Forum Software Ferduino code WaveMaker alternated with storm
WaveMaker alternated with storm  [SOLVED]
Post Number:#1 Post Mon Jun 09, 2014 9:30 am
Hi
In my older arduino, i has modified wavemaker for an alternated and storm.
I tried to copy the code to put in place of mode 4 in Ferduino code and i have add the night mode.
i am newbie in devellopement arduino and I can not find "periodo"
but "periodo" is too long, how I can change it to 700, 800, 900, for an example
 else if(modo_selecionado == 4)
   switch (cmode){
     case 0: times = millis();
    value = int(128 + 127 * sin(2 * PI / periodo * times));
    Pump1PWM = 0;
    Pump2PWM = value;
   if(value == 255){cmode = 1;} // при достижении уровня 253 - перейти к case 1
     break;
      case 1:
    times = millis();
     Pump1PWM = value;
     Pump2PWM = 0;
   if(value == 253){cmode = 2;} // при достижении значения уровня 253 - перейти к case 1
    break;
    case 2: times = millis();
     Pump1PWM = 255;
     Pump2PWM = 0;
  if(value == 100){cmode = 3;}
    break;
    case 3: times = millis();
      Pump1PWM = 0;
      Pump2PWM = 255;
  if(value == 100){cmode = 4;}
    break;
    case 4: times = millis();
     Pump1PWM = value;
     Pump2PWM = 0;
  if(value == 255){cmode = 5;}
    break;
    case 5: times = millis();
     Pump1PWM = 0;
     Pump2PWM = value;
  if(value == 255){cmode = 6;}
    break;
    case 6: times = millis();
     Pump1PWM = 255;
     Pump2PWM = 255;
  if(value == 252){cmode = 7;}
    break;
    case 7: times = millis();
     Pump1PWM = 0;  // 255
     Pump2PWM = 0;  // 255
  if(value == 20){cmode = 0;}
    break;
  else if(modo_selecionado == 5)
 Pump1PWM = Pump1PWM_temp;
 Pump2PWM = Pump2PWM_temp;
  if(Pump1PWM > 255)
    Pump1PWM = 255;
  else if(Pump1PWM < 0)
    Pump1PWM = 0;
  else if(Pump2PWM > 255)
    Pump2PWM = 255;
  else if(Pump2PWM < 0)
    Pump2PWM = 0;
if((bled_out == 0) && (wled_out == 0) && (rbled_out  == 0) && (rled_out == 0))
  analogWrite(wavemaker1, int(Pump1PWM * 0.50));
  analogWrite(wavemaker2, int(Pump2PWM * 0.50));
  analogWrite(wavemaker1, Pump1PWM );
  analogWrite(wavemaker2, Pump2PWM );
Thank you in advanced
Post Number:#2 Post Mon Jun 09, 2014 9:48 am
Here you can change the step and the interval:
https://github.com/FernandoGarcia/Fedui ... .ino#L1061
          duracao -= 1000;
          if(duracao < 1000)
            duracao = 5000;
Example:
          duracao -= 100;
          if(duracao < 100)
            duracao = 5000;
Post Number:#3 Post Mon Jun 09, 2014 10:22 am
thank again ^:)^
I have changed "duraco" par "periodo" in Procesmytouch.ino
        if ((x>=peRB[0]) && (x<=peRB[2]) && (y>=peRB[1]) && (y<=peRB[3]))  // Duração do intervalo -
          //waitForIt(peRB[0], peRB[1], peRB[2], peRB[3]);
          periodo -= 100;
          if(periodo < 100)
            periodo = 5000;
          waveScreen();
        else if ((x>=peRC[0]) && (x<=peRC[2]) && (y>=peRC[1]) && (y<=peRC[3]))  // intervalo +
          //waitForIt(peRC[0], peRC[1], peRC[2], peRC[3]);
          periodo += 1000;
          if(periodo > 5000)
            periodo = 1000;
          waveScreen();
and changed in L_Menu Modo 4 =periodo
 if((modo_selecionado == 1) || (modo_selecionado == 2)|| (modo_selecionado == 4))
    myGLCD.print("     ", 75, 145);
    myGLCD.printNumI(periodo, 75, 145);
  else if((modo_selecionado == 3))
    myGLCD.print("    ", 85, 150);
    myGLCD.printNumI(duracao, 85, 150);
The difficult for me, it's for one fonction they are three ways: fonction, graphic and touch, that my loses some ~x(
Post Number:#4 Post Mon Jun 09, 2014 10:37 am
You need change here also:
        periodo += 1000;
          if(periodo > 5000)
            periodo = 1000;
Post Number:#5 Post Mon Jun 09, 2014 11:07 am
No When i changed also "duraco" by "periodo" touch is ok, but but the display does not follow.
when i changed L_menu, it's good
Post Number:#6 Post Mon Jun 09, 2014 11:18 am
I don't understand what you mean.
Some images can help.
Post Number:#7 Post Mon Jun 09, 2014 11:21 am
nothing is good
I think it works
Post Number:#8 Post Mon Jun 09, 2014 1:34 pm
There is a bug in the code that I added the switch case 0: to case1: to case 2: .... do not work, it's don't switch
Can you take a look that if you see a problem ? "value== 255"
   switch (cmode){
    Pump1PWM = 0;
    Pump2PWM = value;
     break;
      case 1:
    times = millis();
     Pump1PWM = value;
     Pump2PWM = 0;
    break;
     Pump1PWM = 255;
     Pump2PWM = 0;
    break;
Post Number:#9 Post Mon Jun 09, 2014 1:46 pm
This is a question of probability.
What's the probability of "value" be 255 to this equation?
Post Number:#10 Post Mon Jun 09, 2014 1:54 pm
Good question, i don't know, the original value=253, but i want Pump1PWM for 20 minutes after Pump2PWM for 20 minutes ...
On Jarduino was work but equation is different "value = 128+127*cos(2*PI/periode*(times-(starttime+startvalue))); "
Post Number:#11 Post Mon Jun 09, 2014 3:03 pm
The probability is 1 / 127 or 0.7874 %. ;)
Post Number:#12 Post Mon Jun 09, 2014 3:11 pm
yes it's very difficult but i have tested with value ==100, it's same problem
i tried with millis but it's difficult for me.
if((millis() - temps) > 1800000) ... ~x(
   switch (cmode){
    Pump1PWM = 0;
    Pump2PWM = value;
   if((millis() - temps) > 1800000){cmode = 1;}
   temps = millis();
   break;
      case 1:
    times = millis();
     Pump1PWM = value;
     Pump2PWM = 0;
   if((millis() - temps) > 1800000){cmode = 2;}
    temps = millis();
    break;
Post Number:#13 Post Wed Jun 11, 2014 5:08 pm
Hi, if anyone can help me ?
thank you
Post Number:#14 Post Wed Jun 11, 2014 5:17 pm
Try this:
 cmode = 1;
  temps = millis();
   break;
You need wait 30 minutes to see the result or change the interval.
Post Number:#15 Post Wed Jun 11, 2014 6:05 pm
Hi Fernando
I tried but don't switch to case 1:
void Wavemaker()
  long temps = millis();
  int cmode = 0;
  int value = 0;
  long times = millis();
   switch (cmode){
    case 0:
    Pump1PWM = 0;
    Pump2PWM = value;
   if((millis() - temps) > 18000)
     cmode = 1;
     temps = millis();
     break;
    case 1:
    Pump1PWM = value;
    Pump2PWM = 0;
     cmode = 0;
     temps = millis();
     break;
I tried several way and it never switches !!!!
Post Number:#16 Post Wed Jun 11, 2014 6:10 pm
You can't put this variable as local.
Should be global variable.
Put here:
https://github.com/FernandoGarcia/Fedui ... a.ino#L886
After:
byte Pump2PWM = 0;
Post Number:#17 Post Wed Jun 11, 2014 6:16 pm
this variable also ?
int cmode = 0;
Last edited by Sueur Aurelien on Wed Jun 11, 2014 6:19 pm, edited 1 time in total.
Post Number:#18 Post Wed Jun 11, 2014 6:18 pm
this variable too ?
int cmode = 0;
Yes.
Post Number:#19 Post Wed Jun 11, 2014 6:23 pm
YEAHHHH!!!!! :-bd
A BIG THANK YOU
it's been several days that I break my head on it
Post Number:#20 Post Wed Jun 11, 2014 6:28 pm
Cool!
Some suggestions of good practice of programming.
int cmode = 0;
int value = 0;
"cmode" and "value" never will be higher than 255 so use it:
byte cmode = 0;
byte value = 0;
