Post Number:#241 Post Wed Sep 30, 2015 11:36 pm
Post Number:#242 Post Wed Sep 30, 2015 11:37 pm
With 4.6 V will work normally.
-------------------------------- Last edited Wed Sep 30, 2015 11:41 pm --------------------------------
I'll make other project for isolation.
Post Number:#243 Post Thu Oct 01, 2015 12:11 am
I have a CNC router I want try to do a pcb on if you want to send eagle file I can try and see if it works?or I can work on a board of my own to B-)
Post Number:#244 Post Thu Oct 01, 2015 12:06 pm
Post Number:#245 Post Thu Oct 01, 2015 5:24 pm
My project is based on this shield. :D
I have all done.
Can you make a PCB with 2 layers?
Post Number:#246 Post Thu Oct 01, 2015 6:58 pm
As long as I have proper .dxf file yes I can do 2 sided pcb. Would prefer to have file in g-code but not everyone can transfer it.
Post Number:#247 Post Fri Oct 02, 2015 1:21 am
Fernando that is a great looking board I was wondering does it only support ezo chips or does it also do 5.0 can you run ez and 5.0 at the same time? the regular uart board has problems when doing that and a EC chip but we all know that and there new board is very costly
Post Number:#248 Post Fri Oct 02, 2015 9:50 am
It should work with any stamp using UART.
Have individual isolation for stamps.
Post Number:#249 Post Mon Oct 05, 2015 1:18 pm
Post Number:#250 Post Mon Oct 05, 2015 3:47 pm
Using old or new board?
Post Number:#251 Post Tue Oct 06, 2015 7:34 am
The new one, I also have an issue I will figure out on my own brand new ec stamp makes the bord freak out when plugged in so I set it up on another arduino and can't get it to connect with any code I have tried.
Post Number:#252 Post Tue Oct 06, 2015 10:03 am
Changed the baud rate to 38400 on new stamp?
Post Number:#253 Post Tue Oct 06, 2015 10:09 am
Post Number:#254 Post Tue Oct 06, 2015 10:16 am
Using the code for test change this line:
Serial3.begin(38400);
Serial3.begin(9600);
After send SERIAL, 38400 change the code to 38400 again.
Don't forget to change the terminator on serial monitor to carriage return.
Post Number:#255 Post Tue Oct 06, 2015 11:41 am
Post Number:#256 Post Tue Oct 06, 2015 12:03 pm
Which slot are you using on Ferduino Mega?
Post Number:#257 Post Tue Oct 06, 2015 3:57 pm
Post Number:#258 Post Tue Oct 06, 2015 4:37 pm
Are you using a multiplexer?
What you tink about post a step by step here: viewtopic.php?f=24&t=96 ?
Post Number:#259 Post Tue Oct 06, 2015 4:49 pm
I got it to work on separate Arduino I will post step by step and add comment tomorrow I have get to bed for work tonight :-B
No multiplexer just prototype shield and Arduino Mega 2560.
1) 5 volt from 2560 to VCC on stamp.
2) ground to ground
3) TX3 from 2560 to RX on stamp.
4) RX3 from 2560 to TX on stamp.
5) Connect USB to 2560.
open IDE>open file EZO Mega> keep BAUD rate the same (9600) for the first load of code> load code> open serial monitor> send this: serial,38400<cr> next in IDE change the SERIAL(9600) to SERIAL(38400) load new code to 2560 open the serial monitor change baud rate to 38400 and send this c,0 to stop constant read then send this (serial,?<cr>) response should be (?*OK,38400)
THIS WAS NOT DONE ON FERDUINO BOARD WAS ON A STAND ALONE 2560 AND PROTOTYPE SHIELD.
Last edited by Christopher Kindig on Tue Oct 06, 2015 5:14 pm, edited 1 time in total.
Post Number:#260 Post Tue Oct 06, 2015 4:56 pm
Have you connected TX to RX and RX to TX?
Users viewing this topic: No registered users and 28 guests
