Forum Software Ferduino code A few questions
A few questions  [SOLVED]
Post Number:#21 Post Wed Jun 08, 2016 4:47 pm
Topics: 11
Topics: 11
All I get is the same as before
IP server: 192.168.1.58
Free memory: 4999
Sensor 2: 1023
Sensor 3: 1023
Sensor 4: 1009
Free memory: 4999
Sensor 2: 1023
Sensor 3: 1023
Sensor 4: 1009
Free memory: 4999
Sensor 2: 1023
Sensor 3: 1023
Sensor 4: 1007
and it just keeps repeating. Yes I have TFT disabled.
Post Number:#22 Post Thu Jun 09, 2016 3:19 pm
It happens when the TFT is enabled?
Post Number:#23 Post Fri Jun 10, 2016 4:51 pm
Topics: 11
Topics: 11
Exactly the same with tft enabled. same with watchdog on and off #-o
Post Number:#24 Post Fri Jun 10, 2016 5:29 pm
Try this changes:
1 - Disable the watchdog;
2 - In the tab webserver find:
#ifdef DEBUG
    Serial.println(F("Can't connect!"));
#endif
    client.flush();
    client.stop();
Add after:
    notconnected++;
    if (notconnected == limite_falha)
      start_ethernet();
      notconnected = 0;
It will restart the W5100 setup without reboot.
Leave the serial monitor opened to see what happens when the upload stops. Maybe you will see "can't connect" sometimes before.
Check if after the re-setup the IP on serial monitor is right.
Post Number:#25 Post Wed Jun 22, 2016 10:13 am
Topics: 11
Topics: 11
I have done this and been testing it for a few days with limite_falha set to 10 (20 minutes) and have been getting emails roughly each day saying its stopped sending, followed by another email 10 minutes later saying its working again so this seems to have fixed the error :D i will change it to 8 when I get chance and this should keep it going without emails so I only get emails if there is a new problem.
I have ordered a new screw shield and ethernet shield as well just incase my ethernet is at fault and to tidy it up so fingers crossed this will be out of test soon and properly running the tank.
Thank you again for all your help. You have done a sterling job creating this software :-bd
Post Number:#26 Post Wed Jun 22, 2016 12:29 pm
Glad to hear.
Post Number:#27 Post Tue Jul 05, 2016 10:24 am
Topics: 11
Topics: 11
I have had this running fine now for 9 days and I have checked it today and it hasnt dosed since yesterday, the container settings are the same as yesterday and now the shcedule is not activated. The only way I can get this properly working again is by hard reset. The bigger problem though is I want to be able to leave this controller to itself but there is no notification setting or alert for if something like this happens and if it doesnt dose for a week or so because I am not aware, it could cause damage to corals.
Can you suggest what might cause this and how I can get an alert for status changing to not scheduled on each doser - all dosers that were active (4 of the 6) have changed to not scheduled.
Post Number:#28 Post Tue Jul 05, 2016 11:46 am
The "custom dosage settings" is showing all pumps disabled?
It seems problem with SD card, when the schedule table shows "not activated" is because the text file was not found on SD card.
Check is there any bad contact in the bridge between pin 10 (ethernet shield) and pin 53 (Arduino).
Regarding the alerts I have to think about.
Post Number:#29 Post Tue Jul 05, 2016 12:05 pm
Topics: 11
Topics: 11
On the custom settings it is showing pumps 1,2,3,4 enabled 5,6 disabled.
I will check the wires in case that has come loose.
Guy
Post Number:#30 Post Sat Jul 09, 2016 10:25 pm
The alert for custom dosage is available now, update your code.
Post Number:#31 Post Sat Dec 03, 2016 8:42 am
Is it a possible voltage issue like what I was having for some time, I found if at 5 volts there where issues, at 7 volts no issues, just a thought.
Post Number:#32 Post Sun Jan 15, 2017 10:08 pm
Have you gave up of your controller?
Did you a try with latest version using MQTT protocol?
Post Number:#33 Post Wed Sep 05, 2018 6:42 pm
Topics: 5
Topics: 5
edit on the below
... I have both stamp types (ezo / v4x).
I suppose the V4X are an alternative to the EZO. Please, where is there information about the V4X ?. I have not been able to find anything on Google.
Thank you.
Post Number:#34 Post Wed Sep 05, 2018 7:52 pm
Not, the V4.x is an obsolete version and was replaced by EZO.
I'll close this topic since the questions were answered.
If needed please create a new topic.
