Forum Software Ferduino code error stamps and density code
error stamps and density code  [SOLVED]
Post Number:#1 Post Fri Jan 13, 2017 5:57 pm
how solve this error?
C:\Users\Marcelo\Desktop\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta\Webserver.ino: In function 'check_parametro_densidade()':
C:\Users\Marcelo\Desktop\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta\Stamps_V4.ino:142:41: warning: iteration 14 invokes undefined behavior [-Waggressive-loop-optimizations]
         sensorstring[i] = Serial3.read();
C:\Users\Marcelo\Desktop\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta-master\Ferduino_with_webcontrol_beta\Stamps_V4.ino:140:7: note: containing loop
       for (byte i = 1; i <= 15; i++)
-------------------------------- Last edited Fri Jan 13, 2017 7:42 pm --------------------------------
I comment the lines
//#define STAMPS_V4X     // Comente esta linha para usar Stamps EZO
//#define STAMPS_EZO     // Descomente esta linha para usar Stamps EZO
and uncoment this
// Comment the line below if you haven't a stamp for tank pH.
#define USE_STAMP_FOR_TANK_PH // Comente esta linha se você não tem um "stamp" para o pH do aquário.
the error has gone
Using only this
Post Number:#2 Post Fri Jan 13, 2017 7:08 pm
after compile....
another error messages
the sketch use 172.134 bytes (67%) the  storage for programs. The maximum is 253.952 bytes.
Global variables use 4.509 bytes (55%) of  dynamic memmories, leaving 3.683 bytes for local variables. the maximum is 8.192 bytes.
Post Number:#3 Post Fri Jan 13, 2017 7:18 pm
Go to Tools > Board and select Arduino/Genuino Mega 2560
-------------------------------- Last edited Fri Jan 13, 2017 8:21 pm --------------------------------
You can leave this line commented if you haven't a pH stamp from Atlas Scientific.
-------------------------------- Last edited Fri Jan 13, 2017 8:25 pm --------------------------------
This is not an error only an information.
-------------------------------- Last edited Fri Jan 13, 2017 8:32 pm --------------------------------
Another thing, warnings are not errors can be ignored.
Post Number:#4 Post Sat Jan 14, 2017 10:03 pm
I think this problem was solved so I'll close.
