Forum Members section LED light and others Multi chip 5 channel led
Multi chip 5 channel led  [SOLVED]
Post Number:#1 Post Thu Feb 19, 2015 7:20 am
Hi Fernando I have my lights setup but I am having an issue, when 4 channels are on they will run at 100%, when I add the 5th channel the all go dim then offat 100%. Here are the specs.
SPECIFICATIONS:
Channel 1: EPISTAR ES-CADBV45P 45*45mil 4500K x 10 chips  (32-34V @ 350mA-500mA)
Channel 2 : EPISTAR ES-CADBV45P 45*45mil 455nm Royal Blue x 10 chips (32-34V @ 350mA-500mA)
Channel 3 : EPILEDS EP-U4545K-A3 45*45mil  430nm Violet(UV) x 10 chips (32-34V @ 350mA-500mA)
Channel 4 : EPILEDS BH-R4242D-A1 42*42mil 660nm x 5 chips + Epistar ES--CADBV45P 490nm x 5 chips (27-29V @ 350mA-500mA)
Channel 5 : EPILEDS EP-U4545K-A3 45*45mil 410nm  (32-34V @ 350-500ma
48 Volt
7.3 Amp
350 Watt
87.5% Efficiency
Meanwell 5 up board with ldd500h drivers
Post Number:#2 Post Thu Feb 19, 2015 8:13 am
This power supply is regulated to how many volts?
The GND from board is connected with GND (- 48V) from power supply?
Which menu you are using to test it?
Post Number:#3 Post Thu Feb 19, 2015 8:23 am
I am using the test leds in ferduino menus, yes ground is connected (-48), and if at max is running 49 volts.
Post Number:#4 Post Thu Feb 19, 2015 8:38 am
Why 49V?
The LEDs need of 29V or 34V the LDD need of 3V only.
Try adjust the voltage to 37V and add a resistor to channel 4.
R = (34 - 29) / 0.500
R = 10 Ohms
P = 0.500 * (34 - 29)
P = 2.5 Watt.
Post Number:#5 Post Thu Feb 19, 2015 8:42 am
What size resistor? It would go in between the 500ldd and the LED correct.
Post Number:#6 Post Thu Feb 19, 2015 10:14 am
Put between LED and LDD and check if you can control the power of 0 - 100 % otherwise put between power supply and LDD.
Maybe is needed change the value of resistor. I'm not sure about how many mA is needed to LDD.
Post Number:#7 Post Thu Feb 19, 2015 11:29 am
Ok Fernando thank you for the reply, I will check it out when I get home this afternoon.
Post Number:#8 Post Sun Feb 22, 2015 12:31 pm
must have ground from 5up back to ferduino, when there is a supply there must be a return. oops.
