
const byte relayPin = 42;
  pinMode(relayPin, OUTPUT);
  Serial.print("Pin ");
  Serial.print(relayPin);
  Serial.println(": ON");
  digitalWrite(relayPin, HIGH);
  delay(5000);
  Serial.println(": OFF");
  digitalWrite(relayPin, LOW);
  delay(5000);
Post Number:#3 Post Wed Jan 11, 2017 12:22 am
hi, in other topic i told you that i have a problem......
and you give me a code for test.. but how i do it?
put it in a new scketchbook and do upload??
sorry about the simples questions, but i´m beginner of beginner
Post Number:#4 Post Wed Jan 11, 2017 8:41 am
Yes, copy the code to a new sketch then upload.
Open serial monitor and set the baud rate to 9600 to see debug message.
Post Number:#5 Post Wed Jan 11, 2017 9:37 am
Ok.. It's done.
LCD screen is completely white
On the serial monitor 9600 shows me the msg
Pin 42: on
Pin 42: off
Post Number:#6 Post Wed Jan 11, 2017 9:39 am
And what happens with relay connected on pin 42 when the serial monitor says "pin 42 ON"?
Post Number:#7 Post Wed Jan 11, 2017 1:55 pm
5 seconds active
5 seconds off
Post Number:#8 Post Wed Jan 11, 2017 2:24 pm
So if you didn't any change in this values on Ferduino code it should work. There no errors on code to make it work as you are talking.
const byte aquecedorPin = 42;   // Pino que liga o aquecedor
const byte chillerPin = 43; // Pino que liga o chiller
Moreover this function at "Parametros" tab prevent chiller and heater activated simultaneously.
    if ((bitRead(status_parametros, 0) == true)  &&  (bitRead(status_parametros, 1) == true))
      bitWrite(status_parametros, 0, 0);
      bitWrite(status_parametros, 1, 0);
      digitalWrite(aquecedorPin, LOW);
      digitalWrite(chillerPin, LOW);
Post Number:#9 Post Wed Jan 11, 2017 2:35 pm
This configuration is already running, but still inverted the functions.
the code is ok
On relay code i have.. chiller pin 43 powered, Heather pin 42 powered, and pumps pin...A6, A7, A8, powered too
i make a test with ledpinmoon pin 44 - nedd to be not powered because its 15pm... and it´s on... :ymsigh: :ymsigh:
another test with pin 8 led violet.. when the power needs to be on maximun its on minimum ....and when needs to be on minimum its maximum power...
Post Number:#10 Post Wed Jan 11, 2017 2:48 pm
This problem doesn't exists in latest version of Ferduino code.
1 - Check the changes that you did on code;
2 - Don't change the temperature very fast while making tests;
3 - Show me images of your circuit;
4 - Post a video to show the problem including the message on TFT when heater and chiller is activated simultaneously.
Post Number:#11 Post Thu Jan 12, 2017 12:26 am
I have reinstaled de ferduino code... only change the ethernet shield to true and the code of MyGLCD
Boolean_Stamps=false (i do not change this value)
just this changes
i´m waiting 2 minutes to view the result, but in 10 seconds its shows the new one if i had changed
1 conected gnd of relay to gnd of arduino
5v relay to 5v arduino
and the pin 42 to pin 1 of relay
pin 43 to pin 2 of relay
I will post the pictures of the boards and how i conect... maybe there´s something wrong
plug the ethernet making conecting pin 10 to pin 53
disconected pin 10, 11, 12 ,13
disconect pin 50, 51, 52, 53 of tft shield
make a bridge pin 4 to resistor R 16 and disconect one side of it
on this Picture you can see Heather and chiller turned off on the screen and on the relay board ... both of then ...on
Post Number:#12 Post Thu Jan 12, 2017 8:25 am
The question seems very simple, this relay board works with inverted logic.
In others words needs of signal LOW to turn on and HIGH to turn off.
Connect the relay board according to this schematic and don't need change the code:
Notice the TFT says "heater: OFF" and "chiller: OFF" so the code is not turning on any relay.
-------------------------------- Last edited Thu Jan 12, 2017 10:09 am --------------------------------
With an adequate answer to this question, the problem could have been resolved before.
Q: what happens with relay connected on pin 42 when the serial monitor says "pin 42 ON"?
A: The relay is OFF
Q: what happens with relay connected on pin 42 when the serial monitor says "pin 42 OFF"?
A: The relay is ON
Solution: The relay board have inverted logic.
Post Number:#13 Post Thu Jan 12, 2017 10:01 am
Now... It seems to be OK.. I put one uln2003a before the connections to the relay board... Doing as you told.
Thanks for the patience. :D
