Forum Hardware Others components TFT 5"
TFT 5"  [SOLVED]
Post Number:#1 Post Fri Feb 14, 2020 8:30 am
Germany
can this tft can be used directly.
https://www.ebay.de/itm/5-0-inch-MIT-To ... SwHfxeMGGi
Post Number:#2 Post Fri Feb 14, 2020 11:17 am
Yes, but you should make the changes explained here.
Moreover you have to edit the code to make the menu fill all the screen. All versions modified by users available on forum for 800x480 screen are outdated.
Post Number:#3 Post Fri Feb 14, 2020 12:56 pm
Germany
when you look at the backside of the tft you see the same pins like 400x240.
Post Number:#4 Post Fri Feb 14, 2020 1:16 pm
You should ask the datasheet for this seller because the backlight for this big screens normally are 5 V.
Post Number:#5 Post Fri Feb 14, 2020 4:04 pm
Germany
I found this https://ecksteinimg.de/Datasheet/CP11009.zip
but found nothing about this.
with touchscreen
Display: 5.0 "TFT with backlight
Color spectrum: 262K
Backlight: LED
Resolution: 800 x 480
IC driver: SSD19635V / 3.3V TTL logic compatible.
The display can be used directly in the 5V / 3.3V Arduino system.
Post Number:#6 Post Fri Feb 14, 2020 11:25 pm
I'm not sure about it. The schematic seems different from PCB image.
Anyway you can try connect directly and if the backlight has low brightness so you can make the changes above.
Post Number:#7 Post Mon Apr 27, 2020 3:22 pm
Any news here?
Post Number:#8 Post Sun Oct 04, 2020 8:08 am
Any news here?
Return to Others components
Users viewing this topic: No registered users and 21 guests
