Forum Software Ferduino code Feature request: Calibration for probes
Feature request: Calibration for probes  [SOLVED]
Post Number:#1 Post Tue Jun 08, 2021 5:40 am
There is the possibility that you modify the Ferduino code to be able to perform the calibration of the probes from the environment itself.
This would avoid having to disassemble the probes and circuits to perform the calibration.
Thanks !!
Last edited by Fernando Garcia on Tue Jun 08, 2021 12:20 pm, edited 1 time in total.
Reason: Changed the title to a more suitable.
Post Number:#2 Post Tue Jun 08, 2021 1:01 pm
This feature is in my task list but now I have only stamps 4.X. Is very complicated to add code without hardware to test.
Stamps 4.x are obsolete since long time so add code for it will be waste of time.
Normally is not needed disassembly the controller, is needed just change the code and it should be done one time per year.
Can you show me how your stamps are connected to your controller?
Post Number:#3 Post Tue Jun 08, 2021 2:51 pm
I connect the probe module to the main board with RJ45, lately when trying to insert images in the message it gives me the following error: "It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct"
Post Number:#4 Post Tue Jun 08, 2021 3:02 pm
You should mark the option "Align image" as left, center or right leaving as default will give you this error.
It seems good but I think you could make a single PCB to connect the ISO board, rj45 and multiplexer to avoid bad connections in wires.
Also the box could be so much smaller.
As do you have a rj45 you could use a spare Arduino to calibrate the probes when needed.
Post Number:#5 Post Tue Jun 08, 2021 5:41 pm
Thanks for the idea !!
I had the box at home and I have taken advantage of it, I am looking at 3D printers to make the main module box, the one for the probes and the dosing pumps
Users viewing this topic: No registered users and 22 guests
