Forum Software Ferduino code Enable pullup pin digital
Enable pullup pin digital  [SOLVED]
Post Number:#1 Post Mon Feb 20, 2017 5:05 pm
Topics: 22
Topics: 22
Hello
I would have the need to activate the resistance of pullup on a arduino digital pins to use it for a sensor but in the ferduino code is not active
const byte sensoreosmosi = 13 ;
pinMode(sensoreosmosi, INPUT_PULLUP);
logically pin 13 I'm using I freed from fanpin on which I assigned another pin
but unplugged always remains low
if I try without the card ferduino code works fine
Post Number:#2 Post Mon Feb 20, 2017 5:41 pm
Firstly I think you should follow this "consiglio" and try learn the basic first.
Secondly this type of problem haven't anything related with Ferduino code so should be asked in Arduino forum.
Thirdly you should read Arduino documentation before ask.
Look for this page: https://www.arduino.cc/en/Tutorial/DigitalPins
NOTE: Digital pin 13 is harder to use as a digital input than the other digital pins because it has an LED and resistor attached to it that's soldered to the board on most boards. If you enable its internal 20k pull-up resistor, it will hang at around 1.7V instead of the expected 5V because the onboard LED and series resistor pull the voltage level down, meaning it always returns LOW. If you must use pin 13 as a digital input, set its pinMode() to INPUT and use an external pull down resistor.
Therefore this behaviour is expected on pin 13.
Post Number:#3 Post Mon Feb 20, 2017 8:25 pm
Topics: 22
Topics: 22
thank you and excuse me
however, I followed the advice I read such a book, but I find it hard to understand how it works equally
