Forum Software Ferduino code Pin 80 - 82
Pin 80 - 82
Post Number:#1 Post Mon Mar 20, 2017 2:33 pm
South Africa
Fernando
I understand that if using the PCF8575, it creates 16 additional IO port, which you then declare as P0 - P15
- this is straight forward and your code is easy to understand/follow..
What I don't yet understand is where pins 80 - 87 (used for timers, and other functions) are coming from?
(defined in setup.ino)
At first I figured pins 80 - 87 are linked to Analogue pins A0 - A14, but then I realised it cant be as this would then conflict to the functions already assigned to these pins (such as dosing pumps)- and I checked the logic to determine if pins 80-87 refer to physical pins on the Mega, but this too seems ilogical.
not sure if this is related to the other users post: viewtopic.php?f=8&t=411#p3134
..from this post it would seem that these are temporary pins that need to be assigned to "free" pins as needed?
been a long day, maybe I have it all wrong, and you can give simple explanation?
Post Number:#2 Post Mon Mar 20, 2017 4:15 pm
Any pin number higher than 69 is fictitious.
Analog pins are 54 to 69.
It's right when you don't have a PCF8575.
When using a PCF8575 you should uncomment the line bellow:
#define USE_PCF8575
Then look for this part of the code:
///************************************** PCF8575 ****************************************************
// Do not change this part if you have not a PCF8575 installed.
// Não altere esta parte se você não tem um PCF8575 instalado.
#ifdef USE_PCF8575 // Do not change this line!
const byte ozonizadorPin = 0;       // P0       // Pino que liga o ozonizador
const byte reatorPin = 1;           // P1       // Pino que liga o CO2 do reator.
const byte bomba1Pin = 2;           // P2       // Bomba que tira água da quarentena.
const byte bomba2Pin = 3;           // P3       // Bomba que tira água do sump.
const byte bomba3Pin = 4;           // P4       // Bomba que coloca água no sump.
const byte temporizador1 = 5;       // P5       // Pino que liga o timer 1.
const byte temporizador2 = 6;       // P6       // Pino que liga o timer 2.
const byte temporizador3 = 7;       // P7       // Pino que liga o timer 3.
const byte temporizador4 = 8;       // P8       // Pino que liga o timer 4.
const byte temporizador5 = 9;       // P9       // Pino que liga o timer 5.
const byte solenoide1Pin = 10;      // P10      // Liga a reposição de água doce.
const byte alimentadorPin = 11;     // P11      // Pino que controla o alimentador automático.
const byte skimmerPin = 12;         // P12      // Pino que controla o skimmer
#endif // Do not change this line!
Forget all lines inside of this "if":
#ifndef USE_PCF8575 // If not defined (uncommented) USE_PCF8575 ignore it.
Any thing here won't be considered!
#endif
Post Number:#3 Post Tue Mar 21, 2017 12:57 am
South Africa
