Forum Software Ferduino code Arduino create not working
Arduino create not working  [SOLVED]
Post Number:#1 Post Tue Feb 20, 2018 5:29 pm
codes for testing using Arduino create are not working or web editor has changed, do you have any information on this Fernando?
Post Number:#2 Post Tue Feb 20, 2018 6:01 pm
Are you talking about all codes available here?
Post Number:#3 Post Tue Feb 20, 2018 6:18 pm
Yes, when I try to download they are empty folders, and Arduino Create does not run on my pc for some reason.
Post Number:#4 Post Tue Feb 20, 2018 6:27 pm
Download is working to me. The folder is not empty.
Post Number:#5 Post Tue Feb 20, 2018 6:32 pm
I am not sure what is going on then, I can not download any test codes or anything else. I tried to update the controller today and ran into issues. so I needed the test codes.
just tried 2 other codes and same results, web editor will not come up for me, I can not download the app from App store, I am at a lose here.
-------------------------------- Last edited Tue Feb 20, 2018 3:59 pm --------------------------------
Can not sign in on tabs eather.
-------------------------------- Last edited Tue Feb 20, 2018 4:31 pm --------------------------------
is github up to date?
Post Number:#6 Post Tue Feb 20, 2018 7:39 pm
I don't know why the upload via browser is not available.
You can create an account the copy the code to your sketchbook.
You should install the plugin: http://create.arduino.cc/getting-started/plugin?page=2
Anyway you can copy the code and paste in Arduino IDE.
Post Number:#7 Post Tue Feb 20, 2018 8:00 pm
I have tried three times to install the plug in and will not work either, I am doing some work on chrome to see there is a problem there.
Post Number:#8 Post Wed Feb 21, 2018 8:55 am
The upload via embedded code is not available.
http://forum.arduino.cc/index.php?topic=430276.0
Post Number:#9 Post Wed Feb 21, 2018 7:40 pm
Hi, yes I found that out after some searching on their side of things, so I did as you suggested with copy and paste but it has to be highlighted Ctrl+c and Ctrl+p, there is nothing when I do right click on the code from forum.
