Forum Hardware Others components Wiring for electronic pump
Wiring for electronic pump  [SOLVED]
Post Number:#1 Post Thu Nov 02, 2017 8:45 pm
Hi Fernando and all,
I bought an electronic return pump, the Tunze 1073.050.
Here you can find the manual with details:
https://www.tunze.com/fileadmin/gebrauc ... 3.0588.pdf
it has a power supply with an output at 24V DC 3A that goes into a controller that you can see here:
https://www.tunze.com/PT/en/products/de ... D=7090.250
I would like to use the wave maker output of Ferduino to control this pump.
I'm pretty sure that I should connect the wavemaker output to something in the controller...but I don't have the minimum idea of how.
On the controller there is a potentiometer, so probably the connection should be made to its pins.
Can somebody help me in understanding how can i do this simple thing?
thank you so much, as usual.
Post Number:#2 Post Fri Nov 03, 2017 4:28 pm
Here a picture of the controller.
Last edited by Fernando Garcia on Sat Nov 04, 2017 9:34 am, edited 1 time in total.
Reason: Please use tags [img=left][/img] to post images
Post Number:#3 Post Sat Nov 04, 2017 9:32 am
Measure the voltage between this two pins:
Post Number:#4 Post Sat Nov 04, 2017 3:32 pm
2.42 V
I did what you can see in the picture. Power supply plugged into the controller. Pump not connected (but i think that it is not a problem)
thank you for helping me Fernando.
Last edited by Fernando Garcia on Sun Nov 05, 2017 11:40 am, edited 1 time in total.
Post Number:#5 Post Sun Nov 05, 2017 11:43 am
Moving the knob changes something?
Post Number:#6 Post Sun Nov 05, 2017 2:28 pm
No! It doesn’t change. 2.42 V stable.
Post Number:#7 Post Sun Nov 05, 2017 2:51 pm
You should be able to control this pump using PWM between 0 and 127 or 0 - 2.5 V.
Remove this trimmer then connect the GND pin to Ground and PWM pin to Input.
DO NOT APPLY more than 127 PWM to this input or use a voltage divider on PWM pin.
P.S.: I'm not responsible by any damage in your controller or board. Do it by your own risk.
-------------------------------- Last edited Sun Nov 05, 2017 4:02 pm --------------------------------
My suggestion for you is: buy an Arduino clone to make tests to prevent damage your Ferduino Mega.
Post Number:#8 Post Mon Nov 06, 2017 11:42 am
Ok Fernando, I’ll try following your suggestions and I let you know.
Post Number:#9 Post Sat Nov 11, 2017 6:09 pm
Hi Fernando and guys,
I tried your suggestions with another Arduino that I have. It works but with a little modification.
I think that it is because the pump with the trimmer can not be regulated between 0 and 100% of power...but between 20% and 100%. So removing totally the trimmer the pump controller doesn't work. Otherwise removing just the INPUT pin of the trimmer and connecting arduino's GND and input where indicated by Fernando it works very well (exactly as using the trimmer).
Obviously I confirm that should be used a range 0-127 for the Arduino's Output.
In some weeks I'll perform a final trial with Ferduino Mega and the pump connected.
thank you all!
Post Number:#10 Post Sun Nov 12, 2017 11:58 am
What you are talking doesn't makes sense to me since leaving the trimmer connected between 2.5 V and GND it will work like a simple resistor spending energy only.
Maybe the controller doesn't supports PWM control so the alternative is add a ceramic capacitor of 1 uF between PWM pin and GND.
Return to Others components
