Forum Software Ferduino code Automatic wave maker mode change
Automatic wave maker mode change  [SOLVED]
Post Number:#1 Post Wed Jul 02, 2014 4:49 pm
Fernando,
how easy would it be to make the wave maker change modes every 2 hours, make it programmable to run a specific mode for a set amount of time, then run in another mode and continually change modes ?
I think the randomness would be nice for the tank so it get's a different wave pattern every so often
Post Number:#2 Post Wed Jul 02, 2014 6:38 pm
You can make it using a method very simple.
Add in ferduino tab:
unsigned long interval_wave_millis = 0;
int interval_wave = 120; // in minutes
boolean alternated_mode = true;
Add on loop:
if(alternated_mode == true)
  if((millis() - interval_wave_millis) > (interval_wave*60000))
    modo_selecionado += 1;
    if(modo_selecionado > 5)
      modo_selecionado = 1
    interval_wave_millis = millis();
Post Number:#3 Post Wed Jul 02, 2014 7:39 pm
awesome, OK I added this to the ferduino tab at the very bottom as below
  215, 210, 205, 200, 190, 185, 180, 175,   //16 - 17
  170, 165, 160, 160, 160, 150, 145, 140,   //18 - 19
  135, 130, 125, 115, 100, 75, 60, 30,      //20 - 21
  30, 30, 28, 28, 0, 0, 0, 0                //22 - 23
byte *cor[5] = {wled, bled, rbled, rled, uvled};
byte *cor_canal[5] = {cor_canal1, cor_canal2, cor_canal3, cor_canal4, cor_canal5};
/************* automatic mode change for wavemaker *************************/
OK I got it now, you have an [ ; ] missing in the above code Fernando :D
I add to loop.ino like below
  Wavemaker();
      modo_selecionado = 1;
  if (dispScreen == 10) // Desenha os gráficos enquanto o menu estiver aberto.
    Grafico_WaveMaker();
  if (millis() - previousMillis > 5000)  // Verifica as funções a cada 5 segundos.
changed time to 1 minute and tested, the screen on the Ferduino display remains as is but the bar graph changes as the mode changes very nice man thank you
