Forum Members section Show your controller My Ferduino DIY
My Ferduino DIY
Post Number:#1 Post Mon Dec 15, 2014 4:58 pm
Belgium
Hello Fernando,
Here 2 pictures of my ferduino PCB (sorry for the poor quality).
Dosing pump
PH stamp
Float switch
Working correctly
Relays 1 and 2
LED
Fan control
Not yet tested
Once again thanks for your help
Best regards,
Jean-Yves
Post Number:#2 Post Mon Dec 15, 2014 5:07 pm
Great job!
I think that someone is trying copy my Ferduino Mega :D
Do you are using the version with web control?
Can you tell me where found this float switches with long cable and temperature sensors with plastic isolation?
Post Number:#3 Post Mon Dec 15, 2014 5:50 pm
Belgium
Fernando,
No panic it's impossible to make a copy as perfect as your board.
I only did it for myself to simplify all the wiring.
I have to add that it's far away from the quality of your board but as I follow your project since the beginning I had all the required components that are now integrated in Ferduino board.
I am using Joy-reef but the function has not been tested with the board because I use an ENC28J60 as ethernet shield and I have ordered a W5100 to try with the new version of webcontrol.
Here is the ref. for float switch http://www.reef-ocean.com/produit/index/?pid=31335
Sorry but for the temp sensor I don't remember.
Best regards,
Jean-Yves
Post Number:#4 Post Mon Dec 15, 2014 5:54 pm
I was joking :D
Thanks for link. It's very expensive :(.
Post Number:#5 Post Mon Dec 15, 2014 6:04 pm
Belgium
I understood.
Yes they are expensive.
For the temp sensor you can make an internet seach with " DS18B20 waterproof " you'll find some.
Jean-yves
Post Number:#6 Post Tue Dec 16, 2014 8:30 am
I can find the probes but, not with good price.
You'll add some material to protect the copper surface of your board?
Post Number:#7 Post Tue Dec 16, 2014 11:53 am
Belgium
Hello
Yes I will protect the circuit with special varnish but I have first to modify the buzzer circuit ( don't know how ) that was made following the shematics provided in Ferduino Mega but I saw yesterday that there is a difference with the circuits in the forum.
Best regards,
Jean-Yves
Post Number:#8 Post Tue Dec 16, 2014 1:37 pm
Don't worry.
The circuit will work fine with trimmer of 10K.
Post Number:#9 Post Tue Dec 16, 2014 2:12 pm
Belgium
Post Number:#10 Post Sun Apr 19, 2015 10:30 pm
Indonesia
Post Number:#11 Post Mon Apr 20, 2015 6:23 am
Belgium
Hello Diztly,
Here is a side view of the assembly
This board was made to mount the different shield on it (from bottom to top you have arduino mega, ethernet shield ,diy shield, ITDB 02 shield and the TFT LCD ).
Basically its is the same shield but more complete that the one Fernando recommends in the part list ( the green one ).
jean-yves
Post Number:#12 Post Mon Apr 20, 2015 11:38 pm
Indonesia
Post Number:#13 Post Sat Apr 25, 2015 5:25 pm
Belgium
Hello Fernando ,
I have added some picture in my album, I will make a complete presentation later because the post that I had just prepared has disappeared from the forum and it is a lot of work to do it again.
Best regards,
Jean-Yves
Post Number:#14 Post Sun Apr 26, 2015 10:14 am
Great job!
I'm waiting to see more details.
Post Number:#15 Post Sun Apr 26, 2015 1:02 pm
Belgium
Hello Fernando ,
Some short comments on the pictures of my Ferduino.
Stamps box
Inside of the box
Finished box
Dosing pumps box made from electrical trunking
All pumps installed
Box finished
Relays 1 box
For this, I used 2 multiple outlet modified so that each outlet is independent and controlled by relay( except one which is always powered ).
Here the 2 multiple outlet fixed in the box
In the second half of the box,I fixed the relays board and the step down converter used to power the relays and the 6v outlet for the ATO pump.
Hot wire for the relays
Hot wire installed
Just before closing the box with everything connected
Box finished
Ferduino box
Front view
Left side
Rear side
Right side
Cover
All together
Working Ferduino
Best regards,
Jean-Yves
Post Number:#17 Post Sun Apr 26, 2015 2:45 pm
An acrylic frame like this should be nice. :)
Post Number:#18 Post Sat May 02, 2015 6:24 am
Post Number:#19 Post Mon May 04, 2015 12:22 pm
wow that looks great you did a really good job on the boards and also on the cases are the silk screened ? how did you do the lettering on the box's?
Post Number:#20 Post Mon May 04, 2015 2:34 pm
Belgium
Hello,
Thanks for the comments.
The boxes have been covered with transparent adhesive film.
The software used is Front Panel Designer from schaeffer ag.
http://www.schaeffer-ag.de/en/downloads ... _designer/
Very easy to use and freeware.
Best regards,
Jean-Yves
