Forum Members section DIY Ferduino controller Module operation of Relays-2 and PCF8575
Post Number:#21 Post Sat Apr 13, 2019 1:43 pm
Images: 271
Solve rating: 214
If do you have problem yet can you answer my last question?
I thought the problem was solved.
Post Number:#22 Post Sun Apr 14, 2019 7:37 am
Images: 26
Sorry, I was still doing tests, the voltage was about 0.37 v and continued with the same problems. I used another 5v relay module and another PCB with a different PCF8575 and still had the same problems. I had left it as impossible and decided not to use the PCF module even if I limited some of the functionalities.
As soon as the new module that Gio indicated that it worked for me, I will try and comment on it.
Regards,
Post Number:#23 Post Sun Apr 14, 2019 10:47 am
Images: 271
Solve rating: 214
The voltage should be around 1.5 V with ULN connected.
Disconnect the ULN and measure the voltage. It should be 5V.
Maybe the input voltage on PCF is less than 5V.
  • Similar Topics
    Replies
    Views
    Last post
