Forum Software Ferduino code White screen
White screen  [SOLVED]
Post Number:#1 Post Fri Jun 07, 2019 11:01 am
Chile
hola fernando estoy tratando de actualiza el codigo a a ferduino master con control web y al cargarlo me queda la pantalla en blanco, no me da ningun error en la carga solo no se ve nada, tengo la pantalla de itead con resolucion 240x400 y shield ITDB02 la version 1.1 con rtc, al final de de la compilacion no dice nada, que podra ser?
El Sketch usa 38222 bytes (15%) del espacio de almacenamiento de programa. El máximo es 253952 bytes.
Las variables Globales usan 2293 bytes (27%) de la memoria dinámica, dejando 5899 bytes para las variables locales. El máximo es 8192 bytes.
estoy usando el ide 1.8.9
espero me puedas ayudar
Post Number:#2 Post Fri Jun 07, 2019 6:50 pm
Welcome Juan!
Please write on forum only in english.
For latest version of Ferduino code a PCF is mandatory.
The white screen is because the controller can't find the module.
Post Number:#3 Post Fri Jun 07, 2019 8:07 pm
Chile
I have never occupied a pcf and the code loaded me without any problem and I wanted to update the latest version just that, the previous code worked without any problem
Post Number:#4 Post Fri Jun 07, 2019 8:18 pm
For latest version a PCF8575 is needed. It's as the code is right now.
Post Number:#5 Post Fri Jun 07, 2019 9:30 pm
Chile
which version can work without pcf since the old code does not smoke me in the current idea of ​​arduino and where I can get it, the version I have is updated on 03/05/2017
Post Number:#6 Post Sat Jun 08, 2019 10:02 am
You can browse the repository on Github and download the code from specific point but it will be missing features and fixes.
Post Number:#7 Post Sat Jun 08, 2019 1:49 pm
Chile
fernando I did what he told me and he gives me these compilation errors
Arduino:1.8.9 (Windows Store 1.8.21.0) (Windows 10), Tarjeta:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from c:\users\juan\appdata\local\temp\arduino_build_23151\sketch\src/Include/Library.h:11:0,
                 from c:\users\juan\appdata\local\temp\arduino_build_23151\sketch\configuration.h:126,
                 from sketch\src\Ferduino_Aquarium_Controller.h:5,
                 from sketch\src\Ferduino_Aquarium_Controller.cpp:4:
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h: In function 'int EEPROM_writeAnything(int, const T&)':
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:3:11: error: 'byte' does not name a type
     const byte* p = (const byte*)(const void*)&value;
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:6:24: error: 'p' was not declared in this scope
    EEPROM.write(ee++, *p++);
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h: In function 'int EEPROM_readAnything(int, T&)':
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:12:5: error: 'byte' was not declared in this scope
     byte* p = (byte*)(void*)&value;
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:12:11: error: 'p' was not declared in this scope
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:12:21: error: expected primary-expression before ')' token
C:\Users\juan\Documents\Arduino\libraries\writeAnything/writeAnything.h:12:23: error: expected primary-expression before 'void'
exit status 1
Error compilando para la tarjeta Arduino/Genuino Mega or Mega 2560.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Post Number:#8 Post Sat Jun 08, 2019 2:10 pm
As I told old version can be missing fixes.
Apply this fix.
https://github.com/FernandoGarcia/Ferdu ... dcfd3a2127
I won't help you with more problems in regression.
The initial issue was answered so I'll close this topic.
