Forum Software Ferduino code Can´t configurate Dosing Pumps
Can´t configurate Dosing Pumps  [SOLVED]
Post Number:#1 Post Thu Jul 11, 2019 6:51 pm
Hello, I need some help here.
I recently upgraded the version of my ferduino (DIY) to the most recent one found on the site. But after upgrading, I can no longer configure the dosing pumps. I even setup the Dosing Pumps> Custom menu, but when I go to the Scheduled Dosage menu, only pump 1 displays the scheduled times. All the others show Not Activated ... and the ferduino stops responding ... I already followed the tips of several posts of other users here of the forum and nothing solved. Another thing that happens is that the touch stops responding after a few touches on the screen.
Thank you for any help.
I take this opportunity to congratulate you on this great work, the ferduino
Post Number:#2 Post Thu Jul 11, 2019 8:29 pm
Welcome Leonardo!
Thanks for kind words!
Can you set up the dosing pump via TFT?
Can you see the pumps activated on this menu?
Can you see the files HDP1.TXT, ..... HDP6.TXT on SD card?
Can you see this messages on serial monitor after open dosage schedule in web interface?
Post Number:#3 Post Fri Jul 12, 2019 8:17 am
Hi, good morning.
Q: Can you set up the dosing pump via TFT?
A: No, the interface freezes when I access this menu and does not accept any touch
Q: Can you see the pumps activated on this menu?
A: Same answer above
Q: Can you see the files HDP1.TXT, ..... HDP6.TXT on SD card?
A: I was not finding these files but after replacing the reader and SD card, they were created.
Q: Can you see this messages on serial monitor after open dosage schedule in web interface?
A: Yes I can, but the interface freezes after this.
Post Number:#4 Post Fri Jul 12, 2019 12:10 pm
It happens in any menu?
You are using WiFi right? Why you are not using SD slot on TFT?
Post Number:#5 Post Fri Jul 12, 2019 1:53 pm
Yes, this is happening on any menu. The touch stops responding after a while... This does not happen in a sketch test...
Yes, I'm using a wi-fi. But I never thought about why using an external SD card reader (my fault) instead of the display card reader. I bought the components of a friend and he had made it this way. But I had to redo the whole assembly and ended up still using the external reader. Do you think this could be the cause of the malfunction?
I'm sorry, but my English is not good for writing...
Best Regards.
Post Number:#6 Post Fri Jul 12, 2019 4:08 pm
It should be the problem. Remove the external reader and make sure that options on code are suitable.
Don't worry about your english. I don't speak english too.
Post Number:#7 Post Fri Jul 12, 2019 7:16 pm
I had make the changes sugested by you and until now, its working perfectly. I will left in test for few hours to have sure.
Thank you a lot!
Post Number:#8 Post Sat Jul 13, 2019 11:25 am
