Forum Software Ferduino code WaveMaker alternated with storm
WaveMaker alternated with storm  [SOLVED]
Post Number:#21 Post Wed Jun 11, 2014 6:53 pm
It work well thanks Fernando :D
wavemaker pumps alternate mode with storm and night mode
i add in the main:
long temps = millis();
byte cmode = 0;
i modified in L_Menu:
 if((modo_selecionado == 1) || (modo_selecionado == 2)|| (modo_selecionado == 4))
    myGLCD.print("     ", 75, 145);
    myGLCD.printNumI(periodo, 75, 145);
I modified in ProcessMyTouch:
else if(modo_selecionado == 4)
        if ((x>=peRB[0]) && (x<=peRB[2]) && (y>=peRB[1]) && (y<=peRB[3]))  // Duração do intervalo -
          //waitForIt(peRB[0], peRB[1], peRB[2], peRB[3]);
          periodo -= 100;
          if(periodo < 100)
            periodo = 5000;
          waveScreen();
        else if ((x>=peRC[0]) && (x<=peRC[2]) && (y>=peRC[1]) && (y<=peRC[3]))  // intervalo +
          //waitForIt(peRC[0], peRC[1], peRC[2], peRC[3]);
          periodo += 1000;
          if(periodo > 5000)
            periodo = 1000;
          waveScreen();
I modified in wave maker:
   switch (cmode){
    case 0:
    value = int(128 + 127 * sin(2 * PI / periodo * times));
    Pump1PWM = 0;
    Pump2PWM = value;
   if((millis() - temps) > 1800000)
     cmode = 1;
     temps = millis();
     break;
    case 1:
    Pump1PWM = value;
    Pump2PWM = 0;
     cmode = 2;
     temps = millis();
     break;
     case 2:
    Pump1PWM = 0;
    Pump2PWM = value;
   if((millis() - temps) > 18000)
     cmode = 3;
     temps = millis();
     break;
     case 3:
    Pump1PWM = value;
    Pump2PWM = 0;
     cmode = 4;
     temps = millis();
     break;
     case 4:
    Pump1PWM = 0;
    Pump2PWM = 255;
     cmode = 5;
     temps = millis();
     break;
     case 5:
    Pump1PWM = 255;
    Pump2PWM = 0;
   if((millis() - temps) > 180000)
     cmode = 6;
     temps = millis();
     break;
     case 6:
    Pump1PWM = 255;
    Pump2PWM = 255;
   if((millis() - temps) > 10000)
     cmode = 0;
     temps = millis();
     break;
