Forum Software Ferduino code Screensaver
Screensaver  [SOLVED]
Post Number:#1 Post Wed Sep 17, 2014 4:28 pm
Topics: 22
Topics: 22
hello
you must forgive me but I do not know much about programming
I wanted to ask you can make a kind of screensaver?
when for a certain period of time is not touched, the display turns off
Post Number:#2 Post Wed Sep 17, 2014 4:57 pm
I didn't know anything about programming when started this project in January of 2012.
Do you'll never learn without try first.
I'll not write any custom function that need of a menu.
All this informations are important for me so, I want see it every time.
I think this function useless because the TFT never is really OFF.
Feel free to change anything on your code.
Post Number:#3 Post Wed Sep 17, 2014 5:17 pm
Topics: 22
Topics: 22
thanks
but I do not know which way to me
I wanted to turn down the brightness to 0 when it is not used all here
thanks anyway
Post Number:#4 Post Sat Nov 01, 2014 5:53 pm
Topics: 22
Topics: 22
someone can give me a help I would make sure that after 10 seconds of not using the touch is a black screen
thanks
Post Number:#5 Post Tue Nov 04, 2014 10:20 am
I have an example for you.
#include <UTFT.h>
#include <UTouch.h>
#include <DS1307henning.h>
extern uint8_t BigFont[];
extern uint8_t SevenSegNumFontPlus[];
unsigned long previousMillis_1 = 0;
unsigned long previousMillis_2 = 0;
int interval = 20; // In seconds
UTFT myGLCD(ITDB32WD,38,39,40,41);
// UTouch      myTouch(6,5,4,3,2); // For DIY controller
UTouch      myTouch(7,6,5,4,3);    // For Ferduino Mega 2560
//       (SDA,SCL)
//DS1307 rtc(20, 21); // For DIY controller
DS1307 rtc(18, 19); // For Ferduino Mega 2560
Time t_temp, t;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  rtc.halt(false);
  mainScreen();
  previousMillis_1 = millis();
  if(myTouch.dataAvailable())
    myGLCD.clrScr();
    myGLCD.setFont(BigFont);
    myGLCD.setColor(255, 0, 0);
    myGLCD.print("Touch received!", CENTER, 110);
    delay(1000);
    previousMillis_2 = millis();
  if((millis() - previousMillis_1) > 5000)
    if((millis() - previousMillis_2) > interval * 1000)
      clockScreen();
      mainScreen();
void mainScreen()
  myGLCD.clrScr();
  myGLCD.setColor(255, 255, 255);
  myGLCD.print("Waiting for touch...", CENTER, 110);
  myGLCD.setColor(0, 255, 0);
  myGLCD.print("0 degrees", 0, 0, 0);
  myGLCD.print("90 degrees", 399, 0, 90);
  myGLCD.print("180 degrees", 399, 239, 180);
  myGLCD.print("270 degrees", 0, 239, 270);
void clockScreen()
  myGLCD.clrScr();
  myGLCD.setFont(SevenSegNumFontPlus);
  myGLCD.setColor(0, 174, 255);
  myGLCD.print(rtc.getTimeStr(FORMAT_LONG), CENTER, 100);
Post Number:#6 Post Tue Nov 04, 2014 6:22 pm
Topics: 22
Topics: 22
thanks
but I can not understand how to do the command that makes the black screen
Post Number:#7 Post Tue Nov 11, 2014 7:28 pm
Topics: 22
Topics: 22
I am trying to use your example code ferduino
which function should I use to insert in the LOOP to make sure that if you do not touch the screen I have to display the time
because in this instance I am
      clockScreen();
      mainScreen();
but does not work well because after I display the time but I also see to click the main menu
thanks
thanks
Post Number:#8 Post Tue Nov 11, 2014 8:10 pm
Post Number:#9 Post Wed Nov 12, 2014 10:05 am
Topics: 22
Topics: 22
thank you very nice
they had seen the codes that I have linked, but I can not understand are not very experienced
I might have some more information?
thank you kindly
Post Number:#10 Post Fri Nov 14, 2014 3:42 pm
Topics: 22
Topics: 22
thanks
Could you give me some help? I can not figure out which ones you posted
thanks
Post Number:#11 Post Fri Nov 14, 2014 4:23 pm
I hate give the fish.
I prefer teach get the fish.
But I think that's missing some willingness to learn.
Anyway here's your code:
In the tab "Ferduino" find:
Add after:
Find:
int dispScreen = 0;
Add after:
In the tab "botoes e etc" add:
void clockScreen()
  myGLCD.clrScr();
On loop find:
processMyTouch();
Replace with:
    if(((millis() - previousMillis_2) > interval * 1000) && (dispScreen == 0))
      clearScreen();
      mainScreen(true);
      processMyTouch();
Find:
mainScreen();
Replace with:
        clockScreen();
        mainScreen();
Post Number:#12 Post Sun Nov 16, 2014 6:21 am
Topics: 22
Topics: 22
thanks
but it does not work also spent a lot of time does not change the time of day display
Post Number:#13 Post Sun Nov 16, 2014 8:04 am
Are you sure?
Post Number:#14 Post Sun Nov 16, 2014 10:19 am
Topics: 22
Topics: 22
I do not work. I made the changes you told me is on the home screen and never changes
these are my codes
https://drive.google.com/file/d/0B1EU3g ... sp=sharing
Post Number:#15 Post Sun Nov 16, 2014 10:38 am
It's ok?
Where I told for you remove "{}"?
Post Number:#16 Post Sun Nov 16, 2014 10:48 am
Topics: 22
Topics: 22
ok thanks I get
Last edited by Simone Sandonati on Sun Nov 16, 2014 11:07 am, edited 1 time in total.
Post Number:#17 Post Sun Nov 16, 2014 10:58 am
Post Number:#18 Post Sun Nov 16, 2014 11:34 am
Topics: 22
Topics: 22
many thanks
because if I put more time as 30 seconti does not work?
int interval = 35; // In seconds
Post Number:#19 Post Sun Nov 16, 2014 5:03 pm
Images: 1
[ITA]
Simone, non può essere :D
quel valore può essere un intero qualsiasi, quindi non può cambiare se metti 20 o 35.
Cerca il problema da qualche altra parte!
[/ITA]
It can't be... search for the problem somewhere else!
[ITA]
devi aggiugnere una { ( parentesi graffa aperta ) dopo
if(myTouch.dataAvaiable())
e dopo
if ( dispScreen ==0 )
e una } (parentesi graffa chiusa ) dopo
previousMillis_2= millis();
e dopo
mainScreen();
Post Number:#20 Post Mon Nov 17, 2014 3:22 pm
Topics: 22
Topics: 22
[ITA]
[/ITA]
[ITA]
e dopo
e dopo
mainScreen();
[ITA]
grazie
ma il problema che non mi andava l'ho risolto in effetti avevo sbagliato a non mettere le parentesi
ma la mia domanda del tempo di ritardo dei 30 secondi vi volevo chiedere che se aumento non va più in salvaschermo
[/ITA]
