Post Number:#141 Post Tue Feb 03, 2015 10:28 am
Post Number:#142 Post Tue Feb 03, 2015 7:05 pm
Topics: 12
Topics: 12
Netherlands
Just change the nivel code. What I did was build a float switch and put it on channel 6. Then alter the nivel code so it only monitors channel 6 plus i altered the low text to high. So now when my return pump fails it will trigger the float and the level text will change from normal to high. Plus i altered the code so it puts 25 at reactor ph when triggered and 0 when all is well. I then set the alert on joy reef for the ph reactor. So now when my return pump fails i get a warning form joy reaf my reactor ph is wrong. Quick and dirty solution but it gets the job done.
Post Number:#143 Post Tue Feb 03, 2015 10:52 pm
Hi Fernando, I was working with the code this morning and had a JAVA error come up has any one else had this issue, the error reads.
Post Number:#144 Post Wed Feb 04, 2015 1:46 am
Post Number:#145 Post Thu Feb 05, 2015 12:32 am
Hi Fernando I tried to run 12 volts on the board again and no luck am I doing some thing wrong, I have 12volt positive and ground at the power port and now nothing is working every thing comes on when power on and stays on.
Post Number:#146 Post Tue Feb 10, 2015 5:25 am
new pump temp setup.
so this my new pump after a failure of my 1. year old internal retun pump.
-------------------------------- Last edited Tue Feb 10, 2015 2:37 am --------------------------------
and also another full on sour note dont let a 12 volt line touch the back of the heat sink on the board, I was working with unit cleaning some stuff up and one my kiddos moved some wires to get some thing off my desk and zap, I was able to do as fernando suggested and remove all components and turn it into a shield but some things are not quite right so new board here I come :|
Post Number:#147 Post Thu Feb 12, 2015 1:29 am
Hi Fernando are EC and density going to be the same code in ferduino I just received my probe and would like to set it up, also is there a calibration code for EC or do I use atlas code? I did check in some topics and did not see any thing specific.
Post Number:#148 Post Thu Feb 12, 2015 6:41 am
Why you need of EC and SG?
The code is ready to SG.
To calibration you need use the test code.
Post Number:#149 Post Thu Feb 12, 2015 7:29 am
Just wanted to make sure that there was nothing specific I had to do before using the ec probe, and it connects to number 3 stamp, correct?
-------------------------------- Last edited Thu Feb 12, 2015 4:29 am --------------------------------
-------------------------------- Last edited Thu Feb 12, 2015 4:30 am --------------------------------
Post Number:#150 Post Thu Feb 12, 2015 7:31 am
Post Number:#151 Post Thu Feb 12, 2015 7:35 am
Post Number:#152 Post Thu Feb 12, 2015 7:39 am
You'll buy my relay board?
The cable isn't needed on this case because goes together.
I'll get the relay board in next week probably.
Last edited by Fernando Garcia on Thu Feb 12, 2015 7:40 am, edited 1 time in total.
Reason: Spelling
Post Number:#153 Post Thu Feb 12, 2015 7:58 am
I will still need a cable, relay board is going to be in a gang box with the out lets so there is no power interference between the to types of voltages. Do you have a price for the relay board yet?
-------------------------------- Last edited Thu Feb 12, 2015 4:59 am --------------------------------
Post Number:#154 Post Thu Feb 12, 2015 8:10 am
I'll have in the next week.
Post Number:#155 Post Thu Feb 12, 2015 2:41 pm
I know why it double post , when I back out on my phone it re posts for some reason. EC stamp making things unstable :((
and I am looking forward to the relay board :D, do you have an eagle or gbr file of the board I am having a hard time to fallow the other schematic I am trying to find a common thing between all the issues from when the board was shorted, so fare I have the RX issue with Ethernet communication when EC stamp is plugged in it makes the board unstable and that's' it so far.
Post Number:#156 Post Thu Feb 12, 2015 5:32 pm
Sorry, I can't give this files.
Post Number:#157 Post Thu Feb 12, 2015 8:01 pm
Post Number:#158 Post Thu Feb 12, 2015 9:36 pm
Only the GND because stamps are 5V and ethernet 3.3V.
Post Number:#159 Post Fri Feb 13, 2015 7:59 am
Post Number:#160 Post Fri Feb 13, 2015 9:04 am
The EC stamp works fine with test code?
Which type of instability do you have?
Users viewing this topic: No registered users and 5 guests
