Forum Software Ferduino code Ethernet Shield and SD Card
Ethernet Shield and SD Card  [SOLVED]
Post Number:#1 Post Fri Jun 16, 2017 8:25 am
Hello,
I am not able to configure the ethernet shield with the SD card. I tried to find a response in the forum but I have not found it and so I ask for help. Summary of the tests I have done:
1 / Test read write SD card using Arduino example "ReadWriteSdfat"
Result:
Correct, read and write without problems.
2 / Proof of IP address assignment by DHCP using the Arduino example "DhcpAddressPrinter"
2.1 Without SD card
Result:
Right, assign IP address of my address range
2.2 With SD card
Result:
"Failed to configure using DHCP"
3 / Test example of Arduino "WebClient"
3.1 Without SD card
Result:
"Connecting ...
Connected
HTTP / 1.1 302 Found
Location: http://www.google.com/search?q=arduino&gws_rd=cr&ei=_pZDWfyECsnSwAKK3JvwBA
Cache-Control: private
Content-Type: text / html; Charset = UTF-8
P3P: CP = "This is not a P3P policy! See https://www.google.com/support/accounts/answer/151657?hl=en for more info."
Date: Fri, 16 Jun 2017 08:29:50 GMT
Server: gws
Content-Length: 278
X-XSS-Protection: 1; Mode = block
X-Frame-Options: SAMEORIGIN
Set-Cookie: NID = 105 = vzLbA5TMDvu9l0gp61wcut12OhH7UuLFls8pRcBBSfd0LWGZDayQFEn0hWyqyg4Hps6gQBOWK1p7h7KfxdtQ4KeziFiu9HB9vH4tDV9uqDGcLR9XAMUCdl90YSsvIzuu; Expires = Sat, 16-Dec-2017 08:29:50 GMT; Path = /; Domain = .google.com; HttpOnly
Connection: close
<HTML> <HEAD> <meta http-equiv = "content-type" content = "text / html; charset = utf-8">
<TITLE> 302 Moved </ TITLE> </ HEAD> <BODY>
<H1> 302 Moved </ H1>
The document has moved
<A HREF="http://www.google.com/search?q=arduino&amp;gws_rd=cr&amp;ei=_pZDWfyECsnSwAKK3JvwBA"> here </A>.
</ BODY> </ HTML>
Disconnecting. "
3.2 With SD card
Result:
"Failed to configure Ethernet using DHCP
Connecting
Connection failed
Disconnecting. "
4 / Test using "Ethernet_shield_with_W5100 by FernandoGarcia
3.1 Without SD card
Result:
Only the serial monitor shows the following line
"Server is at 192.168.1.69"
3.2 With SD card
Result:
5 / Try using "Simple_webserver_running_on_SD_card by FernandoGarcia"
The index.htm file I have created hand on the SD card
Sketch Configuration:
Byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip (192, 168, 1, 69); // IP address, may need to change depending on network
EthernetServer server (80);
Const byte SelectSlave_ETH = 53;
Const byte SelectSlave_SD = 4; // For ethernet shield
// const byte SelectSlave_SD = 5; // For Ferduino Mega 2560
Const byte SelectSlave_RFM = 69; // For Ferduino Mega 2560
5.1 first run with SD card
Initializing SD Card ...
SUCCESS - SD Card Initialized
SUCCESS - Found Index.htm. "
5.2 second run with SD card
"Server is at 223.171.223.255
5.3 Without SD card
ERROR - SD Card Initialization failed "
Last edited by Fernando Garcia on Fri Jun 16, 2017 8:36 am, edited 1 time in total.
Reason: Please use tags [code][/code] to post any code.
Post Number:#2 Post Fri Jun 16, 2017 8:47 am
Welcome Jose!
Your SD card and ethernet shield is working.
The problem with "DhcpAddressPrinter" is related with conflict between SD card and W5100.
The sketch haven't any command to disable the communication with SD card while W5100 is working.
Find:
Add after:
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
It should work.
Regarding others tests, only type this IP (192.168.1.69) on browser to see the result.
Post Number:#3 Post Fri Jun 16, 2017 1:19 pm
Thank you very much for the help, I have the doubt to execute
The first time I run the serial monitor response is
Initializing SD card ...
SUCCESS - SD card initialized.
SUCCESS - Found index.htm file. "
And in the browser to go to 192.168.1.69 appears 1 2 3 4 5 6 which is the contents of the Index.htm file
From the second time I run it modifies the ip address and generates one out of range
"Server is at 255.255.223.255
If I add to the sketch
   "PinMode (SelectSlave_SD, OUTPUT);
    DigitalWrite (SelectSlave_SD, HIGH); "
The IP address 192.168.1.69 is maintained and the results of the execution are the same as the first time.
I do not know if this is the expected behavior.
Sorry for my poor knowledge
Last edited by Fernando Garcia on Fri Jun 16, 2017 8:07 pm, edited 1 time in total.
Post Number:#4 Post Fri Jun 16, 2017 8:13 pm
Dear, I didn't told to add anything to this sketch.
Sometimes is needed press the reset for a while to get right IP.
Try Ferduino code and tell me the result.
Post Number:#5 Post Sat Jun 17, 2017 2:06 pm
Yes, I have tried with the ferduino code and everything works perfectly, thank you very much for the patience and dedication you give to those who like me have very few, to say no knowledge in the matter.
Post Number:#6 Post Sat Jun 17, 2017 4:22 pm
Please don't delete images it can be useful to others users.
