Forum Software Ferduino code Upload problem
Upload problem  [SOLVED]
Post Number:#1 Post Sat Dec 22, 2018 2:57 pm
Topics: 5
Topics: 5
Germany
When i open Ferduino_Aquarium_Controller.ino
only opened Ferduino_Aquarium_Controller.ino and Configuration.h in Arduino IDE
I dun know how File i can Upload to Arduino Mega
wha's wrong
my dowloaded Ferduino Controller Software from GitHub only shows this one:
and so on .................
// Este programa é software livre; Você pode redistribuí-lo e/ou
// modificá-lo sob os termos da GNU General Public License
// como publicada pela Free Software Foundation versão 3
// da licença, ou (por sua opção) qualquer versão posterior.
// Este programa é distribuído na esperança que seja útil,
// mas sem qualquer garantia; sem mesmo a garantia implícita de
// comercialização ou propósito particular. Consulte o
// GNU General Public License para mais detalhes.
Last edited by Fernando Garcia on Sun Dec 23, 2018 5:22 am, edited 1 time in total.
Reason: Please use tags [code][/code] to post any code here.
206 gallon tank, 42 gallon technic sump, system triton core 7, 8 dosing Pumps, AM Aquarius, AM Reef LED, AM Ocean LED at TC420, AM Temp controller, Skimmer Bubble Magus Curve M7, 3 Tunze flow pumps at Tunze Multi Controller 7096, AM refill system pro
Post Number:#2 Post Sun Dec 23, 2018 5:28 am
Images: 268
Solve rating: 208
It's ok. Please whatch the videos about how to install the code.
Check this topic also.
Post Number:#3 Post Mon Dec 24, 2018 10:28 am
Topics: 5
Topics: 5
Germany
Thanks I will try to follow correct instructions onto video
Post Number:#4 Post Mon Dec 24, 2018 10:38 pm
Topics: 5
Topics: 5
Germany
when I upload Ferduino get varios errores
what's the problem
In file included from /Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:8:0,
                 from /Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/MsgPackDeserializer.hpp:11,
                 from /Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson.hpp:27,
                 from /Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson.h:9,
                 from sketch/src/../src/Include/Library.h:33,
                 from sketch/src/../Configuration.h:122,
                 from sketch/src/Ferduino_Aquarium_Controller.h:5,
                 from sketch/src/Ferduino_Aquarium_Controller.cpp:4:
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:9:28: error: macro "swap" requires 3 arguments, but only 2 given
 inline void swap(T& a, T& b) {
In file included from /Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/MsgPackDeserializer.hpp:11:0,
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:13:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[0], p[7]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:14:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[1], p[6]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:15:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[2], p[5]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:16:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[3], p[4]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:20:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[0], p[3]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:21:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[1], p[2]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/endianess.hpp:25:18: error: macro "swap" requires 3 arguments, but only 2 given
   swap(p[0], p[1]);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:9:13: error: variable or field 'swap' declared void
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:10:5: error: expected primary-expression before 't'
   T t(a);
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:10:5: error: expected '}' before 't'
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:11:3: error: 'a' does not name a type
   a = b;
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:12:3: error: 'b' does not name a type
   b = t;
/Users/gordonlehmann/Documents/Arduino/libraries/ArduinoJson/src/ArduinoJson/MsgPack/../Polyfills/utility.hpp:14:1: error: expected declaration before '}' token
 }  // namespace ARDUINOJSON_NAMESPACE
Mehrere Bibliotheken wurden für "Ethernet.h" gefunden
 Benutzt: /Users/gordonlehmann/Documents/Arduino/libraries/Ethernet
 Nicht benutzt: /Applications/Arduino.app/Contents/Java/libraries/Ethernet
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Mega or Mega 2560.
Last edited by Fernando Garcia on Thu Dec 27, 2018 4:08 pm, edited 1 time in total.
Post Number:#5 Post Tue Dec 25, 2018 4:48 pm
Topics: 5
Topics: 5
Germany
the problem was the JSON library have completely rebuilt the Arduino IDE and created everything as in the video and lo and behold!
  • Similar Topics
    Replies
    Views
    Last post
